Downloading an Archive Object (SDK for Node.js)
To prolong the validity period of the Archive data restored, you can repeatedly restore the data, but you will be billed for each restoration. After a second restore, the validity period of Standard object copies will be prolonged, and you need to pay for storing these copies during the prolonged period.
Function
To download an object in the Archive storage class, you need to restore it first. After an object is restored, a copy of the object is saved in the Standard storage class. By doing so, the object in the Archive storage class and its copy in the Standard storage class co-exist in the bucket. The copy will be automatically deleted once its retention period ends.
This API restores an Archive object in a specified bucket.
Restrictions
- To restore an Archive object, you must be the bucket owner or have the required permission (obs:object:RestoreObject in IAM or RestoreObject in a bucket policy.) For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- To learn about the mappings between OBS regions and endpoints, see Regions and Endpoints.
- To extend the validity period of the Archive data restored, you can repeatedly restore the data, but you will be billed for each restoration. After a restoration, the validity period of Standard object copies will be extended, and you need to pay for storing these copies during the extended period.
Method
ObsClient.restoreObject(params)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
Bucket |
string |
Yes |
Explanation: Bucket name Restrictions:
Value range: The value can contain 3 to 63 characters. Default value: None |
Key |
string |
Yes |
Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Restrictions: The object specified in ObsClient.restoreObject must be in the Archive storage class. Otherwise, an error is reported. Value range: The value can contain 1 to 1,024 characters. Default value: None |
VersionId |
string |
No |
Explanation: Version ID of the Archive object to restore. Restrictions: None Value range: The value must contain 32 characters. Default value: None. If this parameter is left blank, the latest version of the object is specified. |
Days |
number |
Yes |
Explanation: After an object is restored, a Standard copy is generated for the object. This parameter specifies how long the Standard copy can be retained, that is, the validity period of the restored object. Restrictions: None Value range: The value ranges from 1 to 30, in days. Default value: None |
Tier |
No |
Explanation: Tier of the restoration speed. You can select a suitable tier based on your needs. Restrictions: None Value range: See Table 2. Default value: Standard |
Responses
Type |
Description |
NOTE:
This API returns a Promise response, which requires the Promise or async/await syntax. |
Explanation: Returned results. For details, see Table 4. |
Parameter |
Type |
Description |
CommonMsg |
Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 5. |
InterfaceResult |
Explanation: Results outputted for a successful call. For details, see Table 6. Restrictions: This parameter is not included if the value of Status is greater than 300. |
Parameter |
Type |
Description |
Status |
number |
Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes. |
Code |
string |
Explanation: Error code returned by the OBS server. |
Message |
string |
Explanation: Error description returned by the OBS server. |
HostId |
string |
Explanation: Request server ID returned by the OBS server. |
RequestId |
string |
Explanation: Request ID returned by the OBS server. |
Id2 |
string |
Explanation: Request ID2 returned by the OBS server. |
Indicator |
string |
Explanation: Error code details returned by the OBS server. |
Code Examples
You can call ObsClient.restoreObject to restore an Archive object. Sample code is as follows:
// Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here as an example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); async function downloadColdObject() { // Specify the bucket name. const bucketName = "examplebucket"; // Specify the object (example/objectname in this example). const objectKey = "example/objectname"; try { // Restore an Archive object. const restoreObjectOutput = await obsClient.restoreObject({ Bucket: bucketName, Key: objectKey, // Specify how long the restored object will be retained, in days. The value ranges from 1 to 30 (1 this example). Days: 1, // Specify the restoration speed (obs.RestoreTierExpedited in this example). By default, the object is restored at an expedited speed. Tier: obs.enums.RestoreTierExpedited }); if (restoreObjectOutput.CommonMsg.Status > 300) { handleMessage(restoreObjectOutput.CommonMsg); return; }; // Wait for the object to be restored. await sleep(5 * 60); // Download the object. const getObjectOutput = await obsClient.getObject({ Bucket: bucketName, Key: objectKey, }); if (getObjectOutput.CommonMsg.Status > 300) { handleMessage(getObjectOutput.CommonMsg); return; }; console.log("Get object(%s) under the bucket(%s) successful!", params.Key, params.Bucket); console.log("RequestId: %s", result.CommonMsg.RequestId); console.log('Object Content: %s', result.InterfaceResult.Content); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; function handleMessage(commonMsg) { console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", commonMsg.Status); console.log("Code: %s", commonMsg.Code); console.log("Message: %s", commonMsg.Message); console.log("RequestId: %s", commonMsg.RequestId); }; function sleep() { return new Promise(resolve => { setTimeout(resolve, time * 1000); }); } ; downloadColdObject();
Feedback
Was this page helpful?
Chatbot
