Updated on 2025-09-19 GMT+08:00
Delimiter Configuration
You can configure delimiters to split log content into words, so you can search for logs by these words. LTS has preconfigured the following delimiters:
, '";=()[]{}@&<>/:\n\t\r
If the default delimiters cannot meet your needs, you can set custom delimiters.
Precautions
Your custom delimiters are applicable only to the log events generated after the delimiters are configured.
Procedure
  1. Log in to the LTS console, choose Configuration Center in the navigation pane on the left, and click the Delimiters tab.
  2. Configure delimiters.
    You can configure delimiters in either of the following ways. If you use both ways, the delimiters configured in the two ways will all take effect.
    • Common Delimiters: Click Edit and enter delimiters in the text box.
    • ASCII Delimiters: Click Edit. On the displayed page, click Add ASCII Delimiter and enter ASCII values by referring to ASCII Table.
  3. Preview the parsing result.
    Enter log content in the text box and click Preview.
  4. Check whether the parsing result is correct. If it is correct, click Save.
    You can click Reset to restore the default delimiters, which include:
ASCII Table
Table 1 ASCII table
ASCII Value
Character
ASCII Value
Character
ASCII Value
Character
ASCII Value
Character
0
NUL (Null)
32
Space
64
96
1
SOH (Start of heading)
33
65
A
97
a
2
STX (Start of text)
34
66
B
98
b
3
ETX (End of text)
35
67
C
99
c
4
EOT (End of transmission)
36
68
D
100
d
5
ENQ (Enquiry)
37
69
E
101
e
6
ACK (Acknowledge)
38
70
F
102
f
7
BEL (Bell)
39
71
G
103
g
8
BS (Backspace)
40
72
H
104
h
9
HT (Horizontal tab)
41
73
I
105
i
10
LF (Line feed)
42
74
J
106
j
11
VT (Vertical tab)
43
75
K
107
k
12
FF (Form feed)
44
76
L
108
l
13
CR (Carriage return)
45
77
M
109
m
14
SO (Shift out)
46
78
N
110
n
15
SI (Shift in)
47
79
O
111
o
16
DLE (Data link escape)
48
0
80
P
112
p
17
DC1 (Device control 1)
49
1
81
Q
113
q
18
DC2 (Device control 2)
50
2
82
R
114
r
19
DC3 (Device control 3)
51
3
83
S
115
s
20
DC4 (Device control 4)
52
4
84
T
116
t
21
NAK (Negative acknowledge)
53
5
85
U
117
u
22
SYN (Synchronous idle)
54
6
86
V
118
v
23
ETB (End of transmission block)
55
7
87
W
119
w
24
CAN (Cancel)
56
8
88
X
120
x
25
EM (End of medium)
57
9
89
Y
121
y
26
SUB (Substitute)
58
90
Z
122
z
27
ESC (Escape)
59
91
123
28
FS (File separator)
60
92
124
29
GS (Group separator)
61
93
125
30
RS (Record separator)
62
94
126
31
US (Unit separator)
63
95
_
127
DEL (Delete)
