Help Center/
API Gateway/
User Guide (ME-Abu Dhabi Region)/
API Management/
Importing and Exorting APIs/
Extended Definition/
x-apigateway-request-type
Updated on 2024-10-09 GMT+08:00
Meaning: API request type, which can be public or private.
Scope of effect: Operation Object (2.0)/Operation Object (3.0)
Example:
paths: '/path': get: x-apigateway-request-type: 'public'
Parameter |
Mandatory |
Type |
Description |
x-apigateway-request-type |
Yes |
String |
API visibility. The options include public and private.
Parent topic: Extended Definition
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
