Help Center/ Object Storage Service/ SDK Reference/ Python/ Bucket-Related APIs (SDK for Python)/ Obtaining Static Website Hosting for a Bucket (SDK for Python)
Updated on 2025-05-09 GMT+08:00
Function
You can host static website resources such as HTML web pages, flash files, as well as audio and video files in an OBS bucket, so that you can provide these hosted resources using the bucket's website endpoint to end users. Typical use cases include:
  • Redirecting all requests to another website
  • Redirecting specific requests
This API returns the static website hosting configuration of the bucket.
Restrictions
Method
ObsClient.getBucketWebsite(bucketName, extensionHeaders)
Request Parameters
Parameter
Type
Mandatory (Yes/No)
Description
bucketName
str
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket properties comply with those set in the first creation request.
Default value:
None
extensionHeaders
dict
No
Explanation:
Extension headers.
Value range:
See User-defined Header (SDK for Python).
Default value:
None
Responses
Type
Description
GetResult
Explanation:
SDK common results
Table 1 GetResult
Parameter
Type
Description
status
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
reason
str
Explanation:
Reason description.
Default value:
None
errorCode
str
Explanation:
Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
errorMessage
str
Explanation:
Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
requestId
str
Explanation:
Request ID returned by the OBS server
Default value:
None
indicator
str
Explanation:
Error indicator returned by the OBS server.
Default value:
None
hostId
str
Explanation:
Requested server ID. If the value of status is less than 300, this parameter is left blank.
Default value:
None
resource
str
Explanation:
Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank.
Default value:
None
header
list
Explanation:
Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header.
Default value:
None
body
object
Explanation:
Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python).
Default value:
None
GetResult.body Type
Description
WebsiteConfiguration
Explanation:
Website hosting settings of a bucket
Table 2 WebsiteConfiguration
Parameter
Type
Mandatory (Yes/No)
Description
redirectAllRequestTo
RedirectAllRequestTo
No if used as a request parameter
Explanation:
Redirection rules for all requests. For details, see Table 3.
indexDocument
IndexDocument
Explanation:
Default page configuration. For details, see Table 4.
errorDocument
ErrorDocument
Explanation:
Error page configuration. For details, see Table 5.
routingRules
list of RoutingRule
Explanation:
List of routing rules. For details, see Table 6.
  • errorDocument, indexDocument, and routingRules must be used together and they cannot be used with redirectAllRequestsTo.
  • When errorDocument, indexDocument, and routingRules are used together, routingRules can be left blank.
  • You must specify either the combo of fields ErrorDocument, IndexDocument, and RoutingRules, or the RedirectAllRequestsTo field.
Table 3 RedirectAllRequestTo
Parameter
Type
Mandatory (Yes/No)
Description
hostName
str
Yes if used as a request parameter
Explanation:
Host name used for redirection, for example, www.example.com
Restrictions:
The host name must comply with the host name rules.
Default value:
None
protocol
str
Explanation:
Protocol used for redirection
Value range:
  • http
  • https
Default value:
None
Table 4 IndexDocument
Parameter
Type
Mandatory (Yes/No)
Description
suffix
str
Explanation:
Suffix that is appended to the request for a directory. For example, if the suffix is index.html and you request samplebucket/images/, the returned data will be for the object named images/index.html in the bucket samplebucket.
Value range:
This parameter can neither be left blank nor contain slashes (/).
Default value:
None
Table 5 ErrorDocument
Parameter
Type
Mandatory (Yes/No)
Description
key
str
Explanation:
Object name to use when a 4XX error occurs. This parameter specifies the webpage to display when an error occurs.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
Table 6 RoutingRule
Parameter
Type
Mandatory (Yes/No)
Description
condition
Condition
Explanation:
Conditions that must be met for the specified redirect to apply
Value range:
See Table 7.
Default value:
None
redirect
Redirect
Explanation:
Details about the redirection. For details, see Table 8.
Default value:
None
Table 7 Condition
Parameter
Type
Mandatory (Yes/No)
Description
keyPrefixEquals
str
Explanation:
Object name prefix for the redirection to take effect. If the name prefix of the requested object is the same as the value specified for this parameter, the redirection rule takes effect.
For example, to redirect the requests for the object ExamplePage.html, set KeyPrefixEquals to ExamplePage.html.
Restrictions:
This parameter cannot be used together with httpErrorCodeReturnedEquals.
Value range:
Default value:
None
int
Explanation:
HTTP error code for the redirection to take effect. If there is an error, and the error code returned is the same as the value specified for this parameter, the redirection rule takes effect.
For example, if you want to redirect requests to NotFound.html when HTTP error code 404 is returned, set httpErrorCodeReturnedEquals to 404 in Condition, and set ReplaceKeyWith to NotFound.html in Redirect.
Restrictions:
This parameter cannot be used together with keyPrefixEquals.
Value range:
See Error Codes.
Default value:
None
Table 8 Redirect
Parameter
Type
Mandatory (Yes/No)
Description
protocol
str
Explanation:
Value range:
  • http
  • https
Default value:
None
hostName
str
Explanation:
Default value:
None
replaceKeyPrefixWith
str
Explanation:
Object name prefix used in the redirection request
Value range:
Default value:
None
replaceKeyWith
str
Explanation:
Object name used in the redirection request
Restrictions:
This parameter cannot be used together with replaceKeyPrefixWith.
Value range:
Default value:
None
httpRedirectCode
int
Explanation:
HTTP status code in the response to the redirect request. For details, see Status Code.
Default value:
None
Code Examples
This example returns the static website hosting configuration of bucket examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
from obs import ObsClient
import os
import traceback
# Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage.
# Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
ak = os.getenv("AccessKeyID")
sk = os.getenv("SecretAccessKey")
# (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables.
# security_token = os.getenv("SecurityToken")
# Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use.
server = "https://obs.ap-southeast-1.myhuaweicloud.com"
# Create an obsClient instance.
# If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance.
obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server)
try:
    bucketName="examplebucket"
    # Obtain the website configuration of the bucket.
    resp = obsClient.getBucketWebsite(bucketName)
    # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails.
    if resp.status < 300:
        print('Get Bucket Website Succeeded')
        print('requestId:', resp.requestId)
        if resp.body.redirectAllRequestTo:
            print('redirectAllRequestTo.hostName:', resp.body.redirectAllRequestTo.hostName,
                  ',redirectAllRequestTo.protocol:', resp.body.redirectAllRequestTo.protocol)
        if resp.body.indexDocument:
            print('indexDocument.suffix:', resp.body.indexDocument.suffix)
        if resp.body.errorDocument:
            print('errorDocument.key:', resp.body.errorDocument.key)
        if resp.body.routingRules:
            index = 1
            for rout in resp.body.routingRules:
                print('routingRule[', index, ']:')
                index += 1
                print('condition.keyPrefixEquals:', rout.condition.keyPrefixEquals,
                      ',condition.httpErrorCodeReturnedEquals:', rout.condition.httpErrorCodeReturnedEquals)
                print('redirect.protocol:', rout.redirect.protocol, ',redirect.hostName:', rout.redirect.hostName,
                      ',redirect.replaceKeyPrefixWith:', rout.redirect.replaceKeyPrefixWith,
                      ',redirect.replaceKeyWith:', rout.redirect.replaceKeyWith, ',redirect.httpRedirectCode:',
                      rout.redirect.httpRedirectCode)
    else:
        print('Get Bucket Website Failed')
        print('errorCode:', resp.errorCode)
        print('errorMessage:', resp.errorMessage)
except:
    print(traceback.format_exc())
