Updated on 2025-05-12 GMT+08:00
Downloading an Object - Range-Based (SDK for Go)
Function
This API downloads partial data of an object by specifying a range. If the specified range is from 0 to 1,000, data at the 0th to the 1,000th bytes, 1,001 bytes in total, will be returned. If the specified range is invalid, the whole object data will be returned.
Restrictions
  • To download an object, you must be the bucket owner or have the required permission (obs:object:GetObject in IAM or GetObject in a bucket policy).
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
  • Objects in the Archive storage class can be downloaded only when they are in the Restored status.
  • If the specified range is invalid (for example, the start or end position is set to a negative integer or the range is larger than the object length), the whole object data will be returned.
  • This download method also can be used to concurrently download parts of a large object. For details about the sample code, see concurrent_download_object_sample.
Method
func (obsClient ObsClient) GetObject(input *GetObjectInput) (output *GetObjectOutput, err error)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
input
*GetObjectInput
Yes
Explanation:
Input parameters for a partial download. For details, see Table 2.
Table 2 GetObjectInput
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Key
string
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
ResponseCacheControl
string
No
Explanation:
Cache-Control header in the response. It specifies the cache behavior of the web page when the object is downloaded.
Default value:
None
ResponseContentDisposition
string
No
Explanation:
Content-Disposition header in the response. It specifies the name of the object when it is downloaded.
Default value:
None
ResponseContentEncoding
string
No
Explanation:
Content-Encoding header in the response. It specifies the content encoding format when an object is downloaded.
Default value:
None
ResponseContentLanguage
string
No
Explanation:
Content-Language header in the response. It specifies the content language format when an object is downloaded.
Default value:
None
ResponseContentType
string
No
Explanation:
Content-Type header in the response. It specifies the object file type.
Default value:
None
ResponseExpires
string
No
Explanation:
Expires header in the response. It specifies the cache expiration time of the web page when the object is downloaded.
Default value:
None
VersionId
string
No
Explanation:
Object version ID. Example: G001117FCE89978B0000401205D5DC9
Value range:
The value must contain 32 characters.
Default value:
None. If this parameter is left blank, the latest version of the object is obtained.
ImageProcess
string
No
Explanation:
Image processing command or style. Example for resizing and rotating an image: image/resize,m_fixed,w_100,h_100/rotate,90
Value range:
Command format: image/commands
Style format: style/style name
For details about image processing parameters, see Processing Images.
Default value:
If no commands are entered, the original image is returned.
RangeStart
int64
No
Explanation:
Start position for object download
Value range:
0 to the object length, in bytes.
Default value:
0, indicating the download starts from the first byte of the object.
RangeEnd
int64
No
Explanation:
End position for object download
Value range:
  • The value must be greater than that of RangeStart.
  • The upper limit of the value is the object length minus 1, in bytes.
Default value:
None
IfMatch
string
No
Explanation:
Preset ETag. If the ETag of the object to be downloaded is the same as the preset ETag, the object is returned. Otherwise, an error is returned.
Value range:
Default value:
None
IfNoneMatch
string
No
Explanation:
Preset ETag. If the ETag of the object to be downloaded is different from the preset ETag, the object is returned. Otherwise, an error is returned.
Value range:
Default value:
None
IfModifiedSince
time.Time
No
Explanation:
The object is returned if it has been modified since the specified time; otherwise, an error is returned.
Restrictions:
The time must be in the ISO8601 format, for example, 2018-01-01T00:00:00.000Z.
Sample code: time.Now().Add(time.Duration(24) * time.Hour)
Default value:
None
IfUnmodifiedSince
time.Time
No
Explanation:
The object is returned if it has not been modified since the specified time; otherwise, an error is returned.
Restrictions:
Default value:
None
SseHeader
SseCHeader
No
Explanation:
Server-side decryption headers. For details, see Table 3.
Restrictions:
If the object uploaded to a server is encrypted with the key provided by the client, the key must also be provided in the message for downloading the object.
Table 3 SseCHeader
Parameter
Type
Mandatory (Yes/No)
Description
Encryption
string
Yes if used as a request parameter
Explanation:
SSE-C used for encrypting objects
Value range:
AES256, indicating objects are encrypted using SSE-C
Default value:
None
Key
string
Explanation:
Key for encrypting the object when SSE-C is used
Restrictions:
The value is a Base64-encoded 256-bit key, for example, K7QkYpBkM5+hca27fsNkUnNVaobncnLht/rCB2o/9Cw=.
Default value:
None
KeyMD5
string
No if used as a request parameter
Explanation:
MD5 value of the key for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key.
Restrictions:
The value is encrypted by MD5 and then encoded by Base64, for example, 4XvB3tbNTN+tIEVa0/fGaQ==.
Default value:
None
Responses
Table 4 List of returned results
Parameter
Type
Description
output
*GetObjectOutput
Explanation:
Returned results. For details, see Table 5.
err
error
Explanation:
Error messages returned by the API
Table 5 GetObjectOutput
Parameter
Type
Description
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
Body
io.ReadCloser
Explanation:
Object data stream to download
Default value:
None
DeleteMarker
bool
Explanation:
Whether the deleted object is a delete marker
Value range:
  • true: The deleted object is a delete marker.
  • false: The deleted object is not a delete marker.
Default value:
false
StorageClass
StorageClassType
Explanation:
Object storage class
Value range:
See Table 6.
Default value:
None
AllowOrigin
string
Explanation:
If Origin in the request meets the CORS rules of the bucket, AllowedOrigin specified in the CORS rules is returned. AllowedOrigin indicates the origin from which the requests can access the bucket.
Restrictions:
Domain name of the origin. Each origin can contain only one wildcard character (*), for example, https://*.vbs.example.com.
Default value:
None
AllowHeader
string
Explanation:
If RequestHeader in the request meets the CORS rules of the bucket, AllowedHeader specified in the CORS rules is returned. AllowedHeader indicates the allowed headers for cross-origin requests. Only CORS requests matching the allowed headers are valid.
Restrictions:
Each header can contain only one wildcard character (*). Spaces, ampersands (&), colons (:), and less-than signs (<) are not allowed.
Default value:
None
AllowMethod
string
Explanation:
AllowedMethod in the CORS rules of the bucket. It specifies the HTTP method of cross-origin requests, that is, the operation type of buckets and objects.
Value range:
The following HTTP methods are supported:
  • GET
  • PUT
  • HEAD
  • POST
  • DELETE
Default value:
None
ExposeHeader
string
Explanation:
ExposeHeader in the CORS rules of the bucket. It specifies the CORS-allowed additional headers in the response. These headers provide additional information to clients. By default, your browser can only access headers Content-Length and Content-Type. If your browser needs to access other headers, add them to a list of the allowed additional headers.
Restrictions:
Spaces, wildcard characters (*), ampersands (&), colons (:), and less-than signs (<) are not allowed.
Default value:
None
MaxAgeSeconds
int
Explanation:
MaxAgeSeconds in the CORS rules of the bucket. It specifies the time your client can cache the response for a cross-origin request.
Restrictions:
Each CORS rule can specify only one value for MaxAgeSeconds.
Value range:
0 to (231 – 1), in seconds
Default value:
100
ContentLength
int64
Explanation:
Object size in bytes
Value range:
The value ranges from 0 TB to 48.8 TB, in bytes.
Default value:
None
CacheControl
string
Explanation:
Cache-Control header in the response. It specifies cache behaviors of the web page when an object is downloaded.
Default value:
None
ContentDisposition
string
Explanation:
Default value:
None
ContentEncoding
string
Explanation:
Default value:
None
ContentLanguage
string
Explanation:
Default value:
None
ContentType
string
Explanation:
MIME type of the file to be downloaded. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data.
Value range:
See What Is Content-Type (MIME)?
Default value:
If you do not specify this parameter when uploading an object, the SDK determines the object type based on the suffix of the specified object name and automatically assigns a value to this parameter.
Expires
string
Explanation:
Default value:
None
LastModified
time.Time
Explanation:
Time when the last modification was made to the object
Restrictions:
Default value:
None
ETag
string
Explanation:
Base64-encoded, 128-bit MD5 value of an object. ETag is the unique identifier of the object content. It can be used to determine whether the object content is changed. For example, if the ETag value is A when an object is uploaded, but changes to B when the object is downloaded, it indicates that the object content has been changed. The ETag reflects changes to the object content, rather than the object metadata. An uploaded or copied object has a unique ETag after being encrypted using MD5.
Restrictions:
If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object.
Value range:
Default value:
None
VersionId
string
Explanation:
Object version ID
Value range:
Default value:
None
Restore
string
Explanation:
Restore status of an object. For an Archive object that is being restored or has been restored, this header is returned.
For example, ongoing-request="true" indicates that the object is being restored. ongoing-request="false", expiry-date="Wed, 7 Nov 2012 00:00:00 GMT" indicates that the object has been restored. expiry-date indicates when the restored object expires.
Restrictions:
This parameter is only available for Archive objects.
Default value:
None
Expiration
string
Explanation:
Expiration details of the object. Example: "expiry-date=\"Mon, 11 Sep 2023 00:00:00 GMT\""
Default value:
None
SseHeader
SseCHeader or SseKmsHeader
Explanation:
Server-side encryption header information. If SSE-C is used, see Table 7. If SSE-KMS is used, see Table 8.
WebsiteRedirectLocation
string
Explanation:
If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. This parameter specifies the address the request for the object is redirected to.
The request is redirected to object anotherPage.html in the same bucket:
WebsiteRedirectLocation:/anotherPage.html
The request is redirected to an external URL http://www.example.com/:
WebsiteRedirectLocation:http://www.example.com/
OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation.
Restrictions:
  • The value must start with a slash (/), http://, or https:// and cannot exceed 2 KB.
  • OBS only supports redirection for objects in the root directory of a bucket.
Default value:
None
Metadata
map[string]string
Explanation:
Custom object metadata. You can add a header starting with x-obs-meta- in the request to define metadata. The custom metadata will be returned in the response when you retrieve the object or query the object metadata.
Restrictions:
  • The custom metadata cannot exceed 8 KB. To measure the custom metadata, sum the number of bytes in the UTF-8 encoding of each key and value.
  • The custom metadata keys are case insensitive, but are stored in lowercase in OBS. The key values are case sensitive.
  • Both custom metadata keys and their values must conform to US-ASCII standards. If non-ASCII or unrecognizable characters are required, they must be encoded and decoded in URL or Base64 on the client, because the server does not perform such operations.
Default value:
None
Table 6 StorageClassType
Constant
Default Value
Description
StorageClassStandard
STANDARD
OBS Standard
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
StorageClassWarm
WARM
OBS Infrequent Access
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed.
StorageClassCold
COLD
OBS Archive
Used for storing rarely accessed (once a year) data.
Table 7 SseCHeader
Parameter
Type
Mandatory (Yes/No)
Description
Encryption
string
Explanation:
Value range:
Default value:
None
Key
string
Explanation:
Restrictions:
Default value:
None
KeyMD5
string
Explanation:
Restrictions:
Default value:
None
Table 8 SseKmsHeader
Parameter
Type
Mandatory (Yes/No)
Description
Encryption
string
Explanation:
SSE-KMS used for encrypting objects
Value range:
kms, indicating objects are encrypted using SSE-KMS
Default value:
None
Key
string
Explanation:
ID of the KMS master key when SSE-KMS is used
Value range:
Valid value formats are as follows:
  1. regionID:domainID:key/key_id
  2. key_id
In the preceding formats:
Default value:
  • If this parameter is not specified, the default master key will be used.
  • If there is no such a default master key, OBS will create one and use it by default.
Code Examples
This example downloads part (length range: 0-1,000 bytes) of example/objectname from examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.GetObjectInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify the object (example/objectname as an example) to download.
    input.Key = "example/objectname"
    // Specify a range.
    input.RangeStart = 0
    input.RangeEnd = 1000
    // Download the specified part of the object.
    output, err := obsClient.GetObject(input)
    if err == nil {
        // Close output.Body after using it, to avoid connection leakage.
        defer output.Body.Close()
        fmt.Printf("Get object(%s) under the bucket(%s) successful!\n", input.Key, input.Bucket)
        fmt.Printf("StorageClass:%s, ETag:%s, ContentType:%s, ContentLength:%d, LastModified:%s\n",
            output.StorageClass, output.ETag, output.ContentType, output.ContentLength, output.LastModified)
        // Read the object content.
        p := make([]byte, 1024)
        var readErr error
        var readCount int
        for {
            readCount, readErr = output.Body.Read(p)
            if readCount > 0 {
                fmt.Printf("%s", p[:readCount])
            if readErr != nil {
                break
        return
    fmt.Printf("List objects under the bucket(%s) fail!\n", input.Bucket)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
