Updated on 2025-05-16 GMT+08:00
Listing Objects (SDK for C)
This example shows how to list all objects in a bucket.
Sample code:
static void test_list_bucket_objects()
    // Create and initialize option.
    obs_options option;
    init_obs_options(&option);
    option.bucket_options.host_name = "<your-endpoint>";
    option.bucket_options.bucket_name = "<Your bucketname>";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY.
    // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    option.bucket_options.access_key = getenv("ACCESS_KEY_ID");
    option.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
    // Set response callback function.
    obs_list_objects_handler list_bucket_objects_handler =
        { &response_properties_callback, &list_objects_complete_callback },
        &list_objects_callback
    // Customize callback data.
    list_bucket_callback_data data;
    memset(&data, 0, sizeof(list_bucket_callback_data));
    // List objects.
    list_bucket_objects(&option, "<prefix>", "<marker>", "<delimiter>", "<maxkeys>", &list_bucket_objects_handler, &data);
    if (OBS_STATUS_OK == data.ret_status) {
        printf("list bucket objects successfully. \n");
    else
        printf("list bucket objects failed(%s).\n",
            obs_get_status_name(data.ret_status));
