Configuring Static Website Hosting for a Bucket (SDK for Go)
Function
You can host static website resources such as HTML web pages, flash files, or audio and video files in an OBS bucket, so that you can access these hosted resources using the bucket's website endpoint. Typical use cases include:
- Redirecting all requests to another website
- Redirecting specific requests
This API configures static website hosting for a bucket.
Restrictions
- Periods (.) should be avoided in the target bucket name, or there may be certificate verification failures on the client when you use HTTPS for access.
- The request body of the website configuration cannot exceed 10 KB.
- To configure static website hosting for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutBucketWebsite in IAM or PutBucketWebsite in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) SetBucketWebsiteConfiguration(input *SetBucketWebsiteConfigurationInput) (output *BaseModel, err error)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
input |
Yes |
Explanation: Input parameters for configuring static website hosting. For details, see Table 2. |
Parameter |
Type |
Description |
Bucket |
string |
Yes |
Explanation: Bucket name Restrictions:
Value range: The value must contain 3 to 63 characters. |
RedirectAllRequestsTo |
No |
Explanation: Redirection rules for all requests. For details, see Table 3. |
IndexDocument |
No |
Explanation: Default page configuration. For details, see Table 4. |
ErrorDocument |
No |
Explanation: Error page configuration. For details, see Table 5. |
RoutingRules |
No |
Explanation: List of routing rules. For details, see Table 6. |
- ErrorDocument, IndexDocument, and RoutingRules must be used together and they cannot be used with RedirectAllRequestsTo.
- When ErrorDocument, IndexDocument, and RoutingRules are used together, RoutingRules can be left blank.
- You must specify either the three parameters (ErrorDocument, IndexDocument, and RoutingRules), or RedirectAllRequestsTo.
Parameter |
Type |
Description |
HostName |
string |
Yes if RedirectAllRequestsTo is specified |
Explanation: Host name used for redirection, for example, www.example.com Restrictions: The host name must comply with the host name rules. Default value: None |
Protocol |
No |
Explanation: Protocol used for redirection Value range: See Table 9. Default value: None |
Parameter |
Type |
Description |
Suffix |
string |
Yes if IndexDocument is specified |
Explanation: Suffix that is appended to the request for a directory. For example, if the suffix is index.html and you request samplebucket/images/, the returned data will be for the object named images/index.html in the bucket samplebucket. Value range: This parameter can neither be left blank nor contain slashes (/). Default value: None |
Parameter |
Type |
Description |
Key |
string |
No if ErrorDocument is specified |
Explanation: Object name to use when a 4XX error occurs. This parameter specifies the webpage to display when an error occurs. Value range: The value must contain 1 to 1,024 characters. Default value: None |
Parameter |
Type |
Description |
Condition |
No |
Explanation: Conditions that must be met for the specified redirect to apply Value range: See Table 7. Default value: None |
Redirect |
Yes if RoutingRule is specified |
Explanation: Details about the redirection. For details, see Table 8. |
Parameter |
Type |
Description |
KeyPrefixEquals |
string |
No |
Explanation: Object name prefix when the redirection is applied. When a request is sent for accessing an object, the redirection rule takes effect if the object name prefix matches the value specified for this parameter. For example, to redirect the request for object ExamplePage.html, set the KeyPrefixEquals to ExamplePage.html. Restrictions: This parameter cannot be used together with HttpErrorCodeReturnedEquals. Value range: The value must contain 1 to 1,024 characters. Default value: None |
HttpErrorCodeReturnedEquals |
string |
No |
Explanation: HTTP error codes when the redirection takes effect. The specified redirection is applied only when the error code returned equals the value specified for this parameter. For example, if you want to redirect requests to NotFound.html when HTTP error code 404 is returned, set HttpErrorCodeReturnedEquals to 404 in Condition, and set ReplaceKeyWith to NotFound.html in Redirect. Restrictions: This parameter cannot be used together with KeyPrefixEquals. Value range: See Error Codes. Default value: None |
Parameter |
Type |
Description |
Protocol |
No if used as a request parameter |
HostName |
string |
Explanation: Host name used for redirection Default value: None |
ReplaceKeyPrefixWith |
string |
Explanation: Object name prefix used for redirection Value range: The value must contain 1 to 1,024 characters. Default value: None |
ReplaceKeyWith |
string |
Explanation: Object name used for redirection Restrictions: This parameter cannot be used together with replaceKeyPrefixWith. Value range: The value must contain 1 to 1,024 characters. Default value: None |
HttpRedirectCode |
string |
Explanation: HTTP status code in the response to the redirect request. For details, see Status Code. Default value: None |
Constant |
Default Value |
Description |
ProtocolHttp |
http |
HTTP protocol used for redirection |
ProtocolHttps |
https |
HTTPS protocol used for the redirection request |
Responses
Parameter |
Type |
Description |
output |
Explanation: Returned results. For details, see Table 11. |
err |
error |
Explanation: Error messages returned by the API |
Parameter |
Type |
Description |
StatusCode |
int |
Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
RequestId |
string |
Explanation: Request ID returned by the OBS server Default value: None |
ResponseHeaders |
map[string][]string |
Explanation: HTTP response headers Default value: None |
Code Examples
This example configures static website hosting for bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 |
package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint, obs.WithSecurityToken(securityToken)) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.SetBucketWebsiteConfigurationInput{} // Specify a bucket name. input.Bucket = "examplebucket" // Specify a default page (index.html as an example). This configuration indicates that when examplebucket/images/ is requested, the content of object images/index.html in bucket samplebucket will be returned. input.IndexDocument.Suffix = "index.html" // Specify an error page (error.html as an example). input.ErrorDocument.Key = "error.html" // Specify the list of request redirect rules. input.RoutingRules = []obs.RoutingRule{ {Redirect: obs.Redirect{HostName: "www.a.com", Protocol: obs.ProtocolHttp, ReplaceKeyPrefixWith: "prefix", HttpRedirectCode: "304"}}, {Redirect: obs.Redirect{HostName: "www.b.com", Protocol: obs.ProtocolHttps, ReplaceKeyWith: "replaceKey", HttpRedirectCode: "304"}}, } // Configure static website hosting for the bucket. output, err := obsClient.SetBucketWebsiteConfiguration(input) if err == nil { fmt.Printf("Set bucket(%s)'s website successful!\n", input.Bucket) fmt.Printf("RequestId:%s\n", output.RequestId) return } fmt.Printf("Set bucket(%s)'s website fail!\n", input.Bucket) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
Feedback
Was this page helpful?
Chatbot
