Help Center/
Data Lake Insight/
SQL Syntax Reference (ME-Abu Dhabi Region)/
Spark SQL Syntax Reference/
Built-in Functions/
Mathematical Functions/
e
Updated on 2025-01-22 GMT+08:00
e
This function is used to return the value of e.
Syntax
e()
Return Values
The return value is of the DOUBLE type.
Example Code
The value 2.718281828459045 is returned.
select e();
Parent topic: Mathematical Functions
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
