Obtaining the Region of a Bucket (SDK for Python)
Function
This API returns the region of a bucket.
Restrictions
- To obtain the region of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketLocation in IAM or GetBucketLocation in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
ObsClient.getBucketLocation(bucketName, extensionHeaders)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
bucketName |
str |
Yes |
Explanation: Bucket name Restrictions:
Default value: None |
extensionHeaders |
dict |
No |
Explanation: Extension headers Value range: See User-defined Header (SDK for Python). Default value: None |
Responses
Type |
Description |
Explanation: SDK common results |
Parameter |
Type |
Description |
status |
int |
Explanation: HTTP status code Value range: A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
reason |
str |
Explanation: Reason description. Default value: None |
errorCode |
str |
Explanation: Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
errorMessage |
str |
Explanation: Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
requestId |
str |
Explanation: Request ID returned by the OBS server Default value: None |
indicator |
str |
Explanation: Error indicator returned by the OBS server. Default value: None |
hostId |
str |
Explanation: Requested server ID. If the value of status is less than 300, this parameter is left blank. Default value: None |
resource |
str |
Explanation: Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank. Default value: None |
header |
list |
Explanation: Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header. Default value: None |
body |
object |
Explanation: Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python). Default value: None |
GetResult.body Type |
Description |
Explanation: Response to the request for obtaining a bucket location |
Parameter |
Type |
Description |
location |
str |
Explanation: Region where a bucket is located Restrictions: If the used endpoint is obs.myhuaweicloud.com, this parameter is not required. If any other endpoint is used, this parameter is required. Value range: To learn about valid regions and endpoints, see Regions and Endpoints. An endpoint is the request address for calling an API. Endpoints vary depending on services and regions. To obtain the regions and endpoints, contact the enterprise administrator. Default value: If obs.myhuaweicloud.com is used as the endpoint and no region is specified, cn-north-1 (the CN North-Beijing1 region) is used by default. |
Code Examples
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 |
from obs import ObsClient import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: bucketName="examplebucket" # Obtain the bucket region. resp = obsClient.getBucketLocation(bucketName) # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails. if resp.status < 300: print('Get Bucket Location Succeeded') print('requestId:', resp.requestId) print('location:', resp.body.location) else: print('Get Bucket Location Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Get Bucket Location Failed') print(traceback.format_exc()) |
Feedback
Was this page helpful?
Chatbot
