Obtaining Static Website Hosting Configurations (SDK for Node.js)
Function
You can host static website resources such as HTML web pages, flash files, or audio and video files in an OBS bucket, so that you can provide these hosted resources using the bucket's website endpoint to end users. Typical use cases include:
- Redirecting all requests to another website
- Redirecting specific requests
This API returns the static website hosting configurations of the bucket.
Restrictions
- To obtain the static website hosting configurations of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketWebsite in IAM or GetBucketWebsite in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- To learn about the mappings between OBS regions and endpoints, see Regions and Endpoints.
Method
ObsClient.getBucketWebsite(params)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
Bucket |
string |
Yes |
Explanation: Bucket name. Restrictions:
Value range: The value can contain 3 to 63 characters. Default value: None |
Responses
Type |
Description |
NOTE:
This API returns a Promise response, which requires the Promise or async/await syntax. |
Explanation: Returned results. For details, see Table 3. |
Parameter |
Type |
Description |
CommonMsg |
Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4. |
InterfaceResult |
Explanation: Results outputted for a successful call. For details, see Table 5. Restrictions: This parameter is not included if the value of Status is greater than 300. |
Parameter |
Type |
Description |
Status |
number |
Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes. |
Code |
string |
Explanation: Error code returned by the OBS server. |
Message |
string |
Explanation: Error description returned by the OBS server. |
HostId |
string |
Explanation: Request server ID returned by the OBS server. |
RequestId |
string |
Explanation: Request ID returned by the OBS server. |
Id2 |
string |
Explanation: Request ID2 returned by the OBS server. |
Indicator |
string |
Explanation: Error code details returned by the OBS server. |
Parameter |
Type |
Description |
RequestId |
string |
Explanation: Request ID returned by the OBS server |
RedirectAllRequestsTo |
Explanation: Redirection rules for all requests. For details, see Table 8. |
IndexDocument |
Explanation: Default page configuration. For details, see Table 6. |
ErrorDocument |
Explanation: Error page configuration. For details, see Table 7. |
RoutingRules |
Explanation: List of routing rules. For details, see Table 9. |
Parameter |
Type |
Description |
Suffix |
string |
Yes if IndexDocument is specified |
Explanation: Suffix that is appended to the request for a directory. For example, if the suffix is index.html and you request samplebucket/images/, the returned data will be for the object named images/index.html in the bucket samplebucket. Restrictions: This parameter can neither be left blank nor contain slashes (/). Value range: None Default value: None |
Parameter |
Type |
Description |
Key |
string |
No if ErrorDocument is specified |
Explanation: The object name that is used when a 4XX error occurs. This element specifies the page that is returned when an error occurs. Restrictions: None Value range: The key can contain 1 to 1,024 characters. Default value: None |
Parameter |
Type |
Description |
HostName |
string |
Explanation: Domain name used for redirection, for example, www.example.com |
Protocol |
string |
Explanation: Protocol used for redirection |
Parameter |
Type |
Description |
Condition |
Explanation: Conditions that must be met for the specified rule to take effect. For details, see Condition. |
Redirect |
Explanation: Details about the redirection. For details, see Table 11. |
Parameter |
Type |
Description |
KeyPrefixEquals |
string |
No |
Explanation: Object name prefix for the redirection to take effect. If the name prefix of the requested object is the same as the value specified for this parameter, the redirection rule takes effect. For example, to redirect the requests for the object ExamplePage.html, set KeyPrefixEquals to ExamplePage.html. Restrictions: This parameter cannot be used together with HttpErrorCodeReturnedEquals. Value range: The value can contain 1 to 1,024 characters. Default value: None |
HttpErrorCodeReturnedEquals |
string |
No |
Explanation: HTTP error code for the redirection to take effect. If an error code returned is the same as the value specified for this parameter, the redirection rule takes effect. For example, if you want to redirect requests to NotFound.html when HTTP error code 404 is returned, set HttpErrorCodeReturnedEquals to 404 in Condition and set ReplaceKeyWith to NotFound.html in Redirect. Restrictions: This parameter cannot be used together with KeyPrefixEquals. Value range: See Error Codes. Default value: None |
Parameter |
Type |
Description |
Protocol |
string |
HostName |
string |
Explanation: Domain name used for redirection |
ReplaceKeyPrefixWith |
string |
Explanation: Object name prefix used in the redirection request |
ReplaceKeyWith |
string |
Explanation: Object name used in the redirection request |
HttpRedirectCode |
string |
Explanation: HTTP status code in the response to the redirection request. For details, see Status Codes. |
Code Examples
You can call ObsClient.getBucketWebsite to obtain the hosting configuration of a bucket. The following code shows how to obtain the website configuration of bucket examplebucket:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 |
// Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); async function getBucketWebsite() { try { const params = { // Specify the bucket name. Bucket: "examplebucket", }; // Obtain the website configuration of the bucket. const result = await obsClient.getBucketWebsite(params); if (result.CommonMsg.Status <= 300) { console.log("Get bucket(%s)'s website configuration successful!", params.Bucket); console.log('RedirectAllRequestsTo:'); console.log('HostName: %s', result.InterfaceResult.RedirectAllRequestsTo.HostName); console.log('Protocol: %s', result.InterfaceResult.RedirectAllRequestsTo.Protocol); console.log('IndexDocument[Suffix]: %s', result.InterfaceResult.IndexDocument.Suffix); console.log('ErrorDocument[Key]: %s', result.InterfaceResult.ErrorDocument.Key); console.log('RoutingRules:'); for (let i = 0; i < result.InterfaceResult.RoutingRules; i++) { let routingRule = result.InterfaceResult.RoutingRules[i]; let condition = routingRule.Condition; console.log("Condition[%d]-KeyPrefixEquals:%s, HttpErrorCodeReturnedEquals:%s", i, condition.KeyPrefixEquals, condition.HttpErrorCodeReturnedEquals ); let redirect = routingRule.Redirect; console.log("Redirect[%d]-Protocol:%s, HostName:%s, ReplaceKeyPrefixWith:%s, HttpRedirectCode:%s", i, redirect.Protocol, redirect.HostName, redirect.ReplaceKeyPrefixWith, redirect.HttpRedirectCode ); }; return; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; getBucketWebsite(); |
Feedback
Was this page helpful?
Chatbot
