Updated on 2025-03-18 GMT+08:00
Uploading an Object (SDK for C)
The data flow is saved to callback_data (see the callback_data definition in Uploading an Object - Streaming (SDK for C)). Use the callback function put_object_data_callback defined in obs_put_object_handler to copy the content of the uploaded object to buffer, a character pointer parameter of the callback function.
For more information, see Uploading an Object - Streaming (SDK for C).
Sample code:
static void test_put_object_from_buffer()
     // Buffer to be uploaded
    char *buffer = "abcdefg";
     // Length of the buffer to be uploaded
    int buffer_size = strlen(buffer);
     // Name of an object to be uploaded
    char *key = "put_buffer_test";
    // Initialize option.
    obs_options option;
    init_obs_options(&option);
    option.bucket_options.host_name = "<your-endpoint>";
    option.bucket_options.bucket_name = "<Your bucket name>";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY.
    // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    option.bucket_options.access_key = getenv("ACCESS_KEY_ID");
    option.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
    // Initialize the properties of an object to be uploaded.
    obs_put_properties put_properties;
    init_put_properties(&put_properties);
    // Customize the structure for storing uploaded data.
    put_buffer_object_callback_data data;
    memset(&data, 0, sizeof(put_buffer_object_callback_data));
    // Assign the buffer value to the structure.
    data.put_buffer = buffer;
    // Set buffersize.
    data.buffer_size = buffer_size;
    // Set the callback function. The corresponding callback function needs to be implemented.
    obs_put_object_handler putobjectHandler =
        { &response_properties_callback, &put_buffer_complete_callback },
          &put_buffer_data_callback
    put_object(&option, key, buffer_size, &put_properties,0,&putobjectHandler,&data);
    if (OBS_STATUS_OK == data.ret_status) {
        printf("put object from buffer successfully. \n");
    else
        printf("put object from buffer failed(%s).\n", obs_get_status_name(data.ret_status));
