Help Center/ Object Storage Service/ SDK Reference/ Android/ Temporarily Authorized Access/ Using a Temporary URL for Authorized Access
Updated on 2025-05-16 GMT+08:00
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
ObsClient allows you to create a URL whose Query parameters are carried with authentication information by specifying the AK and SK, HTTP method, and request parameters. You can provide other users with this URL for temporary access. When generating a URL, you need to specify the validity period of the URL to restrict the access duration of visitors.
If you want to grant other users the permission to perform other operations on buckets or objects (for example, upload or download objects), generate a URL with the corresponding request (for example, to upload an object using the URL that generates the PUT request) and provide the URL for other users.
The following table lists operations can be performed through a signed URL.
Operation
HTTP Request Method (Value in OBS Android SDK)
Special Operator (Value in OBS Android SDK)
Bucket Name Required
Object Name Required
PUT Bucket
HttpMethodEnum.PUT
N/A
Yes
No
GET Buckets
HttpMethodEnum.GET
N/A
No
No
DELETE Bucket
HttpMethodEnum.DELETE
N/A
Yes
No
GET Objects
HttpMethodEnum.GET
N/A
Yes
No
GET Object versions
HttpMethodEnum.GET
SpecialParamEnum.VERSIONS
Yes
No
List Multipart uploads
HttpMethodEnum.GET
SpecialParamEnum.UPLOADS
Yes
No
Obtain Bucket Metadata
HttpMethodEnum.HEAD
N/A
Yes
No
GET Bucket location
HttpMethodEnum.GET
SpecialParamEnum.LOCATION
Yes
No
GET Bucket storageinfo
HttpMethodEnum.GET
SpecialParamEnum.STORAGEINFO
Yes
No
PUT Bucket quota
HttpMethodEnum.PUT
SpecialParamEnum.QUOTA
Yes
No
GET Bucket quota
HttpMethodEnum.GET
Yes
No
Set Bucket storagePolicy
HttpMethodEnum.PUT
SpecialParamEnum.STORAGEPOLICY
Yes
No
GET Bucket storagePolicy
HttpMethodEnum.GET
Yes
No
Configure Bucket ACL
HttpMethodEnum.PUT
SpecialParamEnum.ACL
Yes
No
Obtain Bucket ACL
HttpMethodEnum.GET
Yes
No
PUT Bucket logging
HttpMethodEnum.PUT
SpecialParamEnum.LOGGING
Yes
No
GET Bucket logging
HttpMethodEnum.GET
Yes
No
PUT Bucket policy
HttpMethodEnum.PUT
SpecialParamEnum.POLICY
Yes
No
GET Bucket policy
HttpMethodEnum.GET
Yes
No
DELETE Bucket policy
Yes
No
PUT Bucket lifecycle
HttpMethodEnum.PUT
SpecialParamEnum.LIFECYCLE
Yes
No
GET Bucket lifecycle
HttpMethodEnum.GET
Yes
No
DELETE Bucket lifecycle
Yes
No
PUT Bucket website
HttpMethodEnum.PUT
SpecialParamEnum.WEBSITE
Yes
No
GET Bucket website
HttpMethodEnum.GET
Yes
No
DELETE Bucket website
Yes
No
PUT Bucket versioning
HttpMethodEnum.PUT
SpecialParamEnum.VERSIONING
Yes
No
GET Bucket versioning
HttpMethodEnum.GET
Yes
No
PUT Bucket cors
HttpMethodEnum.PUT
SpecialParamEnum.CORS
Yes
No
GET Bucket cors
HttpMethodEnum.GET
Yes
No
DELETE Bucket cors
Yes
No
PUT Bucket tagging
HttpMethodEnum.PUT
SpecialParamEnum.TAGGING
Yes
No
GET Bucket tagging
HttpMethodEnum.GET
Yes
No
DELETE Bucket tagging
Yes
No
PUT Object
HttpMethodEnum.PUT
N/A
Yes
Yes
Append Object
HttpMethodEnum.POST
SpecialParamEnum.APPEND
Yes
Yes
GET Object
HttpMethodEnum.GET
N/A
Yes
Yes
PUT Object - Copy
HttpMethodEnum.PUT
N/A
Yes
Yes
DELETE Object
N/A
Yes
Yes
DELETE Objects
HttpMethodEnum.POST
SpecialParamEnum.DELETE
Yes
Yes
Obtain Object Metadata
HttpMethodEnum.HEAD
N/A
Yes
Yes
Configure Object ACL
HttpMethodEnum.PUT
Yes
Yes
Obtain Object ACL
HttpMethodEnum.GET
Yes
Yes
Initiate Multipart Upload
HttpMethodEnum.POST
Yes
Yes
PUT Part
HttpMethodEnum.PUT
N/A
Yes
Yes
PUT Part - Copy
HttpMethodEnum.PUT
N/A
Yes
Yes
List Parts
HttpMethodEnum.GET
N/A
Yes
Yes
Complete Multipart Upload
HttpMethodEnum.POST
N/A
Yes
Yes
DELETE Multipart upload
N/A
Yes
Yes
POST Object restore
HttpMethodEnum.POST
SpecialParamEnum.RESTORE
Yes
Yes
To access OBS using a temporary URL generated by the OBS Android SDK, perform the following steps:
  1. Call ObsClient.createTemporarySignature to generate a signed URL.
  2. Use any HTTP library to make an HTTP/HTTPS request to OBS.
If a CORS or signature mismatch error occurs, refer to the following steps to troubleshoot the issue:
  1. If CORS has not been configured, you need to first configure CORS rules on the console. For details, see Configuring CORS.
  2. If the signatures do not match, check whether signature parameters are correct by referring to Authentication of Signature in a URL. For example, during an object upload, the backend uses Content-Type to calculate the signature and generate an authorized URL, but if Content-Type is not set or set wrongly when the frontend uses the authorized URL, there will be a CORS error. To address this issue, ensure that Content-Type fields at the frontend and backend are consistent.
The following content provides examples of accessing OBS using a temporary URL, including bucket creation, as well as object upload, download, listing, and deletion.
Creating a Bucket
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
String ak = System.getenv("ACCESS_KEY_ID");
String sk = System.getenv("SECRET_ACCESS_KEY_ID");
String endPoint = "https://your-endpoint";
// Create an ObsClient instance.
ObsClient obsClient = new ObsClient(ak, sk, endPoint);
// Specify the validity period of the URL to 3600 seconds.
long expireSeconds = 3600L;
TemporarySignatureRequest request = new TemporarySignatureRequest(HttpMethodEnum.PUT, expireSeconds);
request.setBucketName("bucketname");
TemporarySignatureResponse response = obsClient.createTemporarySignature(request);
Log.i("CreateTemporarySignature", "Creating bucket using temporary signature url:");
Log.i("CreateTemporarySignature", "\t" + response.getSignedUrl());
Request.Builder builder = new Request.Builder();
for (Map.Entry<String, String> entry : response.getActualSignedRequestHeaders().entrySet()) {
       builder.header(entry.getKey(), entry.getValue());
// Make a PUT request to create a bucket.
String location = "your bucket location";
Request httpRequest = builder.url(response.getSignedUrl()).put(RequestBody.create(null, "<CreateBucketConfiguration><LocationConstraint>" + location + "</LocationConstraint></CreateBucketConfiguration>".getBytes())).build();
OkHttpClient httpClient = new OkHttpClient.Builder().followRedirects(false).retryOnConnectionFailure(false)
              .cache(null).build();
Call c = httpClient.newCall(httpRequest);
Response res = c.execute();
Log.i("CreateTemporarySignature", "\tStatus:" + res.code());
if (res.body() != null) {
       Log.i("CreateTemporarySignature", "\tContent:" + res.body().string() + "\n");
res.close();
Uploading an Object
Map<String, String> headers = new HashMap<String, String>();
String contentType = "text/plain";
headers.put("Content-Type", contentType);
request.setObjectKey("objectname");
request.setHeaders(headers);
Log.i("CreateTemporarySignature", "Creating object using temporary signature url:");
//Make a PUT request to upload an object.
Request httpRequest = builder.url(response.getSignedUrl()).put(RequestBody.create(MediaType.parse(contentType), "Hello OBS".getBytes("UTF-8"))).build();
res.close();
Downloading an Object
TemporarySignatureRequest request = new TemporarySignatureRequest(HttpMethodEnum.GET, expireSeconds);
Log.i("CreateTemporarySignature", "Getting object using temporary signature url:");
//Make a GET request to download an object.
Request httpRequest = builder.url(response.getSignedUrl()).get().build();
res.close();
Listing Objects
Log.i("CreateTemporarySignature", "Getting object list using temporary signature url:");
//Make a GET request to obtain the object list.
res.close();
Deleting an Object
TemporarySignatureRequest request = new TemporarySignatureRequest(HttpMethodEnum.DELETE, expireSeconds);
Log.i("CreateTemporarySignature", "Deleting object using temporary signature url:");
//Make a DELETE request to delete an object.
Request httpRequest = builder.url(response.getSignedUrl()).delete().build();
res.close();
HttpMethodEnum is an enumeration function defined in OBS Android SDK, whose value indicates the request method types.
