Initiating a Multipart Upload (SDK for Go)
Function
This API initiates a multipart upload and returns a globally unique upload ID. You can use this upload ID in your subsequent requests including UploadPart, CompleteMultipartUpload, and ListParts. There can be more than one multipart upload for the same object. Each multipart upload initiation request can contain headers such as Content-Type, Content-Encoding, and the headers for ACL and user-defined metadata. These headers are recorded in the multipart upload metadata.
Restrictions
- To initiate a multipart upload, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- After initiating a multipart upload and uploading one or more parts, you must assemble the parts or abort the multipart upload. Only after that can OBS stops billing you for storing the uploaded parts.
Method
func (obsClient ObsClient) InitiateMultipartUpload(input *InitiateMultipartUploadInput) (output *InitiateMultipartUploadOutput, err error)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
input |
Yes |
Explanation: Input parameters for initiating a multipart upload. For details, see Table 2. |
Parameter |
Type |
Description |
Bucket |
string |
Yes |
Explanation: Bucket name Restrictions:
Default value: None |
Key |
string |
Yes |
Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
ACL |
No |
Explanation: ACL that can be pre-defined when a bucket is created. For details about ACLs, see ACLs. Value range: For details about the ACL options, see AclType. Default value: private |
WebsiteRedirectLocation |
string |
No |
Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. The request is redirected to object anotherPage.html in the same bucket: WebsiteRedirectLocation:/anotherPage.html The request is redirected to an external URL http://www.example.com/: WebsiteRedirectLocation:http://www.example.com/ OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation. Restrictions:
ContentType |
string |
No |
Explanation: MIME type of the file to be uploaded. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Value range: See What Is Content-Type (MIME)? Default value: If you do not specify this parameter when uploading an object, the SDK determines the object type based on the suffix of the specified object name and automatically assigns a value to this parameter. |
SseHeader |
No |
Explanation: Server-side encryption header. If SSE-C is used, see Table 4. If SSE-KMS is used, see Table 5. |
StorageClass |
No |
Explanation: Object storage class If this parameter is not set, the object inherits the storage class of its bucket. Value range: StorageClassType lists the available value options. Default value: STANDARD |
Metadata |
map[string]string |
No |
Explanation: Custom metadata of the object to be uploaded. You can add a header starting with x-obs-meta- in the request to define metadata. The custom metadata will be returned in the response when you retrieve the object or query the object metadata. Restrictions:
GrantReadId |
string |
No |
Explanation: ID (domain_id) of an account the READ permission is granted to. The account with the READ permission can read the current object and obtain its metadata. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
GrantReadAcpId |
string |
No |
Explanation: ID (domain_id) of an account the READ_ACP permission is granted to. The account with the READ_ACP permission can read the ACL of the current object. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
GrantWriteAcpId |
string |
No |
Explanation: ID (domain_id) of an account the WRITE_ACP permission is granted to. The account with the WRITE_ACP permission can write the ACL of the current object. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
GrantFullControlId |
string |
No |
Explanation: ID (domain_id) of an account the FULL_CONTROL permission is granted to. The account with the FULL_CONTROL permission can read the current object, obtain its metadata, and obtain and write its ACL. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
Expires |
int64 |
No |
Explanation: Expiration time of the object (calculated from the latest modification time of the object). Expired objects are automatically deleted. Restrictions: This parameter can be configured only during object upload and cannot be modified by calling a metadata API. Value range: 1 to (263 - 1), in days Default value: None |
EncodingType |
string |
No |
Explanation: Encoding type for Key in the response. If Key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode Key. Value range: url Default value: None. If you leave this parameter blank, encoding is not applied to Key. |
Constant |
Default Value |
Description |
AclPrivate |
private |
Private read/write A bucket or object can only be accessed by its owner. |
AclPublicRead |
public-read |
Public read and private write If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket. If it is granted on an object, anyone can read the content and metadata of the object. |
AclPublicReadWrite |
public-read-write |
Public read/write If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart upload tasks. If it is granted on an object, anyone can read the content and metadata of the object. |
AclPublicReadDelivered |
public-read-delivered |
Public read on a bucket as well as objects in the bucket If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions, and read the content and metadata of objects in the bucket.
NOTE:
AclPublicReadDelivered does not apply to objects. |
AclPublicReadWriteDelivered |
public-read-write-delivered |
Public read/write on a bucket as well as objects in the bucket If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of objects in the bucket.
NOTE:
AclPublicReadWriteDelivered does not apply to objects. |
AclBucketOwnerFullControl |
bucket-owner-full-control |
If this permission is granted on an object, only the bucket and object owners have the full control over the object. By default, if you upload an object to a bucket of any other user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object. |
Parameter |
Type |
Description |
Encryption |
string |
Yes if used as a request parameter |
Explanation: SSE-C used for encrypting objects Value range: AES256, indicating objects are encrypted using SSE-C Default value: None |
Key |
string |
Explanation: Key for encrypting the object when SSE-C is used Restrictions: The value is a Base64-encoded 256-bit key, for example, K7QkYpBkM5+hca27fsNkUnNVaobncnLht/rCB2o/9Cw=. Default value: None |
KeyMD5 |
string |
No if used as a request parameter |
Explanation: MD5 value of the key for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key. Restrictions: The value is encrypted by MD5 and then encoded by Base64, for example, 4XvB3tbNTN+tIEVa0/fGaQ==. Default value: None |
Parameter |
Type |
Description |
Encryption |
string |
Explanation: SSE-KMS used for encrypting objects Value range: kms, indicating objects are encrypted using SSE-KMS Default value: None |
Key |
string |
Explanation: ID of the KMS master key when SSE-KMS is used Value range: Valid value formats are as follows:
In the preceding formats:
Default value:
Constant |
Default Value |
Description |
StorageClassStandard |
STANDARD |
OBS Standard Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
StorageClassWarm |
WARM |
OBS Infrequent Access Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed. |
StorageClassCold |
COLD |
OBS Archive Used for storing rarely accessed (once a year) data. |
Responses
Parameter |
Type |
Description |
output |
Explanation: Returned results. For details, see Table 8. |
err |
error |
Explanation: Error messages returned by the API |
Parameter |
Type |
Description |
StatusCode |
int |
Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
RequestId |
string |
Explanation: Request ID returned by the OBS server Default value: None |
ResponseHeaders |
map[string][]string |
Explanation: HTTP response headers Default value: None |
Bucket |
string |
Explanation: Name of the bucket involved in the multipart upload Restrictions:
Key |
string |
Explanation: Name of the object to be uploaded. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
UploadId |
string |
Explanation: Multipart upload ID, for example, 000001648453845DBB78F2340DD460D8 Value range: The value must contain 1 to 32 characters. Default value: None |
SseHeader |
Explanation: Server-side encryption header. If SSE-C is used, see Table 9. If SSE-KMS is used, see Table 10. |
EncodingType |
string |
Parameter |
Type |
Description |
Encryption |
string |
Key |
string |
KeyMD5 |
string |
Parameter |
Type |
Description |
Encryption |
string |
Key |
string |
Default value:
Code Examples
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 |
package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.InitiateMultipartUploadInput{} // Specify a bucket name. input.Bucket = "examplebucket" // Specify an object name (example/objectname as an example). input.Key = "example/objectname" // Initiate a multipart upload. output, err := obsClient.InitiateMultipartUpload(input) if err == nil { fmt.Printf("Initiate multipart upload successful with bucket(%s) and object(%s)!\n", input.Bucket, input.Key) fmt.Printf("UploadId:%s\n", output.UploadId) return } fmt.Printf("Initiate multipart upload fail with bucket(%s) and object(%s)!\n", input.Bucket, input.Key) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
Feedback
Was this page helpful?
Chatbot
