Updated on 2025-05-09 GMT+08:00
Obtaining Object Metadata (SDK for Python)
Function
Object metadata is a set of name-value pairs that describe the object and is used for object management.
Currently, only the system-defined metadata can be obtained. System-defined metadata consists of system-controlled metadata and user-controlled metadata.
This API sends a HEAD request to obtain the metadata of an object in a specified bucket.
Restrictions
  • To obtain object metadata, you must be the bucket owner or have the required permission (obs:object:GetObject in IAM or GetObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
  • Users with the READ permission on objects can send HEAD requests to retrieve metadata from objects. The metadata of the objects is included in the response.
Method
ObsClient.getObjectMetadata(bucketName, objectKey, versionId, sseHeader, origin, requestHeaders, extensionHeaders)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
bucketName
str
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket properties comply with those set in the first creation request.
Default value:
None
objectKey
str
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
versionId
str
No
Explanation:
Object version ID, for example, G001117FCE89978B0000401205D5DC9A
Value range:
The value must contain 32 characters.
Default value:
None
origin
str
No
Explanation:
Origin of the cross-domain request specified by the preflight request. Generally, it is a domain name.
Restrictions:
You can configure one or more rules and use at most one wildcard character (*) in each rule. If you want to configure multiple rules, separate them using a line breaker.
Default value:
None
requestHeaders
str
No
Explanation:
HTTP headers in a cross-origin request Only CORS requests matching the allowed headers are valid.
Restrictions:
You can enter multiple allowed headers, with one separated from another using a line break. Each header can contain one wildcard character (*) at most. Spaces, ampersands (&), colons (:), and less-than signs (<) are not allowed.
Default value:
None
sseHeader
SseCHeader
No
Explanation:
Header for server-side decryption
Value range:
For details, see Table 2.
Default value:
None
extensionHeaders
dict
No
Explanation:
Extension headers.
Value range:
See User-defined Header (SDK for Python).
Default value:
None
Table 2 SseCHeader
Parameter
Type
Mandatory (Yes/No)
Description
encryption
str
Yes
Explanation:
SSE-C used for encrypting objects
Value range:
AES256
Default value:
None
key
str
Yes
Explanation:
Key used in SSE-C encryption. It corresponds to the encryption method. For example, if encryption is set to AES256, the key is calculated using the AES-256 algorithm.
Value range:
Default value:
None
Responses
Table 3 List of returned results
Type
Description
GetResult
Explanation:
SDK common results
Table 4 GetResult
Parameter
Type
Description
status
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
reason
str
Explanation:
Reason description.
Default value:
None
errorCode
str
Explanation:
Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
errorMessage
str
Explanation:
Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
requestId
str
Explanation:
Request ID returned by the OBS server
Default value:
None
indicator
str
Explanation:
Error indicator returned by the OBS server.
Default value:
None
hostId
str
Explanation:
Requested server ID. If the value of status is less than 300, this parameter is left blank.
Default value:
None
resource
str
Explanation:
Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank.
Default value:
None
header
list
Explanation:
Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header.
Default value:
None
body
object
Explanation:
Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python).
Default value:
None
Table 5 GetResult.body
GetResult.body Type
Description
GetObjectMetadataResponse
Explanation:
Response to the request for obtaining object metadata For details, see Table 6.
Table 6 GetObjectMetadataResponse
Parameter
Type
Description
storageClass
str
Explanation:
Object storage class.
Value range:
  • If the storage class is Standard, leave this parameter blank.
  • For details about the available storage classes, see Table 7.
Default value:
None
accessContorlAllowOrigin
str
Explanation:
If Origin in the request meets the CORS rules of the bucket, AllowedOrigin specified in the CORS rules is returned. AllowedOrigin indicates the origin from which requests can access the bucket.
Restrictions:
Domain name of the origin. Each origin can contain only one wildcard character (*), for example, https://*.vbs.example.com.
Default value:
None
accessContorlAllowHeaders
str
Explanation:
If RequestHeader in the request meets the CORS rules of the bucket, AllowedHeader specified in the CORS rules is returned. AllowedHeader indicates the allowed headers for cross-origin requests. Only CORS requests matching the allowed headers are valid.
Restrictions:
Each header can contain at most one wildcard character (*). Spaces, ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed.
Default value:
None
accessContorlAllowMethods
str
Explanation:
AllowedMethod in the CORS rules of the bucket. It specifies the HTTP method of cross-origin requests, that is, the operation type of buckets and objects.
Value range:
The following HTTP methods are supported:
  • GET
  • PUT
  • HEAD
  • POST
  • DELETE
Default value:
None
accessContorlExposeHeaders
str
Explanation:
ExposeHeader in the CORS rules of the bucket. It specifies the CORS-allowed additional headers in the response. These headers provide additional information to clients. By default, your browser can only access headers Content-Length and Content-Type. If your browser needs to access other headers, add them to a list of the allowed additional headers.
Restrictions:
Spaces, wildcard characters (*), ampersands (&), colons (:), and less-than signs (<) are not allowed.
Default value:
None
accessContorlMaxAge
int
Explanation:
MaxAgeSeconds in the CORS rules of the bucket. It specifies the time your client can cache the response for a cross-origin request.
Restrictions:
Each CORS rule can contain only one MaxAgeSeconds.
Value range:
An integer greater than or equal to 0, in seconds
Default value:
100
contentLength
int
Explanation:
Object size
Value range:
The value ranges from 0 TB to 48.8 TB, in bytes.
Default value:
None
contentType
str
Explanation:
MIME type of the file to be uploaded. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data.
Value range:
See What Is Content-Type (MIME)? (Python SDK)
Default value:
None
lastModified
str
Explanation:
Time when the last modification was made to the object
Restrictions:
The time must be in the GMT format, for example, Wed, 25 Mar 2020 02:39:52 GMT.
Default value:
None
etag
str
Explanation:
Base64-encoded, 128-bit MD5 value of an object. ETag is the unique identifier of the object contents and is used to determine whether the contents of an object are changed. For example, if the ETag value is A when an object is uploaded and is B when the object is downloaded, this indicates the contents of the object are changed. The ETag reflects changes only to the contents of an object, not its metadata. Objects created by the upload and copy operations have unique ETags after being encrypted using MD5.
Restrictions:
If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object.
Value range:
Default value:
None
versionId
str
Explanation:
Object version ID.
Value range:
Default value:
None
restore
str
Explanation:
Restore status of an object. This header is returned when an Archive object is being restored or has been restored.
For example, ongoing-request="true" indicates that the object is being restored. ongoing-request="false", expiry-date="Wed, 7 Nov 2012 00:00:00 GMT" indicates that the object has been restored. expiry-date indicates when the restored object expires.
Restrictions:
This parameter is only available for Archive objects.
Default value:
None
expiration
str
Explanation:
Expiration details. Example: "expiry-date=\"Mon, 11 Sep 2023 00:00:00 GMT\""
Default value:
None
sseKms
str
Explanation:
SSE-KMS is used for encrypting objects on the server side.
Value range:
kms
Default value:
None
sseKmsKey
str
Explanation:
ID of the KMS master key when SSE-KMS is used
Value range:
Valid value formats are as follows:
  1. regionID:domainID:key/key_id
  2. key_id
In the preceding formats:
Default value:
  • If this parameter is not specified, the default master key will be used.
  • If there is no such a default master key, the system will create one and use it by default.
sseC
str
Explanation:
SSE-C algorithm
Value range:
AES256
Default value:
None
sseCKeyMd5
str
Explanation:
MD5 value of the key for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key.
Restrictions:
The value is encrypted by MD5 and then encoded by Base64, for example, 4XvB3tbNTN+tIEVa0/fGaQ==.
Default value:
None
websiteRedirectLocation
str
Explanation:
If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. This parameter specifies the address the request for the object is redirected to.
The request is redirected to object anotherPage.html in the same bucket:
WebsiteRedirectLocation:/anotherPage.html
The request is redirected to an external URL http://www.example.com/:
WebsiteRedirectLocation:http://www.example.com/
OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation.
Restrictions:
  • The value must start with a slash (/), http://, or https:// and cannot exceed 2 KB.
  • OBS only supports redirection for objects in the root directory of a bucket.
Default value:
None
isAppendable
bool
Explanation:
Whether the object is appendable
Value range:
True: The object is appendable.
False: The object is not appendable.
Default value:
None
nextPosition
int
Explanation:
Start position for next appending
Value range:
0 to the object length, in bytes.
Default value:
None
Table 7 StorageClass
Parameter
Type
Description
STANDARD
Standard storage class
Explanation:
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
WARM
Infrequent Access storage class
Explanation:
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed.
COLD
Archive storage class
Explanation:
Used for storing rarely accessed (once a year) data.
You can obtain custom metadata from the response headers.
Code Examples
This example returns the metadata of object objectname.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
from obs import ObsClient
import os
import traceback
# Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage.
# Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
ak = os.getenv("AccessKeyID")
sk = os.getenv("SecretAccessKey")
# (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables.
# security_token = os.getenv("SecurityToken")
# Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use.
server = "https://obs.ap-southeast-1.myhuaweicloud.com"
# Create an obsClient instance.
# If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance.
obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server)
try:
    bucketName = "examplebucket"
    objectKey = "objectname"
    # Obtain object metadata.
    resp = obsClient.getObjectMetadata(bucketName, objectKey)
    # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails.
    if resp.status < 300:
        print('Get Object Metadata Succeeded')
        print('requestId:', resp.requestId)
        print('etag:', resp.body.etag)
        print('lastModified:', resp.body.lastModified)
        print('contentType:', resp.body.contentType)
        print('contentLength:', resp.body.contentLength)
    else:
        print('Get Object Metadata Failed')
        print('status:', resp.status)
        print('reason:', resp.reason)
except:
    print(traceback.format_exc())
