Uploading an Object - Resumable (SDK for Node.js)
Function
The resumable upload is an encapsulated and enhanced version of the multipart upload used for dealing with possible upload failures of large files when the network connection is unstable or a program crashes.
Uploading large files often fails due to poor network conditions or program breakdowns. It is a waste of resources to restart the upload process upon an upload failure, and the restarted upload process may still suffer from the unstable network. To resolve such issues, you can use the API for resumable upload, whose working principle is to divide the to-be-uploaded file into multiple parts and upload them separately. The upload result of each part is recorded in a checkpoint file in real time. Only when all parts are successfully uploaded, the result indicating a successful upload will be returned. Otherwise, an error is returned in callback function to remind you of calling the API again for re-uploading. Based on the upload status of each part recorded in the checkpoint file, the re-uploading will upload the parts failed to be uploaded previously, instead of uploading all parts. By virtue of this, resources are saved and efficiency is improved.
The resumable upload interface helps save resources and improve efficiency by restarting an upload from the point of failure and concurrently uploading parts. You do not need to worry about internal service details, such as the creation and deletion of checkpoint files, division of objects, or concurrent uploads of parts.
Restrictions
The total size of files uploaded by the resumable upload API must be larger than 100 KB.
Method
ObsClient.uploadFile(params)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
Bucket |
string |
Yes |
Explanation: Bucket name. Restrictions:
Value range: The value can contain 3 to 63 characters. Default value: None |
Key |
string |
Yes |
Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Restrictions: None Value range: The value can contain 1 to 1,024 characters. Default value: None |
UploadFile |
string |
No |
Explanation: Source file path of the object to be uploaded Restrictions: None Value range: None Default value: None |
PartSize |
number |
No |
Explanation: Size of the current part. Restrictions: None Value range: The value ranges from 100 KB to 5 GB, in bytes. Default value: 102400 |
TaskNum |
number |
No |
Explanation: Maximum number of parts that can be uploaded concurrently Restrictions: None Value range: 1~10000 Default value: 1, indicating concurrent uploads are not used |
ProgressCallback |
function |
No |
Explanation: Callback function for obtaining the upload progress
NOTE:
This callback function contains the following parameters in sequence: number of uploaded bytes, total bytes, and used time (in seconds). Restrictions: None Value range: None Default value: None |
ResumeCallback |
function |
No |
Explanation: Callback function used to obtain the control parameter for canceling a resumable download Restrictions: None Value range: None Default value: None
NOTE:
EnableCheckpoint |
boolean |
No |
Explanation: Whether to enable the resumable mode. Restrictions: None Value range:
Default value: false |
CheckpointFile |
string |
No |
Explanation: Path of a file generated for recording the progress of a resumable upload. The file contains the information about parts and progress. Restrictions: This parameter is valid only in the resumable mode. Value range: None Default value: If this parameter is left blank, the checkpoint file will be in the same directory as the local file to be uploaded. |
EnableCheckSum |
boolean |
No |
Explanation: Whether to verify the file to upload. If this function is enabled, before each task restarts, the system verifies whether the file to upload is the one used during task initialization. Restrictions: This parameter is valid only in the resumable mode. Value range:
ContentType |
string |
No |
Explanation: MIME type of the file to be uploaded. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Restrictions: None Value range: See What Is Content-Type (MIME)? (SDK for Node.js) Default value: If you do not specify this parameter when uploading an object, the SDK determines the object type based on the suffix of the specified object name and automatically assigns a value to this parameter. |
ACL |
No |
Explanation: Access control list (ACL) that can be pre-defined when an object is created. For details about ACLs, see ACLs. Restrictions: None Value range: See Table 2. Default value: None |
WebsiteRedirectLocation |
string |
No |
Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. The request is redirected to object anotherPage.html in the same bucket: WebsiteRedirectLocation:/anotherPage.html The request is redirected to an external URL: WebsiteRedirectLocation:http://www.example.com/ OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation. Restrictions:
SseKmsKey |
string |
No |
Explanation: ID of the KMS master key when SSE-KMS is used. Restrictions: Valid value formats are as follows:
In the preceding formats:
SseC |
string |
Yes when SSE-C is used |
Explanation: SSE-C is used for encrypting objects on the server side. Restrictions: Only AES256 is supported. Value range: AES256 Default value: None |
SseCKey |
string |
Yes if used as a request parameter |
Explanation: Key used for encrypting the object when SSE-C is used Restrictions: A Base64-encoded, 256-bit value, for example, K7QkYpBkM5+hca27fsNkUnNVaobncnLht/rCB2o/9Cw= Value range: None Default value: None |
Metadata |
object |
No |
Explanation: Custom metadata of the object to be uploaded. You can add a header starting with x-obs-meta- in the request to define metadata. The custom metadata will be returned in the response when you retrieve the object or query the object metadata. Restrictions:
Constant |
Default Value |
Description |
ObsClient.enums.AclPrivate |
private |
Private read and write A bucket or object can only be accessed by its owner. |
ObsClient.enums.AclPublicRead |
public-read |
Public read and private write If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket. If this permission is granted on an object, everyone can obtain the content and metadata of the object. |
ObsClient.enums.AclPublicReadWrite |
public-read-write |
Public read and write If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart upload tasks. If this permission is granted on an object, everyone can obtain the content and metadata of the object. |
ObsClient.enums.AclPublicReadDelivered |
public-read-delivered |
Public read on a bucket as well as the objects in the bucket. If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions and read the content and metadata of objects in the bucket.
NOTE:
AclPublicReadDelivered does not apply to objects. |
ObsClient.enums.AclPublicReadWriteDelivered |
public-read-write-delivered |
Public read and write on a bucket as well as the objects in the bucket. If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of objects in the bucket.
NOTE:
AclPublicReadWriteDelivered does not apply to objects. |
ObsClient.enums.AclBucketOwnerFullControl |
bucket-owner-full-control |
If this permission is granted on an object, only the bucket and object owners have the full control over the object. By default, if you upload an object to a bucket of any other user, the bucket owner does not have the permissions on your object. After you grant this policy to the bucket owner, the bucket owner can have full control over your object. For example, if user A uploads object x to user B's bucket, user B does not have the control over object x. If user A sets the bucket-owner-full-control policy for object x, user B then has the control over object x. |
Responses
Type |
Description |
NOTE:
This API returns a Promise response, which requires the Promise or async/await syntax. |
Explanation: Returned results. For details, see Table 4. |
Parameter |
Type |
Description |
CommonMsg |
Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 5. |
InterfaceResult |
Explanation: Results outputted for a successful call. For details, see Table 6. Restrictions: This parameter is not included if the value of Status is greater than 300. |
Parameter |
Type |
Description |
Status |
number |
Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes. |
Code |
string |
Explanation: Error code returned by the OBS server. |
Message |
string |
Explanation: Error description returned by the OBS server. |
HostId |
string |
Explanation: Request server ID returned by the OBS server. |
RequestId |
string |
Explanation: Request ID returned by the OBS server. |
Id2 |
string |
Explanation: Request ID2 returned by the OBS server. |
Indicator |
string |
Explanation: Error code details returned by the OBS server. |
Parameter |
Type |
Description |
RequestId |
string |
Explanation: Request ID returned by the OBS server |
ETag |
string |
Explanation: Base64-encoded, 128-bit MD5 value of an assembled object calculated based on the ETag of each part. The ETag is a unique identifier for the object's contents, used to determine if the object has been updated. For example, if the ETag value is A when an object is uploaded and B when the object is downloaded, this indicates the contents of the object have been changed. The ETag reflects changes to an object's contents, not its metadata. Objects created by the upload and copy operations have unique ETags after being encrypted using MD5. Restrictions: If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object. |
Bucket |
string |
Explanation: Name of the bucket in which parts are assembled |
Key |
string |
Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. |
Location |
string |
Explanation: URL of the object obtained from assembling the parts. Example: https://example-Bucket.obs.regions.myhuaweicloud.com/example-Object |
VersionId |
string |
Explanation: Version ID of the object obtained from assembling the parts. If versioning is enabled for the bucket, the object version ID will be returned. |
SseKms |
string |
Explanation: SSE-KMS is used for encrypting objects on the server side. |
SseKmsKey |
string |
Explanation: ID of the KMS master key when SSE-KMS is used. |
SseC |
string |
Explanation: SSE-C is used for encrypting objects on the server side. |
SseCKeyMd5 |
string |
Explanation: MD5 value of the key used for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key. Restrictions: Base64-encoded MD5 value of the key, for example, 4XvB3tbNTN+tIEVa0/fGaQ== |
Code Examples
This example uploads example/objectname to examplebucket using resumable upload.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 |
// Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); async function uploadFile() { try { const params = { // Specify the bucket name. Bucket: 'examplebucket', // Specify the object to be created (example/objectname in this example). Key: 'example/objectname', //Specify the local file to upload (/tmp/objectname in this example). UploadFile: 'localfile', // Specify whether to enable resumable transmission. Value true is used in this example. The default value is false. EnableCheckpoint: true, // Specify a part size, in bytes. This example sets each part to 9 MB. PartSize: 9 * 1024 * 1024, // Specify the maximum number of parts that can be concurrently transmitted. 5 is used in this example. TaskNum: 5 }; // Upload the object using resumable upload. const result = await obsClient.uploadFile(params); if (result.CommonMsg.Status <= 300) { console.log("Upload file(%s) under the bucket(%s) successful!", params.Key, params.Bucket); console.log("RequestId: %s", result.CommonMsg.RequestId); console.log("ETag: %s", result.InterfaceResult.ETag) return; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; uploadFile(); |
Feedback
Was this page helpful?
Chatbot
