Performing a File-Based Download
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
This example downloads object objectname from bucket bucketname as file.
The example code is as follows:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); obsClient.getObject({ Bucket : 'bucketname', Key : 'objectname', SaveByType : 'file' }, function (err, result) { if(err){ console.error('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); if(result.CommonMsg.Status < 300 && result.InterfaceResult){ // Obtain the download path of the file. console.log('Download Path:'); console.log(result.InterfaceResult.Content.SignedUrl); } } });
- Set the SaveByType parameter to file to generate the path for saving the to-be-downloaded file.
Feedback
Was this page helpful?
Chatbot
