Help Center/ Object Storage Service/ SDK Reference/ Go/ Buckets (SDK for Go)/ Listing Objects in a Bucket (SDK for Go)
Updated on 2025-05-12 GMT+08:00
Function
This API lists some or all of the objects in a bucket. You can use parameters such as the prefix, number of returned objects, and start position to list objects that meet specified criteria. The listed objects are ordered alphabetically using the object name.
Restrictions
Method
func (obsClient ObsClient) ListObjects(input *ListObjectsInput) (output *ListObjectsOutput, err error)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
input
*ListObjectsInput
Yes
Explanation:
Input parameters for listing objects in a bucket. For details, see Table 2.
Table 2 ListObjectsInput
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Marker
string
No
Explanation:
Object name to start with when listing objects in a bucket. All objects following this parameter are listed in alphabetical order.
Restrictions:
This parameter is only used for listing objects with a single version.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
Prefix
string
No
Explanation:
Name prefix that the objects to be listed must contain
Assume that you have the following objects: logs/day1, logs/day2, logs/day3, and ExampleObject.jpg. If you specify logs/ as the prefix, logs/day1, logs/day2, and logs/day3 will be returned. If you leave this parameter blank, all objects in the bucket will be returned.
Value range:
Default value:
None
MaxKeys
int
No
Explanation:
The maximum number of objects returned in the response in alphabetical order
Value range:
The value ranges from 1 to 1000. If the specified value is beyond this range, only 1,000 objects are returned.
Default value:
1000
Delimiter
string
No
Explanation:
Object names are grouped by this parameter, which is often used with Prefix. If a prefix is specified, objects with the same string from the prefix to the first delimiter are grouped into one CommonPrefixes. If no prefix is specified, objects with the same string from the first character to the first delimiter are grouped into one CommonPrefixes.
Assume that a bucket has objects abcd, abcde, and bbcde in it. If delimiter is set to d and prefix is set to a, objects abcd and abcde are grouped into a CommonPrefixes with abcd as the prefix. If only delimiter is set to d, objects abcd and abcde are grouped into a CommonPrefixes with abcd as the prefix, and bbcde is grouped separately into another CommonPrefixes with bbcd as the prefix.
For a parallel file system, if this parameter is not specified, all the content in the current directory is recursively listed by default, and subdirectories are also listed. In big data scenarios, parallel file systems usually have deep directory levels and each directory has a large number of files. In such case, you are advised to configure [delimiter=/] to list the content in the current directory, but not list subdirectories, thereby improving the listing efficiency.
Value range:
Default value:
None
EncodingType
string
No
Explanation:
Encoding method that is applied to some elements in the response. If Delimiter, Marker, Prefix, CommonPrefixes, NextMarker, and Key contain control characters (special characters) that are not supported by the XML 1.0 standard, set this parameter to url.
Value range:
url
Default value:
None. If you leave this parameter blank, encoding is not applied to elements.
Responses
Table 3 List of returned results
Parameter
Type
Description
output
*ListObjectsOutput
Explanation:
Returned parameters for listing objects in a bucket. For details, see Table 4.
err
error
Explanation:
Error messages returned by the API
Table 4 ListObjectsOutput
Parameter
Type
Description
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
Location
string
Explanation:
Region where a bucket is located
Restrictions:
If the used endpoint is obs.myhuaweicloud.com, this parameter is not required. If any other endpoint is used, this parameter is required.
Value range:
To learn about valid regions and endpoints, see Regions and Endpoints. An endpoint is the request address for calling an API. Endpoints vary depending on services and regions. To obtain the regions and endpoints, contact the enterprise administrator.
Default value:
If obs.myhuaweicloud.com is used as the endpoint and no region is specified, cn-north-1 (the CN North-Beijing1 region) is used by default.
Name
string
Explanation:
Bucket name
Restrictions:
  • A bucket name:
Value range:
The value must contain 3 to 63 characters.
Prefix
string
Explanation:
Object name prefix, which is consistent with that set in the request
Value range:
Default value:
None
Marker
string
Explanation:
Object name to start with for listing objects Object name to start with when listing objects in a bucket. All objects following this parameter are listed in alphabetical order.
Restrictions:
Value range:
Default value:
None
Delimiter
string
Explanation:
Value range:
Default value:
None
MaxKeys
int
Explanation:
Maximum number of listed objects, which is consistent with that set in the request The maximum number of objects returned in the response in alphabetical order
Value range:
Default value:
1000
IsTruncated
bool
Explanation:
Whether all results are returned in the response. A maximum of 1,000 objects can be listed at a time. If the number of objects is greater than 1,000, the objects beyond 1,000 cannot be returned.
Value range:
true: Not all results are returned.
false: All results are returned.
Default value:
None
NextMarker
string
Explanation:
Where in the bucket the next listing begins. If not all results are returned, the response contains this parameter to mark the last object listed in the request. In a subsequent request, you can set Marker to the value of this parameter to list the remaining objects.
Value range:
Default value:
None
Contents
[]Content
Explanation:
List of objects in the bucket. For details, see Content.
CommonPrefixes
[]string
Explanation:
List of object name prefixes grouped according to the Delimiter parameter (if specified)
Value range:
Default value:
None
EncodingType
string
Explanation:
Value range:
url
Default value:
None
Table 5 Content
Parameter
Type
Description
Key
string
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
Default value:
None
LastModified
time.Time
Explanation:
Time (UTC) when an object was last modified
Value range:
UTC time
Default value:
None
ETag
string
Explanation:
Base64-encoded, 128-bit MD5 value of an object. ETag is the unique identifier of the object content. It can be used to determine whether the object content is changed. For example, if the ETag value is A when an object is uploaded, but changes to B when the object is downloaded, it indicates that the object content has been changed. The ETag reflects changes to the object content, rather than the object metadata. An uploaded or copied object has a unique ETag after being encrypted using MD5.
Restrictions:
If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object.
Value range:
The value must contain 32 characters.
Default value:
None
Size
int64
Explanation:
Object size in bytes
Value range:
The value ranges from 0 TB to 48.8 TB, in bytes.
Default value:
None
Owner
Owner
Explanation:
Object owner. This parameter contains the domain ID and name of the object owner. For details, see Table 7.
Default value:
None
StorageClass
string
Explanation:
Object storage class
Value range:
See Table 6.
Default value:
None
Table 6 StorageClassType
Constant
Default Value
Description
StorageClassStandard
STANDARD
OBS Standard
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
StorageClassWarm
WARM
OBS Infrequent Access
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed.
StorageClassCold
COLD
OBS Archive
Used for storing rarely accessed (once a year) data.
Table 7 Owner
Parameter
Type
Mandatory (Yes/No)
Description
ID
string
Yes if used as a request parameter
Explanation:
Account (domain) ID of the owner
Value range:
To obtain the account ID, see How Do I Get My Account ID and User ID?
Default value:
None
Listing Objects
This example lists objects in a bucket. A maximum of 1,000 objects can be returned.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.ListObjectsInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // List objects in the bucket.
    output, err := obsClient.ListObjects(input)
    if err == nil {
        fmt.Printf("List objects under the bucket(%s) successful!\n", input.Bucket)
        fmt.Printf("RequestId:%s\n", output.RequestId)
        for index, val := range output.Contents {
            fmt.Printf("Content[%d]-OwnerId:%s, ETag:%s, Key:%s, LastModified:%s, Size:%d\n",
                index, val.Owner.ID, val.ETag, val.Key, val.LastModified, val.Size)
        return
    fmt.Printf("List objects under the bucket(%s) fail!\n", input.Bucket)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
Listing a Specified Number of Objects
This example lists a specified number of objects in a bucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
package main
import (
    "fmt"
    "os"
func main() {
    // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    if err != nil {
    // Specify the maximum number of objects to be returned. 100 is used as an example. Returned objects are listed in alphabetic order. The default value is 1000.
    input.MaxKeys = 100
    if err == nil {
        return
        fmt.Println(err)
Listing Objects with a Specified Prefix
This example lists objects with a specified prefix.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
package main
import (
    "fmt"
    "os"
func main() {
    if err != nil {
    // Specify an object prefix (test/ as an example). Objects whose names contain the specified prefix will be listed.
    input.Prefix = "test/"
    input.MaxKeys = 100
    if err == nil {
        return
        fmt.Println(err)
Listing All Objects Using Pagination
This example lists all objects using pagination.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
// This example lists all files in bucket examplebucket using pagination.
package main
import (
    "fmt"
    "os"
func main() {
    obsClient, err := obs.New(ak, sk, endPoint, obs.WithSecurityToken(securityToken))
    if err != nil {
    input.MaxKeys = 100
    // Specify an encoding type. url is used as an example. If the objects to list contain special characters, this parameter must be passed.
    input.EncodingType = "url"
    for {
        if err != nil {
                fmt.Println(err)
            os.Exit(-1)
        // Print the listing result. By default, 100 records are returned at a time.
        if output.IsTruncated {
            input.Marker = output.NextMarker
            break
Listing All Objects with Folder Name as a Prefix
There is no concept of folders in OBS. All elements stored in OBS buckets are objects. Folders are actually objects whose sizes are 0 and whose names end with a slash (/). You can set a folder name to a prefix to list objects in this folder. Sample code is as follows:
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
package main
import (
    "fmt"
    "os"
func main() {
    if err != nil {
    input.MaxKeys = 100
    // Specify a delimiter for grouping object names. A slash (/) is used as an example.
    input.Delimiter = "/"
    if err == nil {
        return
        fmt.Println(err)
