Updated on 2025-09-11 GMT+08:00
Configuring SLO Metrics
Scenarios
On this page, you can add, modify, delete, and view SLO metrics.
Metrics are classified into request SLIs and instance-based SLIs. After the configuration is complete, you can manually add the metrics in Viewing SLO Interruption Records.
Adding an SLO Metric
  1. Log in to COC.
  2. In the navigation pane, choose Basic Configurations > SLO Management.
  3. Locate the SLO metric you want to configure and click Configure Metric in the Operation column.
  4. Click Add SLI Metric.
  5. Set parameters for configuring an SLI.
    Table 1 Parameters for configuring an SLI
    Parameter
    Description
    Metric Type
    The options are Request SLI Metric and Instance SLI Metric.
    SLI Metric Name
    Specify an SLI name based on naming rules.
    SLI Metric Description
    Enter the detailed description of the SLI.
    Definition of Unavailable
    Select the comparison mode, parameter value, and parameter unit.
    The parameter is unavailable when it meets the conditions.
  6. Click OK.
  7. Click OK.
    The SLO metric is added.
Modifying an SLO Metric
  1. Log in to COC.
  3. Locate the SLO metric you want to configure and click Metric Configuration in the Operation column.
  4. Locate the metric you want to modify and click Modify in the Operation column.
    Table 2 Parameters for configuring an SLI
    Parameter
    Description
    Metric Type
    SLI Metric Name
  6. Click OK.
  7. Click OK.
    The SLO metric is modified.
Deleting an SLO Metric
  1. Log in to COC.
  4. Locate the metric you want to delete and click Modify in the Operation column.
  5. Click OK.
    The SLO metric is deleted.
