Help Center/ Object Storage Service/ SDK Reference/ Python/ Bucket-Related APIs (SDK for Python)/ Obtaining the BPA Configuration of a Bucket (SDK for Python)
Updated on 2025-05-09 GMT+08:00
Function
This API returns the public access block configuration of an OBS bucket.
Restrictions
Method
ObsClient.getBucketPublicAccessBlock(bucket)
Request Parameters
Parameter
Type
Mandatory (Yes/No)
Description
bucketName
str
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name:
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported, and the bucket attributes comply with those set in the first creation request.
Default value:
None
extensionHeaders
dict
No
Explanation:
Extension headers.
Value range:
See User-defined Header (SDK for Python).
Default value:
None
Responses
Type
Description
GetResult
Explanation:
SDK common results
Table 1 GetResult
Parameter
Type
Description
status
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
reason
str
Explanation:
Reason description.
Default value:
None
errorCode
str
Explanation:
Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
errorMessage
str
Explanation:
Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
requestId
str
Explanation:
Request ID returned by the OBS server
Default value:
None
indicator
str
Explanation:
Error indicator returned by the OBS server.
Default value:
None
hostId
str
Explanation:
Requested server ID. If the value of status is less than 300, this parameter is left blank.
Default value:
None
resource
str
Explanation:
Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank.
Default value:
None
header
list
Explanation:
Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header.
Default value:
None
body
object
Explanation:
Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python).
Default value:
None
GetResult.body Type
Description
object
Explanation:
CORS rule list of the bucket. For details, see Table 2.
Table 2 BpaResponse
Parameter
Type
Description
blockPublicAcls
bool
Explanation:
Whether to block public ACLs. If this parameter is set to True, objects cannot be uploaded when the request includes a public ACL. Requests for modifying bucket or object ACLs fail if the requests include public ACLs.
ignorePublicAcls
bool
Explanation:
Whether to ignore public ACLs. If this parameter is set to True, the public ACL does not take effect during OpenAPI permissions checks.
blockPublicPolicy
bool
Explanation:
Whether to block the public policy. If this parameter is set to True, OBS rejects calls to modify bucket policies if the specified bucket policy allows public access.
restrictPublicBuckets
bool
Explanation:
Whether to restrict account access. If this parameter is set to True, only cloud service accounts and this account can access the bucket if a public bucket policy is found during the OpenAPI permissions check.
Code Examples
This example obtains the PublicAccessBlock configuration of bucket examplebucket.
from obs import ObsClient
import os
import traceback
# Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage.
# Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
ak = os.getenv("AccessKeyID")
sk = os.getenv("SecretAccessKey")
# (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables.
# security_token = os.getenv("SecurityToken")
# Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use.
server = "https://obs.ap-southeast-1.myhuaweicloud.com"
# Create an obsClient instance.
# If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance.
obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server)
try:
    bucketName = "examplebucket"
    # Obtain the PublicAccessBlock configuration of the bucket.
    resp = obsClient.getBucketPublicAccessBlock(bucketName)
    # If status code 2xx is returned, the API was called successfully. Otherwise, the call failed.
    if resp.status < 300:
        print('Get Bucket PublicAccessBlock Succeeded')
        print('requestId:', resp.requestId)
        print('blockPublicAcls:', resp.body.blockPublicAcls)
        print('ignorePublicAcls:', resp.body.ignorePublicAcls)
        print('blockPublicPolicy:', resp.body.blockPublicPolicy)
        print('restrictPublicBuckets:', resp.body.restrictPublicBuckets)
    else:
        print('Get Bucket PublicAccessBlock Failed')
        print('errorCode:', resp.errorCode)
        print('errorMessage:', resp.errorMessage)
except:
    print(traceback.format_exc())
