Updated on 2025-01-22 GMT+08:00
floor
This function is used to round down a to the nearest integer.
Syntax
floor(DOUBLE a)
Parameters
Table 1 Parameter
Parameter
Mandatory
Type
Description
a
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The value can be a float, integer, or string.
If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation.
Return Values
The return value is of the BIGINT type.
If the value of a is NULL, NULL is returned.
Example Code
The value 1 is returned.
select floor(1.2);
The value -2 is returned.
select floor(-1.2);
The value NULL is returned.
select floor(null);
