Configuring CORS for a Bucket (SDK for Go)
Function
Cross-origin resource sharing (CORS) is a browser-standard mechanism defined by the World Wide Web Consortium (W3C). It allows a web client in one origin to interact with resources in another one. For general web page requests, website scripts and contents in one origin cannot interact with those in another because of Same Origin Policies (SOPs). OBS supports CORS rules that allow the resources in OBS to be requested from other origins.
This API configures CORS for a bucket.
Restrictions
- To configure CORS for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutBucketCORS in IAM or PutBucketCORS in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) SetBucketCors(input *SetBucketCorsInput) (output *BaseModel, err error)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
input |
Yes |
Explanation: Input parameters for configuring CORS for a bucket. For details, see Table 2. |
Parameter |
Type |
Description |
Bucket |
string |
Yes |
Explanation: Bucket name Restrictions:
Default value: None |
CorsRules |
[]CorsRule |
Yes |
Explanation: CORS rule list of the bucket. For details, see Table 3. Restrictions: A list can have a maximum of 100 CORS rules. |
Parameter |
Type |
Description |
ID |
string |
No if used as a request parameter |
Explanation: CORS rule ID Value range: The value must contain 1 to 255 characters. Default value: None |
AllowedMethod |
[]string |
Yes if used as a request parameter |
Explanation: The allowed HTTP methods cross-origin request, same as the operation types of buckets and objects. Value range: The following HTTP methods are supported:
AllowedOrigin |
[]string |
Explanation: The origin from which the requests can access the bucket. Restrictions: Domain name of the origin. Each origin can contain only one wildcard character (*), for example, https://*.vbs.example.com. Default value: None |
AllowedHeader |
[]string |
Explanation: The allowed headers for cross-origin requests. Only CORS requests matching the allowed headers are valid. Restrictions: Each header can contain only one wildcard character (*). Spaces, ampersands (&), colons (:), and less-than signs (<) are not allowed. Default value: None |
MaxAgeSeconds |
int |
Explanation: Time your client can cache the response for a cross-origin request Restrictions: Each CORS rule can specify only one value for MaxAgeSeconds. Value range: 0 to (231 – 1), in seconds Default value: 100 |
ExposeHeader |
[]string |
Explanation: The CORS-allowed additional headers in the response. These headers provide additional information to clients. By default, your browser can only access headers Content-Length and Content-Type. If your browser needs to access other headers, add them to a list of the allowed additional headers. Restrictions: Spaces, wildcard characters (*), ampersands (&), colons (:), and less-than signs (<) are not allowed. Default value: None |
Responses
Parameter |
Type |
Description |
output |
Explanation: Returned results. For details, see Table 5. |
err |
error |
Explanation: Error messages returned by the API |
Parameter |
Type |
Description |
StatusCode |
int |
Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
RequestId |
string |
Explanation: Request ID returned by the OBS server Default value: None |
ResponseHeaders |
map[string][]string |
Explanation: HTTP response headers Default value: None |
Code Examples
This example configures CORS rules for bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 |
package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint, obs.WithSecurityToken(securityToken)) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.SetBucketCorsInput{} // Specify a bucket name. input.Bucket = "examplebucket" // Specify CORS rules. input.CorsRules = []obs.CorsRule{ { ID: "rule1", AllowedOrigin: []string{"http://www.a.com", "http://www.b.com"}, AllowedMethod: []string{"GET", "PUT"}, AllowedHeader: []string{"header1", "header2"}, MaxAgeSeconds: 1000, ExposeHeader: []string{"obs-1", "obs-2"}, }, { ID: "rule2", AllowedOrigin: []string{"http://www.c.com", "http://www.d.com"}, AllowedMethod: []string{"GET", "POST"}, AllowedHeader: []string{"header3", "header4"}, MaxAgeSeconds: 1000, }, } // Configure CORS for the bucket. output, err := obsClient.SetBucketCors(input) if err == nil { fmt.Printf("Set bucket(%s) CORS configuration successful!\n", input.Bucket) fmt.Printf("RequestId:%s\n", output.RequestId) return } fmt.Printf("Set bucket(%s) CORS configuration fail!\n", input.Bucket) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
Feedback
Was this page helpful?
Chatbot
