Help Center/ Object Storage Service/ SDK Reference/ Python/ Bucket-Related APIs (SDK for Python)/ Obtaining the Logging Configuration of a Bucket (SDK for Python)
Updated on 2025-05-09 GMT+08:00
Function
This API returns the logging configuration of a bucket.
Restrictions
Method
ObsClient.getBucketLogging(bucketName, extensionHeaders)
Request Parameters
Parameter
Type
Mandatory (Yes/No)
Description
bucketName
str
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket properties comply with those set in the first creation request.
Default value:
None
extensionHeaders
dict
No
Explanation:
Extension headers.
Value range:
See User-defined Header (SDK for Python).
Default value:
None
Responses
Type
Description
GetResult
Explanation:
SDK common results
Table 1 GetResult
Parameter
Type
Description
status
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
reason
str
Explanation:
Reason description.
Default value:
None
errorCode
str
Explanation:
Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
errorMessage
str
Explanation:
Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
requestId
str
Explanation:
Request ID returned by the OBS server
Default value:
None
indicator
str
Explanation:
Error indicator returned by the OBS server.
Default value:
None
hostId
str
Explanation:
Requested server ID. If the value of status is less than 300, this parameter is left blank.
Default value:
None
resource
str
Explanation:
Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank.
Default value:
None
header
list
Explanation:
Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header.
Default value:
None
body
object
Explanation:
Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python).
Default value:
None
GetResult.body Type
Description
Logging
Explanation:
Logging configuration information
Table 2 Logging
Parameter
Type
Mandatory (Yes/No)
Description
targetBucket
str
No if used as a request parameter
Explanation:
Name of the bucket for storing log files
Restrictions:
  • This bucket must be in the same region as the bucket with logging enabled.
  • A bucket name:
Default value:
None
targetPrefix
str
Explanation:
Name prefix for log files stored in the log storage bucket
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
targetGrants
list of Grant
Explanation:
Permission information list of grantees, which defines grantees and their permissions for log files. For details, see Table 3.
Default value:
None
agency
str
Yes if the parameter is in a request to enable bucket logging
Explanation:
Name of the IAM agency created by the owner of the target bucket for OBS.
You can select an existing IAM agency or create one. For details about how to create an agency, see Creating an IAM Agency.
Restrictions:
By default, the IAM agency only requires the PutObject permission to upload logs to the target bucket. If default encryption is enabled for the target bucket, the agency also requires the KMS Administrator permission in the region where the target bucket is located.
Default value:
None
Table 3 Grant
Parameter
Type
Description
grantee
Grantee
Explanation:
Grantee information. For details, see Table 4.
Default value:
None
permission
str
Explanation:
Granted permission
Value range:
See Table 6.
Default value:
None
delivered
bool
Explanation:
Whether the bucket ACL is applied to all objects in the bucket
Value range:
True: The bucket ACL is applied to all objects in the bucket.
False: The bucket ACL is not applied to all objects in the bucket.
Default value:
False
Table 4 Grantee
Parameter
Type
Description
grantee_id
str
Explanation:
Account (domain) ID of the grantee.
Value range:
To obtain the account ID, see How Do I Get My Account ID and IAM User ID? (SDK for Python)
Default value:
None
grantee_name
str
Explanation:
Account name of the grantee.
Restrictions:
  • Starts with a letter. Contains 6 to 32 characters.
  • Contains only letters, digits, hyphens (-), and underscores (_).
Default value:
None
group
str
Explanation:
Authorized user group. For details, see Table 5.
Default value:
None
The authorized entity can be an individual user or a user group. grantee_id and grantee_name must be used together and they cannot be used with group.
Table 5 Group
Constant
Description
ALL_USERS
All users
AUTHENTICATED_USERS
Authorized users. This constant is deprecated.
LOG_DELIVERY
Log delivery group. This constant is deprecated.
Table 6 Permission
Constant
Description
READ
Read permission
A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket.
A grantee with this permission for an object can obtain the object content and metadata.
WRITE
Write permission
A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket.
Such permission for an object is not applicable.
READ_ACP
Permission to read ACL configurations
A grantee with this permission can obtain the ACL of a bucket or object.
A bucket or object owner has this permission for the bucket or object permanently.
WRITE_ACP
Permission to modify ACL configurations
A grantee with this permission can update the ACL of a bucket or object.
A grantee with this permission can modify the ACL, thus obtaining full access permissions.
FULL_CONTROL
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL.
A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket.
A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object.
Code Examples
This example returns the logging configuration of bucket examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
from obs import ObsClient
import os
import traceback
# Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage.
# Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
ak = os.getenv("AccessKeyID")
sk = os.getenv("SecretAccessKey")
# (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables.
# security_token = os.getenv("SecurityToken")
# Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use.
server = "https://obs.ap-southeast-1.myhuaweicloud.com"
# Create an obsClient instance.
# If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance.
obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server)
try:
    bucketName="examplebucket"
    # Obtain the logging configuration of the bucket.
    resp = obsClient.getBucketLogging(bucketName)
    # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails.
    if resp.status < 300:
        print('Get Bucket Logging Succeeded')
        print('requestId:', resp.requestId)
        print('targetBucket:', resp.body.targetBucket)
        print('targetPrefix:', resp.body.targetPrefix)
        index = 1
        for grant in resp.body.targetGrants:
            print('grant [' + str(index) + ']')
            print('grant_id:', grant.grantee.grantee_id)
            print('grant_name:', grant.grantee.grantee_name)
            print('group:', grant.grantee.group)
            print('permission:', grant.permission)
            index += 1
    else:
        print('Get Bucket Logging Failed')
        print('errorCode:', resp.errorCode)
        print('errorMessage:', resp.errorMessage)
except:
    print(traceback.format_exc())
