Help Center/
Object Storage Service/
SDK Reference/
BrowserJS/
Quick Start/
Initializing an Instance of ObsClient
Updated on 2024-04-26 GMT+08:00
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
Each time you want to send an HTTP/HTTPS request to OBS, you must create an instance of ObsClient. Sample code is as follows:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); // Use the instance to access OBS.
- For more information, see chapter "Initialization."
- For details about logging configuration, see Configuring SDK Logging.
Parent topic: Quick Start
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
