Help Center/ Object Storage Service/ SDK Reference/ Go/ Buckets (SDK for Go)/ Configuring Static Website Hosting for a Bucket (SDK for Go)
Updated on 2024-06-21 GMT+08:00
Function
You can host static website resources such as HTML web pages, flash files, or audio and video files in an OBS bucket, so that you can access these hosted resources using the bucket's website endpoint. Typical use cases include:
  • Redirecting all requests to another website
  • Redirecting specific requests
This API configures static website hosting for a bucket.
Restrictions
  • Periods (.) should be avoided in the target bucket name, or there may be certificate verification failures on the client when you use HTTPS for access.
  • The request body of the website configuration cannot exceed 10 KB.
  • To configure static website hosting for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutBucketWebsite in IAM or PutBucketWebsite in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) SetBucketWebsiteConfiguration(input *SetBucketWebsiteConfigurationInput) (output *BaseModel, err error)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
input
Yes
Explanation:
Input parameters for configuring static website hosting. For details, see Table 2.
Table 2 SetBucketWebsiteConfigurationInput
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Value range:
The value must contain 3 to 63 characters.
RedirectAllRequestsTo
RedirectAllRequestTo
No
Explanation:
Redirection rules for all requests. For details, see Table 3.
IndexDocument
IndexDocument
No
Explanation:
Default page configuration. For details, see Table 4.
ErrorDocument
ErrorDocument
No
Explanation:
Error page configuration. For details, see Table 5.
RoutingRules
[]RoutingRule
No
Explanation:
List of routing rules. For details, see Table 6.
  • ErrorDocument, IndexDocument, and RoutingRules must be used together and they cannot be used with RedirectAllRequestsTo.
  • When ErrorDocument, IndexDocument, and RoutingRules are used together, RoutingRules can be left blank.
  • You must specify either the three parameters (ErrorDocument, IndexDocument, and RoutingRules), or RedirectAllRequestsTo.
Table 3 RedirectAllRequestsTo
Parameter
Type
Mandatory (Yes/No)
Description
HostName
string
Yes if RedirectAllRequestsTo is specified
Explanation:
Host name used for redirection, for example, www.example.com
Restrictions:
The host name must comply with the host name rules.
Default value:
None
Protocol
ProtocolType
No
Explanation:
Protocol used for redirection
Value range:
See Table 9.
Default value:
None
Table 4 IndexDocument
Parameter
Type
Mandatory (Yes/No)
Description
Suffix
string
Yes if IndexDocument is specified
Explanation:
Suffix that is appended to the request for a directory. For example, if the suffix is index.html and you request samplebucket/images/, the returned data will be for the object named images/index.html in the bucket samplebucket.
Value range:
This parameter can neither be left blank nor contain slashes (/).
Default value:
None
Table 5 ErrorDocument
Parameter
Type
Mandatory (Yes/No)
Description
Key
string
No if ErrorDocument is specified
Explanation:
Object name to use when a 4XX error occurs. This parameter specifies the webpage to display when an error occurs.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
Table 6 RoutingRule
Parameter
Type
Mandatory (Yes/No)
Description
Condition
Condition
No
Explanation:
Conditions that must be met for the specified redirect to apply
Value range:
See Table 7.
Default value:
None
Redirect
Redirect
Yes if RoutingRule is specified
Explanation:
Details about the redirection. For details, see Table 8.
Table 7 Condition
Parameter
Type
Mandatory (Yes/No)
Description
KeyPrefixEquals
string
No
Explanation:
Object name prefix when the redirection is applied. When a request is sent for accessing an object, the redirection rule takes effect if the object name prefix matches the value specified for this parameter.
For example, to redirect the request for object ExamplePage.html, set the KeyPrefixEquals to ExamplePage.html.
Restrictions:
This parameter cannot be used together with HttpErrorCodeReturnedEquals.
Value range:
Default value:
None
string
No
Explanation:
HTTP error codes when the redirection takes effect. The specified redirection is applied only when the error code returned equals the value specified for this parameter.
For example, if you want to redirect requests to NotFound.html when HTTP error code 404 is returned, set HttpErrorCodeReturnedEquals to 404 in Condition, and set ReplaceKeyWith to NotFound.html in Redirect.
Restrictions:
This parameter cannot be used together with KeyPrefixEquals.
Value range:
See Error Codes.
Default value:
None
Table 8 Redirect
Parameter
Type
Mandatory (Yes/No)
Description
Protocol
ProtocolType
No if used as a request parameter
Explanation:
Value range:
See Table 9.
Default value:
None
HostName
string
Explanation:
Default value:
None
ReplaceKeyPrefixWith
string
Explanation:
Object name prefix used for redirection
Value range:
Default value:
None
ReplaceKeyWith
string
Explanation:
Object name used for redirection
Restrictions:
This parameter cannot be used together with replaceKeyPrefixWith.
Value range:
Default value:
None
HttpRedirectCode
string
Explanation:
HTTP status code in the response to the redirect request. For details, see Status Code.
Default value:
None
Table 9 ProtocolType
Constant
Default Value
Description
ProtocolHttp
http
HTTP protocol used for redirection
ProtocolHttps
https
HTTPS protocol used for the redirection request
Responses
Table 10 List of returned results
Parameter
Type
Description
output
*BaseModel
Explanation:
Returned results. For details, see Table 11.
err
error
Explanation:
Error messages returned by the API
Table 11 BaseModel
Parameter
Type
Description
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
Code Examples
This example configures static website hosting for bucket examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint, obs.WithSecurityToken(securityToken))
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.SetBucketWebsiteConfigurationInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify a default page (index.html as an example). This configuration indicates that when examplebucket/images/ is requested, the content of object images/index.html in bucket samplebucket will be returned.
    input.IndexDocument.Suffix = "index.html"
    // Specify an error page (error.html as an example).
    input.ErrorDocument.Key = "error.html"
    // Specify the list of request redirect rules.
    input.RoutingRules = []obs.RoutingRule{
        {Redirect: obs.Redirect{HostName: "www.a.com", Protocol: obs.ProtocolHttp, ReplaceKeyPrefixWith: "prefix", HttpRedirectCode: "304"}},
        {Redirect: obs.Redirect{HostName: "www.b.com", Protocol: obs.ProtocolHttps, ReplaceKeyWith: "replaceKey", HttpRedirectCode: "304"}},
    // Configure static website hosting for the bucket.
    output, err := obsClient.SetBucketWebsiteConfiguration(input)
    if err == nil {
        fmt.Printf("Set bucket(%s)'s website successful!\n", input.Bucket)
        fmt.Printf("RequestId:%s\n", output.RequestId)
        return
    fmt.Printf("Set bucket(%s)'s website fail!\n", input.Bucket)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
