Help Center/ Object Storage Service/ SDK Reference/ Go/ FAQ (SDK for Go)/ How Do I Specify Content-SHA256?
Updated on 2024-06-21 GMT+08:00
You can upload the x-obs-content-sha256 header when uploading an object or a part. The value of this header is the hexadecimal value converted from the SHA256 value of the request body and is calculated from Hex(SHA256Hash(<payload>). The server calculates and verifies the SHA256 value of the message body in the request with x-obs-content-sha256 included, which may make performance deteriorate, but is recommended for security purposes. Sample code is as follows:
This example deletes the asynchronous fetch policy of bucket examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
package main
import (
    "crypto/sha256"
    "fmt"
    "io"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func sha256File(path string) string {
    file, err := os.Open(path) // Open the file for reading
    if err != nil {
        panic(err)
    defer file.Close() // Be sure to close your file!
    hash := sha256.New() // Use the Hash in crypto/sha256
    if _, err := io.Copy(hash, file); err != nil {
        panic(err)
    return fmt.Sprintf("%x", hash.Sum(nil))
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint, obs.WithSecurityToken(securityToken), obs.WithSignature(obs.SignatureObs))
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.PutObjectInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify the object (example/objectname as an example) to download.
    input.Key = "example/objectname"
    filePath := "localfile"
    fd, _ := os.Open(filePath)
    defer fd.Close()
    input.Body = fd
    // Upload you local file using streaming.
    output, err := obsClient.PutObject(input, obs.WithCustomHeader("x-obs-content-sha256", sha256File(filePath)))
    if err == nil {
        fmt.Printf("Put object(%s) under the bucket(%s) successful!\n", input.Key, input.Bucket)
        fmt.Printf("StorageClass:%s, ETag:%s\n",
            output.StorageClass, output.ETag)
        return
    fmt.Printf("Put object(%s) under the bucket(%s) fail!\n", input.Key, input.Bucket)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
OBS SDK for Go supports integrity check with both MD5 and SHA256 (SHA256 is recommended for security purposes).
