Updated on 2024-04-26 GMT+08:00
Setting Bucket Tags
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.setBucketTagging to set bucket tags. Sample code is as follows:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); obsClient.setBucketTagging({ Bucket: 'bucketname', Tags :[{Key:'tag1',Value:'value1'}, {Key:'tag2',Value:'value2'}] }, function (err, result) { if(err){ console.log('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } });
- Use the TagSet parameter to specify tags for a bucket.
- A bucket can have up to 10 tags.
- The key and value of a tag can be composed of Unicode characters.
Parent topic: Tag Management
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
