Obtaining the Logging Configuration of a Bucket (SDK for Node.js)
Function
This API returns the logging configuration of a bucket.
Restrictions
- To obtain the logging configuration of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketLogging in IAM or GetBucketLogging in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- To learn about the mappings between OBS regions and endpoints, see Regions and Endpoints.
Method
ObsClient.getBucketLogging(params)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
Bucket |
string |
Yes |
Explanation: Bucket name. Restrictions:
Value range: The value can contain 3 to 63 characters. Default value: None |
Responses
Type |
Description |
NOTE:
This API returns a Promise response, which requires the Promise or async/await syntax. |
Explanation: Returned results. For details, see Table 3. |
Parameter |
Type |
Description |
CommonMsg |
Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4. |
InterfaceResult |
Explanation: Results outputted for a successful call. For details, see Table 5. Restrictions: This parameter is not included if the value of Status is greater than 300. |
Parameter |
Type |
Description |
Status |
number |
Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes. |
Code |
string |
Explanation: Error code returned by the OBS server. |
Message |
string |
Explanation: Error description returned by the OBS server. |
HostId |
string |
Explanation: Request server ID returned by the OBS server. |
RequestId |
string |
Explanation: Request ID returned by the OBS server. |
Id2 |
string |
Explanation: Request ID2 returned by the OBS server. |
Indicator |
string |
Explanation: Error code details returned by the OBS server. |
Parameter |
Type |
Description |
RequestId |
string |
Explanation: Request ID returned by the OBS server |
Agency |
string |
Explanation: Name of the IAM agency created by the owner of the target bucket for OBS. You can select an existing IAM agency or create one. For details about how to create an agency, see Creating an IAM Agency. |
LoggingEnabled |
Explanation: Logging configuration information |
Parameter |
Type |
Description |
TargetBucket |
string |
Explanation: Name of the bucket for storing log files. |
TargetPrefix |
string |
Explanation: Name prefix for log files stored in the target bucket. |
TargetGrants |
Explanation: Permission information list of grantees, which defines grantees and their permissions for log files. For details, see Table 7. |
Parameter |
Type |
Description |
Grantee |
Yes if used as a request parameter |
Explanation: Grantee information. For details, see Table 8. |
Permission |
Explanation: Granted permissions. For details, see Table 11. |
Parameter |
Type |
Description |
Type |
Explanation: Grantee type. For details, see Table 9. |
ID |
string |
Yes if this parameter is used as a request parameter and Type is set to a user |
Explanation: Account (domain) ID of the grantee. |
Name |
string |
No if used as a request parameter |
Explanation: Account name of the grantee. |
URI |
Yes if this parameter is used as a request parameter and Type is set to a group |
Explanation: Authorized user group. For details, see Table 10. |
Constant |
Default Value |
Description |
GranteeGroup |
Group |
Grants permissions to user groups. |
GranteeUser |
CanonicalUser |
Grants permissions to individual users. |
Constant |
Default Value |
Description |
GroupAllUsers |
AllUsers |
All users |
GroupAuthenticatedUsers |
Authorized users. This constant is deprecated. |
GroupLogDelivery |
LogDelivery |
Log delivery group. This constant is deprecated. |
Constant |
Default Value |
Description |
ObsClient.enums.PermissionRead |
READ |
A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket. A grantee with this permission for an object can obtain the object content and metadata. |
ObsClient.enums.PermissionWrite |
WRITE |
A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket. This permission is not applicable to objects. |
ObsClient.enums.PermissionReadAcp |
READ_ACP |
A grantee with this permission can obtain the ACL of a bucket or object. A bucket or object owner has this permission for their bucket or object by default. |
ObsClient.enums.PermissionWriteAcp |
WRITE_ACP |
A grantee with this permission can update the ACL of a bucket or object. A bucket or object owner has this permission for their bucket or object by default. This permission allows the grantee to change the access control policies, meaning the grantee has full control over a bucket or object. |
ObsClient.enums.PermissionFullControl |
FULL_CONTROL |
A grantee with this permission for a bucket has PermissionRead, PermissionWrite, PermissionReadAcp, and PermissionWriteAcp permissions for the bucket. A grantee with this permission for an object has PermissionRead, PermissionReadAcp, and PermissionWriteAcp permissions for the object. |
Code Examples
You can call ObsClient.getBucketLogging to view the logging configuration of a bucket. The following code shows how to obtain the logging configuration of bucket examplebucket:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 |
// Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); async function getBucketLogging() { try { const params = { // Specify the bucket name. Bucket: "examplebucket", }; // Obtain logging for a bucket. const result = await obsClient.getBucketLogging(params); if (result.CommonMsg.Status <= 300) { console.log("Get bucket(%s)'s logging configuration successful!", params.Bucket); console.log("RequestId: %s", result.CommonMsg.RequestId); if (result.InterfaceResult.LoggingEnabled) { console.log('TargetBucket: %s', result.InterfaceResult.LoggingEnabled.TargetBucket); console.log('TargetPrefix: %s', result.InterfaceResult.LoggingEnabled.TargetPrefix); for (let i = 0; i < result.InterfaceResult.LoggingEnabled.TargetGrants.length; i++) { const grant = result.InterfaceResult.LoggingEnabled.TargetGrants[0]; console.log('Grant[%d]-Type:%s, ID:%s, URI:%s, Permission:%s', i, grant.Grantee.Type, grant.Grantee.ID, grant.Grantee.URI, grant.Permission ); }; }; return; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; getBucketLogging(); |
Feedback
Was this page helpful?
Chatbot
