Updated on 2025-09-19 GMT+08:00
Permissions Management
Description
If you need to assign different permissions to employees in your enterprise to access your LTS resources, Identity and Access Management (IAM) is a good choice for fine-grained permissions management. IAM provides identity authentication, permissions management, and access control, helping you secure access to your LTS resources.
With IAM, you can use your account to create IAM users for your employees, and assign permissions to the users to control their access to LTS resources. For example, some software developers in your enterprise need to use LTS resources but should not delete them or perform other high-risk operations. In this case, you can create IAM users for the software developers and grant them only the permissions required.
If your account does not need individual IAM users for permissions management, you may skip over this section.
IAM can be used for free. You pay only for the resources in your account. For more information about IAM, see IAM Service Overview.
LTS Permissions
By default, new IAM users do not have permissions assigned. You need to add users to one or more groups, and attach permissions policies or roles to these groups. Users inherit permissions from the groups to which they are added and can perform specified operations on cloud services based on the permissions.
LTS is a project-level service deployed and accessed in specific physical regions. To assign LTS permissions to a user group, specify the scope as region-specific projects and select projects for the permissions to take effect. If All projects is selected, the permissions will take effect for the user group in all region-specific projects. When accessing LTS, the users need to switch to a region where they have been authorized to use LTS.
Policies: A type of fine-grained authorization mechanism that defines permissions required to perform operations on specific cloud resources under certain conditions. This mechanism allows for more flexible policy-based authorization, meeting requirements for secure access control. For example, you can grant Elastic Cloud Server (ECS) users only the permissions for managing a certain type of ECSs. Most policies define permissions based on APIs.
The system permissions supported by LTS are listed in Table 1.
Table 1 LTS system permissions
Name
Description
Type
Dependency
LTS FullAccess
Full permissions for LTS. Users with these permissions can perform operations on LTS.
System-defined policy
CCE Administrator, OBS Administrator, and AOM FullAccess
LTS ReadOnlyAccess
Read-only permissions for LTS. Users with these permissions can only view LTS data.
LTS Administrator
Administrator permissions for LTS.
System-defined role
This role is dependent on the Tenant Guest and Tenant Administrator roles.
Table 2 lists the common operations supported by each system-defined policy and role of LTS. Choose the appropriate policies and roles according to this table.
Table 2 Common operations supported by each LTS system policy or role
Operation
LTS FullAccess
LTS ReadOnlyAccess
LTS Administrator
Querying a log group
Creating a log group
Modifying a log group
Deleting a log group
Querying a log stream
Creating a log stream
Modifying a log stream
Deleting a log stream
Configuring log collection from hosts
Viewing a log transfer task
Creating a log transfer task
Modifying a log transfer task
Deleting a log transfer task
Enabling a log transfer task
Disabling a log transfer task
Installing ICAgent
Upgrading ICAgent
Uninstalling ICAgent
To use a custom fine-grained policy, log in to IAM as the administrator and select fine-grained permissions of LTS as required.
Table 3 describes fine-grained permission dependencies of LTS.
Table 3 Fine-grained permission dependencies of LTS
Permission
Description
Dependency
lts:agents:list
List agents
None
lts:buckets:get
Get bucket
None
lts:groups:put
Put log group
None
lts:transfers:create
Create transfer
obs:bucket:PutBucketAcl
obs:bucket:GetBucketAcl
obs:bucket:GetEncryptionConfiguration
obs:bucket:HeadBucket
dis:streams:list
dis:streamPolicies:list
lts:groups:get
Get log group
None
lts:transfers:put
Put transfer
dis:streams:list
lts:resourceTags:delete
Delete resource tag
None
lts:ecsOsLogPaths:list
List ecs os logs paths
None
lts:structConfig:create
Create struct config
None
lts:agentsConf:get
Get agent conf
None
lts:logIndex:list
Get log index
None
lts:transfers:delete
Delete transfer
None
lts:regex:create
Create struct regex
None
lts:subscriptions:delete
Delete subscription
None
lts:overviewLogsLast:list
List overview last logs
None
lts:logIndex:get
Get log index
None
lts:sqlalarmrules:create
Create alarm options
None
lts:agentsConf:create
Create agent conf
None
lts:sqlalarmrules:get
Get alarm options
None
lts:datasources:batchdelete
Batch delete datasource
None
lts:structConfig:put
Update struct config
None
lts:groups:list
List log groups
None
lts:sqlalarmrules:delete
Delete alarm options
None
lts:transfers:action
Enabled transfer
None
lts:datasources:post
Post datasource
None
lts:topics:create
Create log topic
None
lts:resourceTags:get
Query resource tags
None
lts:logs:list
List logs
None
lts:subscriptions:create
Create subscription
None
lts:overviewLogsTopTopic:get
List overview top logs
None
lts:datasources:put
Put datasource
None
lts:structConfig:delete
Delete struct config
None
lts:logIndex:delete
Deleting a specified log index
None
lts:topics:delete
Delete log topics
None
lts:agentSupportedOsLogPaths:list
List agent supported os logs paths
None
lts:topics:put
Put log topic
None
lts:agentHeartbeat:post
Post agent heartbeat
None
lts:logsByName:upload
Upload logs by name
None
lts:buckets:list
List buckets
None
lts:logIndex:post
Create log index
None
lts:logContext:list
List logs context
None
lts:groups:delete
Delete log group
None
lts:resourceTags:put
Update resource tags
None
lts:structConfig:get
Get struct config
None
lts:overviewLogTotal:get
Get overview logs total
None
lts:subscriptions:put
Put subscription
None
lts:subscriptions:list
List subscription
None
lts:datasources:delete
Delete datasource
None
lts:transfersStatus:get
List transfer status
None
lts:logIndex:put
Put log index
None
lts:sqlalarmrules:put
Modify alarm options
None
lts:logs:upload
Upload logs
None
lts:agentDetails:list
List agent diagnostic log
None
lts:agentsConf:put
Put agent conf
None
lts:logstreams:list
Check logstream resources
None
lts:subscriptions:get
Get subscription
None
lts:disStreams:list
Query DIS pipe
None
lts:groupTopics:put
Create log group and log topic
None
lts:resourceInstance:list
Query resource instance
None
lts:transfers:list
List transfers
None
lts:topics:get
Get log topic
None
lts:agentsConf:delete
Delete agent conf
None
lts:agentEcs:list
List agent ecs
None
lts:indiceLogs:list
Search indiceLogs
None
lts:topics:list
List log topic
None
