Help Center/ Object Storage Service/ SDK Reference/ Node.js/ Lifecycle (SDK for Node.js)/ Obtaining the Lifecycle Rules of a Bucket (SDK for Node.js)
Updated on 2025-02-07 GMT+08:00
Function
You can configure lifecycle rules to periodically delete objects or transition objects between storage classes. For more information, see Lifecycle Management.
This API returns the lifecycle rules of a bucket.
Restrictions
Method
ObsClient.getBucketLifecycle(params)
Request Parameters
Table 1 BucketRequestInput
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported, and the bucket attributes comply with those set in the first creation request.
Value range:
The value can contain 3 to 63 characters.
Default value:
None
Responses
Table 2 Responses
Type
Description
Table 3
NOTE:
This API returns a Promise response, which requires the Promise or async/await syntax.
Explanation:
Returned results. For details, see Table 3.
Table 3 Response
Parameter
Type
Description
CommonMsg
ICommonMsg
Explanation:
Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4.
InterfaceResult
Table 5
Explanation:
Results outputted for a successful call. For details, see Table 5.
Restrictions:
This parameter is not included if the value of Status is greater than 300.
Table 4 ICommonMsg
Parameter
Type
Description
Status
number
Explanation:
HTTP status code returned by the OBS server.
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes.
Code
string
Explanation:
Error code returned by the OBS server.
Message
string
Explanation:
Error description returned by the OBS server.
HostId
string
Explanation:
Request server ID returned by the OBS server.
RequestId
string
Explanation:
Request ID returned by the OBS server.
Id2
string
Explanation:
Request ID2 returned by the OBS server.
Indicator
string
Explanation:
Error code details returned by the OBS server.
Table 5 GetBucketLifecycleOutput
Parameter
Type
Description
RequestId
string
Explanation:
Default value:
None
Rules
LifecycleRule[]
Yes
Explanation:
Lifecycle rule information. For details, see Table 6.
Table 6 LifecycleRule
Parameter
Type
Description
ID
string
Explanation:
Lifecycle rule ID.
Prefix
string
Explanation:
Object name prefix. It identifies the objects the rule applies to. You can leave this parameter blank to apply the rule to all objects in the bucket.
Assume that you have the following objects: logs/day1, logs/day2, logs/day3, and ExampleObject.jpg. If you set Prefix to ExampleObject.jpg, the rule applies to object ExampleObject.jpg alone. If you set Prefix to logs/, the rule applies to objects logs/day1, logs/day2, and logs/day3. If you leave Prefix blank, the rule applies to all objects in the bucket.
Status
string
Explanation:
Whether the rule is enabled.
Value range:
Enabled
Disabled
Transitions
Transition[]
Explanation:
Policies for storage class transition, including transition time and the storage class after transition. For details, see Table 7.
Restrictions:
This parameter is only available for the latest object version.
Expiration
Expiration
Explanation:
Object expiration time. For details, see Table 8.
Restrictions:
NoncurrentVersionTransitions
NoncurrentVersionTransition[]
Explanation:
Policies for storage class transition, including transition time and the storage class after transition. For details, see Table 9.
Restrictions:
  • This parameter is only available for historical object versions.
  • Versioning must be enabled (or suspended after being enabled) for the bucket.
NoncurrentVersionExpiration
Explanation:
Expiration time of historical object versions. For details, see Table 10.
Restrictions:
  • This parameter is not available for parallel file systems.
Table 7 Transition
Parameter
Type
Description
StorageClass
StorageClassType
Explanation:
Storage class of the object after transition
Date
string
Explanation:
OBS executes the lifecycle rule for objects that were modified before the specified date.
Days
number
Explanation:
How many days can pass since the last update before the lifecycle rule takes effect
Table 8 Expiration
Parameter
Type
Description
Date
string
Explanation:
OBS executes the lifecycle rule (deletion) for objects that were modified before the specified date.
Days
number
Explanation:
How many days can pass since the last update before the lifecycle rule (deletion) takes effect
Table 9 NoncurrentVersionTransition
Parameter
Type
Description
StorageClass
StorageClassType
Explanation:
Storage class of historical object versions after transition
NoncurrentDays
number
Explanation:
Number of days an object is historical before the specified rule takes effect
Table 10 NoncurrentVersionExpiration
Parameter
Type
Description
NoncurrentDays
number
Explanation:
Table 11 AbortIncompleteMultipartUpload
Parameter
Type
Description
DaysAfterInitiation
number
Explanation:
Number of days since the initiation of an incomplete multipart upload that OBS will wait before deleting the non-assembled parts (fragments) of the upload
Table 12 StorageClassType
Constant
Default Value
Description
ObsClient.enums.StorageClassStandard
STANDARD
Standard storage class.
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
ObsClient.enums.StorageClassWarm
WARM
Infrequent Access storage class.
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but becomes instantly available when needed.
ObsClient.enums.StorageClassCold
COLD
Archive storage class.
Used for storing rarely accessed (once a year) data.
Code Examples
You can call ObsClient.getBucketLifecycle to view lifecycle rules of a bucket. The following code shows how to obtain the lifecycle rule of bucket examplebucket:
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
// Import the OBS library.
// Use npm to install the client.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an instance of ObsClient.
const obsClient = new ObsClient({
  // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
  // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
  access_key_id: process.env.ACCESS_KEY_ID,
  secret_access_key: process.env.SECRET_ACCESS_KEY,
  // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
  // security_token: process.env.SECURITY_TOKEN,
  // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use.
  server: "https://obs.ap-southeast-1.myhuaweicloud.com"
async function getBucketLifecycle() {
  try {
    const params = {
      // Specify the bucket name.
      Bucket: "examplebucket"
    // Obtain the lifecycle rules of the bucket.
    const result = await obsClient.getBucketLifecycle(params);
    if (result.CommonMsg.Status <= 300) {
      console.log("Get bucket(%s)'s lifecycle configuration successful!", params.Bucket);
      console.log("RequestId: %s", result.CommonMsg.RequestId);
      for (let i = 0; i < result.InterfaceResult.Rules.length; i++) {
        const rule = result.InterfaceResult.Rules[i];
        console.log("ID:%s, Prefix:%s, Status:%s, Expiration[Date]:%s, Expiration[Days]:%d, NoncurrentVersionExpiration[NoncurrentDays]:%s",
          rule.ID, rule.Prefix, rule.Status, rule.Expiration.Date,
          rule.Expiration.Days, rule.NoncurrentVersionExpiration.NoncurrentDays
      return;
    console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
    console.log("Status: %d", result.CommonMsg.Status);
    console.log("Code: %s", result.CommonMsg.Code);
    console.log("Message: %s", result.CommonMsg.Message);
  } catch (error) {
    console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
    console.log(error);
getBucketLifecycle();
