User-defined Header (SDK for Python)
Function
When calling an API, you can configure user-defined headers to meet specific needs. The SDK will automatically calculate the signature for the specified headers if needed.
Method:
You can add the specified headers in extensionHeaders in the dictionary format.
Restrictions
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Code Examples
This example configures user-defined headers to use the single-connection bandwidth throttling function for downloading object objectname from bucket examplebucket at a limited rate.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 |
from obs import ObsClient import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: bucketName = "examplebucket" objectKey = "objectname" # Configure the download rate limit by specifying x-obs-traffic-limit, in bits. The value range is from 819200 (100 KB) to 838860800 (100 MB). 819200 is used as an example. extensionHeaders = {'x-obs-traffic-limit': 819200} # Specify the full path (localfile as an example) to which objects are downloaded. The full path contains the local file name. downloadPath = 'localfile' # Download the object at a limited rate. resp = obsClient.getObject(bucketName, objectKey, downloadPath, extensionHeaders=extensionHeaders) # If status code 2xx is returned, the API was called successfully. Otherwise, the call failed. if resp.status < 300: print('Get Object Succeeded') print('requestId:', resp.requestId) print('url:', resp.body.url) else: print('Get Object Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Get Object Failed') print(traceback.format_exc()) |
This example configures a user-defined header to implement the upload callback.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 |
from obs import ObsClient import os import traceback from urllib.parse import quote import base64 import json # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: # Specify a protocol. protocol = 'http://' # Specify the callback address. If the URL contains any special characters or full-width characters, they must be URL-encoded using quote(str). callbackUrl1 = protocol + quote("www.example.com/callback1") callbackUrl2 = protocol + quote ("www.example.com/full-width-characters?key=object-name-in-full-width-characters") # (Optional) Specify the value of the host header carried in the callback request. If this parameter is not specified, the value of host parsed from callbackUrl is used. callbackHost = 'www.example.com' # Specify the body of the callback request. callbackBody = 'key=$(key)&override=$(override)&size=$(size)&bucket=$(bucket)&etag=$(etag)' # Configure the upload callback. callBackPolicy = {"callbackBody": callbackBody, "callbackUrl": callbackUrl1 + ';' + callbackUrl2, "callbackHost": callbackHost} # Configure the custom headers by specifying extensionHeaders. The input parameters are in the dictionary format. # Convert callBackPolicy to a JSON string and then to binary using json.dumps().encode(). Then, encode the results using Base64 (base64.b64encode()) and convert the encoded data which is in binary mode to a string using str(b'str', "utf-8"). extensionHeaders = {'x-obs-callback': str(base64.b64encode(json.dumps(callBackPolicy).encode()), "utf-8")} bucketName = 'your-bucketName' objectKey = 'example.txt' content = 'Hello OBS' # Upload the text and perform the upload callback. resp = obsClient.putContent(bucketName, objectKey, content, extensionHeaders=extensionHeaders) # If status code 2xx is returned, the API was called successfully. Otherwise, the call failed. if resp.status < 300: print('Put Content Succeeded') print('requestId:', resp.requestId) print('etag:', resp.body.etag) else: print('Put Content Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Put Content Failed') print(traceback.format_exc()) |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 |
from obs import ObsClient import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: bucketName = "examplebucket" objectKey = "objectname" # x-obs-expires indicates how many days after the last modification the object expires. This example configures 3 days. extensionHeaders = {'x-obs-expires': 3} # Configure the object metadata. resp = obsClient.setObjectMetadata(bucketName, objectKey, extensionHeaders=extensionHeaders) # If status code 2xx is returned, the API was called successfully. Otherwise, the call failed. if resp.status < 300: print('Set Object Metadata Succeeded') print('requestId:', resp.requestId) else: print('Set Object Metadata Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Set Object Metadata Failed') print(traceback.format_exc()) |
Helpful Links
Feedback
Was this page helpful?
Chatbot
