Help Center/
Object Storage Service/
FAQs/
OBS Console/
OBS Console Couldn't Be Opened in Internet Explorer 9
Updated on 2025-08-04 GMT+08:00
Question
Why OBS Console cannot be opened in Internet Explorer 9, even if the address of OBS Console can be pinged?
Answer
Confirm whether Use SSL and Use TLS are selected in Internet Options. If not, do as follows and try again:
- Open Internet Explorer 9.
- Click Tools in the upper right corner and choose Internet Options > Advanced. Then select Use SSL 2.0, Use SSL 3.0, Use TLS 1.0, Use TLS 1.1, and Use TLS 1.2, as shown in Figure 1.
- Click OK.
Parent topic: OBS Console
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
