Help Center/
SecMaster/
User Guide (ME-Abu Dhabi Region)/
Security Situation/
Task Center/
Handling a To-Do Task
Updated on 2025-01-20 GMT+08:00
Scenario
When a playbook or process task reaches a node, the task needs to be suspended manually so that the playbook or process task can continue.
Process to-do tasks.
Prerequisites
A playbook task has been triggered, and manual actions are required for completing the task.
- Log in to the management console.
- Click
in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
.Figure 2 To-Dos
- In the row containing the target to-do task, click Approve in the Operation column.
The approval mode varies according to the service type.
- Playbook release: The Playbook Release page is displayed on the right. Enter review comments and approve the playbook as prompted.
- Process release: The Process Release page is displayed on the right. Enter the Comment and approve the application as prompted.
- Playbook-Node Review: The Playbook-Node Review page is displayed on the right. You can select Continue or Terminate.
Parent topic: Task Center
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
