Help Center/
Distributed Message Service for RocketMQ/
User Guide (ME-Abu Dhabi Region)/
Managing Consumer Groups/
Viewing Consumer Connection Addresses
Updated on 2023-06-14 GMT+08:00
Scenario
View consumer connection addresses on the DMS for RocketMQ console.
A consumer's connection addresses can be viewed only when the consumer is connected to a RocketMQ instance.
Procedure
- Log in to the management console.
- Click
in the upper left corner to select a region.
Select the region where your RocketMQ instance is located.
- Click
and choose Application > Distributed Message Service for RocketMQ to open the console of DMS for RocketMQ.
- Click a RocketMQ instance to go to the instance details page.
- In the navigation pane on the left, choose Instance Diagnosis.
- For Consumer Group, select the group whose consumer connection address you want to view. Then click Start Diagnosis.
- Locate the row that contains the target diagnosis record, and click View.
- In the Results area, view the consumer connection address.
Figure 1 Consumer connection addresses
Parent topic: Managing Consumer Groups
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
