What Do I Do If I Do Not See a Host with ICAgent Installed?
If a host with ICAgent installed is not displayed on the Hosts tab page on the LTS console, perform the following steps:
Prerequisites
You have logged in to the LTS console.
Procedure
- When configuring ECS log ingestion, if the ECS is not displayed on the Hosts tab page after you install ICAgent on it:
- On the Install ICAgent page, ensure that the installation command is correctly copied. Do not use the installation command across regions.
- Ensure that the obtained AK/SK pair is correct and has not been deleted.
- Run the netstat -nap | grep icagent command to check whether the host network is proper.
- When configuring CCE log ingestion, if the CCE cluster is not displayed on the Hosts tab page after you install ICAgent on it:
Ensure that ICAgent has been installed in the CCE cluster and a host group with custom identifiers has been created for related nodes. If ICAgent has not been installed, upgrade it on the Host Management page.
Feedback
Was this page helpful?
Chatbot
