Obtaining the Bucket ACL (SDK for Go)
Function
Access control lists (ACLs) allow resource owners to grant other accounts the permissions to access resources. By default, only the resource owner has full control over resources when a bucket or object is created. That is, the bucket creator has full control over the bucket, and the object uploader has full control over the object. Other accounts do not have the permissions to access resources. If resource owners want to grant other accounts the read and write permissions on resources, they can use ACLs. ACLs grant permissions to accounts. After an account is granted permissions, both the account and its IAM users can access the resources. For more information, see ACLs.
This API returns the ACL of a bucket.
Restrictions
- To obtain the ACL of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketAcl in IAM or GetBucketAcl in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) GetBucketAcl(bucketName string) (output *GetBucketAclOutput, err error)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
bucketName |
string |
Yes |
Explanation: Bucket name Restrictions:
Default value: None |
Responses
Parameter |
Type |
Description |
output |
Explanation: Returned results. For details, see Table 3. |
err |
error |
Explanation: Error messages returned by the API |
Parameter |
Type |
Description |
StatusCode |
int |
Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
RequestId |
string |
Explanation: Request ID returned by the OBS server Default value: None |
ResponseHeaders |
map[string][]string |
Explanation: HTTP response headers Default value: None |
Owner |
Explanation: Bucket owner. For details, see Table 4. |
Grants |
Explanation: Grantees' permission information. For details, see Table 5. |
Parameter |
Type |
Description |
ID |
string |
Yes if used as a request parameter |
Explanation: Account (domain) ID of the owner Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
Parameter |
Type |
Description |
Grantee |
Explanation: Grantee information. For details, see Table 6. |
Permission |
Explanation: Granted permission. For details, see Table 9. |
Parameter |
Type |
Description |
Type |
Explanation: Grantee type Value range: See Table 7. Default value: None |
ID |
string |
Explanation: Account (domain) ID of the grantee Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
DisplayName |
string |
Explanation: Account name of the grantee Restrictions:
URI |
Explanation: Authorized user group Value range: See Table 8. Default value: None |
Constant |
Default Value |
Description |
GranteeGroup |
Group |
User group |
GranteeUser |
CanonicalUser |
Individual user |
Constant |
Default Value |
Description |
PermissionRead |
READ |
Read permission |
PermissionWrite |
WRITE |
Write permission |
PermissionReadAcp |
READ_ACP |
Permission to read ACL configurations |
PermissionWriteAcp |
WRITE_ACP |
Permission to modify ACL configurations |
PermissionFullControl |
FULL_CONTROL |
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL. |
Code Examples
This example shows how to obtain the ACL of the examplebucket bucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 |
package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint, obs.WithSignature(obs.SignatureObs)/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } // Specify a bucket name. bucketname := "examplebucket" // Obtain the bucket ACL. output, err := obsClient.GetBucketAcl(bucketname) if err == nil { fmt.Printf("Get bucket(%s)'s acl rules successful!\n", bucketname) fmt.Printf("RequestId:%s\n", output.RequestId) fmt.Printf("Owner.ID:%s\n", output.Owner.ID) for index, grant := range output.Grants { fmt.Printf("Grant[%d]-Type:%s, ID:%s, URI:%s, Permission:%s\n", index, grant.Grantee.Type, grant.Grantee.ID, grant.Grantee.URI, grant.Permission) } return } fmt.Printf("Get bucket(%s)'s acl rules fail!\n", bucketname) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
Feedback
Was this page helpful?
Chatbot
