Updated on 2025-05-12 GMT+08:00
Modifying an Object (SDK for Go)
Function
This API modifies the content of an object in a parallel file system from the specified position.
Restrictions
Method
func (obsClient ObsClient) ModifyObject(input *ModifyObjectInput) (output *ModifyObjectOutput, err error)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
input
*ModifyObjectInput
Yes
Explanation:
Input parameters for modifying an object. For details, see Table 2.
Table 2 ModifyObjectInput
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Key
string
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
Position
int64
Yes
Explanation:
Position from which the object is modified
Value range:
1 to (263 – 1), in bytes
Default value:
1, indicating the modification starts from the first byte of the object
ContentLength
int64
No
Explanation:
Size of the object to be modified
Value range:
Default value:
None
Body
io.Reader
No
Explanation:
Data stream of the object to be modified
Default value:
None
Responses
Table 3 List of returned results
Parameter
Type
Description
output
*ModifyObjectOutput
Explanation:
Returned results. For details, see Table 4.
err
error
Explanation:
Error messages returned by the API
Table 4 ModifyObjectOutput
Parameter
Type
Description
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
ETag
string
Explanation:
Base64-encoded, 128-bit MD5 value of an object. ETag is the unique identifier of the object content. It can be used to determine whether the object content is changed. For example, if the ETag value is A when an object is uploaded, but changes to B when the object is downloaded, it indicates that the object content has been changed. The ETag reflects changes to the object content, rather than the object metadata. An uploaded or copied object has a unique ETag after being encrypted using MD5.
Restrictions:
If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object.
Value range:
The value must contain 32 characters.
Default value:
None
Code Examples
This example modifies object example/objectname in bucket examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
package main
import (
    "fmt"
    "os"
    "strings"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.ModifyObjectInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify an object (example/objectname as an example).
    input.Key = "example/objectname"
    input.Position = 0
    input.Body = strings.NewReader("Modify Hello OBS")
    // Modify the object.
    output, err := obsClient.ModifyObject(input)
    if err == nil {
        fmt.Printf("Modify object(%s) under the bucket(%s) successful!\n", input.Key, input.Bucket)
        fmt.Printf("ETag:%s\n", output.ETag)
        return
    fmt.Printf("Modify object(%s) under the bucket(%s) fail!\n", input.Key, input.Bucket)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
