Help Center/ Object Storage Service/ SDK Reference/ Python/ Bucket-Related APIs (SDK for Python)/ Obtaining the Lifecycle Configuration of a Bucket (SDK for Python)
Updated on 2025-05-09 GMT+08:00
Function
You can configure lifecycle rules to periodically delete objects or transition objects between storage classes. For more information, see Lifecycle Management.
This API returns the lifecycle rules of a bucket.
Restrictions
Method
ObsClient.getBucketLifecycle(bucketName, extensionHeaders)
Request Parameters
Parameter
Type
Mandatory (Yes/No)
Description
bucketName
str
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket properties comply with those set in the first creation request.
Default value:
None
extensionHeaders
dict
No
Explanation:
Extension headers.
Value range:
See User-defined Header (SDK for Python).
Default value:
None
Responses
Type
Description
GetResult
Explanation:
SDK common results
Table 1 GetResult
Parameter
Type
Description
status
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
reason
str
Explanation:
Reason description.
Default value:
None
errorCode
str
Explanation:
Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
errorMessage
str
Explanation:
Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
requestId
str
Explanation:
Request ID returned by the OBS server
Default value:
None
indicator
str
Explanation:
Error indicator returned by the OBS server.
Default value:
None
hostId
str
Explanation:
Requested server ID. If the value of status is less than 300, this parameter is left blank.
Default value:
None
resource
str
Explanation:
Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank.
Default value:
None
header
list
Explanation:
Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header.
Default value:
None
body
object
Explanation:
Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python).
Default value:
None
GetResult.body Type
Description
LifecycleResponse
Explanation:
Response to the request for obtaining the lifecycle configuration information of a bucket
Default value:
None
Table 2 LifecycleResponse
Parameter
Type
Description
lifecycleConfig
Lifecycle
Explanation:
Bucket lifecycle configuration. For details, see Table 3.
Default value:
None
Table 3 Lifecycle
Parameter
Type
Mandatory (Yes/No)
Description
rule
list of Rule
Yes if used as a request parameter
Explanation:
List of lifecycle rules. For details, see Table 4.
Default value:
None
Table 4 Rule
Parameter
Type
Mandatory (Yes/No)
Description
id
str
No if used as a request parameter
Explanation:
Lifecycle rule ID
Value range:
The value must contain 1 to 255 characters.
Default value:
None
prefix
str
Explanation:
Object name prefix. It identifies the objects the rule applies to. You can leave this parameter blank to apply the rule to all objects in the bucket.
Assume that you have the following objects: logs/day1, logs/day2, logs/day3, and ExampleObject.jpg. If you set Prefix to ExampleObject.jpg, the rule applies to object ExampleObject.jpg only. If you set Prefix to logs/, the rule applies to the three objects with name starting with logs/. If you leave Prefix blank, the rule applies to all objects in the bucket.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
status
str
Explanation:
Whether the rule is enabled
Value range:
  • Enabled
  • Disabled
Default value:
None
transition
Transition
or
list of Transition
Explanation:
Policies for storage class transition, including transition time and the storage class after transition. For details, see Table 5.
Restrictions:
This parameter applies only to the current object version.
Default value:
None
expiration
Expiration
Explanation:
Object expiration time. For details, see Table 7.
Restrictions:
Default value:
None
noncurrentVersionTransition
NoncurrentVersionTransition
or
list of NoncurrentVersionTransition
Explanation:
Policies for storage class transition, including transition time and the storage class after transition. For details, see Table 9.
Restrictions:
  • This parameter applies only to noncurrent object versions.
  • Versioning is enabled (or suspended after being enabled) for the bucket.
  • This parameter is not available for parallel file systems.
Default value:
None
noncurrentVersionExpiration
NoncurrentVersionExpiration
Explanation:
Expiration time of noncurrent object versions. For details, see Table 10.
Restrictions:
Default value:
None
Table 5 Transition
Parameter
Type
Mandatory (Yes/No)
Description
storageClass
str
Explanation:
Storage class of the object after transition
Restrictions:
  • The Standard storage class is not supported.
  • Restrictions on storage class transitions:
    • Only transitions from the Standard storage class to the Infrequent Access storage class are supported. To transition objects from Infrequent Access to Standard, you must manually do it.
    • Only transitions from the Standard or Infrequent Access storage class to the Archive storage class are supported. To transition objects from Archive to Standard or Infrequent Access, you must restore the objects first and then manually transition their storage class.
    • Multi-AZ redundancy is not available for Archive storage. For this reason, buckets or objects with multi-AZ redundancy cannot be transitioned to the Archive storage class based on a lifecycle rule.
Value range:
See Table 6.
Default value:
None
date
str
or
DateTime
Yes if the parameter is used as a request parameter and days is absent
Explanation:
Date when an object will be transitioned.
Restrictions:
The value must conform with the ISO8601 standards and indicate UTC 00:00. For example, 2018-01-01T00:00:00.000Z indicates only objects that were last modified before the specified time are transitioned to the specified storage class.
For example, DateTime(year=2023, month=9, day=12)
Default value:
None
days
int
Yes if the parameter is used as a request parameter and date is absent
Explanation:
Number of days (since the last update was made to the object) after which the lifecycle rule takes effect
Restrictions:
Value range:
An integer greater than or equal to 0, in days
Default value:
None
Table 6 StorageClass
Parameter
Type
Description
STANDARD
Explanation:
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
WARM
Explanation:
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed.
COLD
Explanation:
Used for storing rarely accessed (once a year) data.
Table 7 Expiration
Parameter
Type
Mandatory (Yes/No)
Description
date
str
or
DateTime
Explanation:
OBS executes the lifecycle rule for objects that were modified before the specified date.
Restrictions:
The value must conform with the ISO8601 standards and indicate UTC 00:00. For example, 2018-01-01T00:00:00.000Z indicates only objects that were last modified before the specified time are deleted.
Default value:
None
days
int
Explanation:
Restrictions:
Value range:
Default value:
None
Table 8 DateTime
Parameter
Type
Description
year
int
Explanation:
Year in UTC
Default value:
None
month
int
Explanation:
Month in UTC
Default value:
None
day
int
Explanation:
Day in UTC
Default value:
None
hour
int
Explanation:
Hour in UTC
Restrictions:
The value is in 24-hour format.
Default value:
0
min
int
Explanation:
Minute in UTC
Default value:
0
sec
int
Explanation:
Second in UTC
Default value:
0
Table 9 NoncurrentVersionTransition
Parameter
Type
Mandatory (Yes/No)
Description
storageClass
str
Explanation:
Restrictions:
Value range:
See Table 6.
Default value:
None
noncurrentDays
int
Explanation:
Number of days an object is noncurrent before the specified rule takes effect
Restrictions:
Value range:
Default value:
None
Table 10 NoncurrentVersionExpiration
Parameter
Type
Mandatory (Yes/No)
Description
noncurrentDays
int
Explanation:
Restrictions:
Value range:
Default value:
None
Code Examples
This example returns the lifecycle configuration of bucket examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
from obs import ObsClient
import os
import traceback
# Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage.
# Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
ak = os.getenv("AccessKeyID")
sk = os.getenv("SecretAccessKey")
# (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables.
# security_token = os.getenv("SecurityToken")
# Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use.
server = "https://obs.ap-southeast-1.myhuaweicloud.com"
# Create an obsClient instance.
# If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance.
obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server)
try:
    bucketName="examplebucket"
    # Obtain the lifecycle configuration of the bucket.
    resp = obsClient.getBucketLifecycle(bucketName)
    # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails.
    if resp.status < 300:
        print('Get Bucket Lifecycle Succeeded')
        print('requestId:', resp.requestId)
        index = 1
        for rule in resp.body.lifecycleConfig.rule:
            print('rule [' + str(index) + ']')
            print('id:', rule.id)
            print('prefix:', rule.prefix)
            print('status:', rule.status)
            if rule.expiration:
                print('days:', rule.expiration.days)
                print('date:', rule.expiration.date)
            if rule.noncurrentVersionExpiration:
                print('noncurrentDays:', rule.noncurrentVersionExpiration.noncurrentDays)
        index += 1
    else:
        print('Get Bucket Lifecycle Failed')
        print('errorCode:', resp.errorCode)
        print('errorMessage:', resp.errorMessage)
except:
    print(traceback.format_exc())
