Updated on 2025-09-15 GMT+08:00
Previewing Objects
Scenarios
For security and compliance purposes, OBS prohibits the preview of objects in a bucket by using the default OBS domain name (a bucket domain name or static website domain name). When you use such a domain name to access objects (such as videos, images, and web pages) in a browser, no content will be displayed. Instead, the content is downloaded as an attachment.
To preview objects, you can use a user-defined domain name.
Solution 1: Use a User-Defined Domain Name
Solution 2: Use a User-Defined Domain Name and CDN
Solution 3: Use Private Bucket Retrieval on CDN
If you have bound a user-defined domain name to a bucket and enabled CDN acceleration, but the objects are still directly downloaded without object preview, handle the problem by referring to With CDN Acceleration Enabled, Why Are the Objects in My OBS Bucket Directly Downloaded When I Access Them?
This restriction takes effect in different regions at the following two points in time:
January 1, 2022: CN North-Beijing1, CN North-Beijing4, CN East-Shanghai1, CN East-Shanghai2, and CN South-Guangzhou
March 25, 2022: CN-Hong Kong, AP-Bangkok, AP-Singapore, AF-Johannesburg, LA-Mexico City1, LA-Mexico City2, LA-Sao Paulo1, AP-Jakarta, and LA-Santiago
