Copying an Object
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
The object copy operation can create a copy for an existing object in OBS.
You can call ObsClient.copyObject to copy an object. When copying an object, you can specify properties and ACL for it.
- If the source object to be copied is in the Archive storage class, you must restore it first.
Copying an Object Directly
Sample code:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); obsClient.copyObject({ Bucket: 'destbucketname', Key : 'destobjectname', CopySource:'sourcebucketname/sourceobjectname' }, function (err, result) { if(err){ console.log('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } });
Use the CopySource parameter to specify the information about the source object.
Rewriting Object Properties
The following sample code shows how to rewrite object properties.
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); obsClient.copyObject({ Bucket: 'destbucketname', Key : 'destobjectname', CopySource:'sourcebucketname/sourceobjectname', ContentType : 'image/jpeg', StorageClass : obsClient.enums.StorageClassWarm, Metadata:{'property':'property-value'}, MetadataDirective : ObsClient.enums.ReplaceMetadata }, function (err, result) { if(err){ console.log('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } });
Use the Metadata parameter to specify the object's customized metadata to be rewritten and the MetadataDirective parameter to specify the rewrite mode, which can be ObsClient.enums.ReplaceMetadata (rewrite) or ObsClient.enums.CopyMetadata (copy from the source object).
Copying an Object by Specifying Conditions
When copying an object, you can specify one or more restriction conditions. If the conditions are met, the object will be copied. Otherwise, the copy will fail with an error code returned.
You can set the following conditions:
Parameter |
Description |
Format |
CopySourceIfModifiedSince |
Copies the source object if it has been modified since the specified time; otherwise, an exception is thrown. |
This parameter must conform to the HTTP time format specified in http://www.ietf.org/rfc/rfc2616.txt. |
CopySourceIfUnmodifiedSince |
Copies the source object if it has not been modified since the specified time; otherwise, an exception is thrown. |
CopySourceIfMatch |
Copies the source object if its ETag is the same as the one specified by this parameter; otherwise, an error code is returned. |
Character string |
CopySourceIfNoneMatch |
Copies the source object if its ETag is different from the one specified by this parameter; otherwise, an error code is returned. |
Character string |
- The ETag of the source object is the MD5 check value of the source object.
- If the object copy request includes CopySourceIfUnmodifiedSince, CopySourceIfMatch, CopySourceIfModifiedSince, or CopySourceIfNoneMatch, and the specified condition is not met, the object copy will fail with error code 412 Precondition Failed returned.
- CopySourceIfModifiedSince and CopySourceIfNoneMatch can be used together. So do CopySourceIfUnmodifiedSince and CopySourceIfMatch.
Sample code:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); obsClient.copyObject({ Bucket: 'destbucketname', Key : 'destobjectname', CopySource:'sourcebucketname/sourceobjectname', CopySourceIfModifiedSince : 'Thu, 31 Dec 2015 16:00:00 GMT', CopySourceIfNoneMatch : 'none-match-etag' }, function (err, result) { if(err){ console.log('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } });
Rewriting an Object ACL
Sample code:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); obsClient.copyObject({ Bucket: 'destbucketname', Key : 'destobjectname', CopySource:'sourcebucketname/sourceobjectname', // Rewrite the object ACL to public read during the copy. ACL : obsClient.enums.AclPublicRead }, function (err, result) { if(err){ console.log('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } });
Use the ACL parameter to rewrite the object ACL.
Feedback
Was this page helpful?
Chatbot
