Obtaining the BPA Configuration of a Bucket (SDK for Python)
Function
This API returns the public access block configuration of an OBS bucket.
Restrictions
- To obtain the BPA configuration of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketPublicAccessBlock in IAM or GetBucketPublicAccessBlock in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
ObsClient.getBucketPublicAccessBlock(bucket)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
bucketName |
str |
Yes |
Explanation: Bucket name. Restrictions:
Default value: None |
extensionHeaders |
dict |
No |
Explanation: Extension headers. Value range: See User-defined Header (SDK for Python). Default value: None |
Responses
Type |
Description |
Explanation: SDK common results |
Parameter |
Type |
Description |
status |
int |
Explanation: HTTP status code Value range: A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
reason |
str |
Explanation: Reason description. Default value: None |
errorCode |
str |
Explanation: Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
errorMessage |
str |
Explanation: Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
requestId |
str |
Explanation: Request ID returned by the OBS server Default value: None |
indicator |
str |
Explanation: Error indicator returned by the OBS server. Default value: None |
hostId |
str |
Explanation: Requested server ID. If the value of status is less than 300, this parameter is left blank. Default value: None |
resource |
str |
Explanation: Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank. Default value: None |
header |
list |
Explanation: Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header. Default value: None |
body |
object |
Explanation: Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python). Default value: None |
GetResult.body Type |
Description |
object |
Explanation: CORS rule list of the bucket. For details, see Table 2. |
Parameter |
Type |
Description |
blockPublicAcls |
bool |
Explanation: Whether to block public ACLs. If this parameter is set to True, objects cannot be uploaded when the request includes a public ACL. Requests for modifying bucket or object ACLs fail if the requests include public ACLs. |
ignorePublicAcls |
bool |
Explanation: Whether to ignore public ACLs. If this parameter is set to True, the public ACL does not take effect during OpenAPI permissions checks. |
blockPublicPolicy |
bool |
Explanation: Whether to block the public policy. If this parameter is set to True, OBS rejects calls to modify bucket policies if the specified bucket policy allows public access. |
restrictPublicBuckets |
bool |
Explanation: Whether to restrict account access. If this parameter is set to True, only cloud service accounts and this account can access the bucket if a public bucket policy is found during the OpenAPI permissions check. |
Code Examples
This example obtains the PublicAccessBlock configuration of bucket examplebucket.
from obs import ObsClient import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: bucketName = "examplebucket" # Obtain the PublicAccessBlock configuration of the bucket. resp = obsClient.getBucketPublicAccessBlock(bucketName) # If status code 2xx is returned, the API was called successfully. Otherwise, the call failed. if resp.status < 300: print('Get Bucket PublicAccessBlock Succeeded') print('requestId:', resp.requestId) print('blockPublicAcls:', resp.body.blockPublicAcls) print('ignorePublicAcls:', resp.body.ignorePublicAcls) print('blockPublicPolicy:', resp.body.blockPublicPolicy) print('restrictPublicBuckets:', resp.body.restrictPublicBuckets) else: print('Get Bucket PublicAccessBlock Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Get Bucket PublicAccessBlock Failed') print(traceback.format_exc())
Feedback
Was this page helpful?
Chatbot
