Help Center/
Object Storage Service/
SDK Reference/
Android/
Troubleshooting/
SDK Common Response Headers
Updated on 2023-11-09 GMT+08:00
After you call an API in an instance of ObsClient, an instance of the HeaderResponse class (or of its sub-class) will be returned. It contains information about HTTP/HTTPS response headers.
Sample code for processing public response headers:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); String endPoint = "https://your-endpoint"; // Create an instance of ObsClient. ObsClient obsClient = new ObsClient(ak, sk, endPoint); HeaderResponse response = obsClient.createBucket("bucketname"); // Obtain the UUID from the public response headers. Log.i("CreateBucket", "\t" + response.getRequestId()); obsClient.close();
Parent topic: Troubleshooting
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
