Copying an Object (SDK for Python)
Function
This API copies an object stored in OBS to another path, with a copy created during the process. You can create a copy of an object up to 5 GB in a single operation.
Restrictions
- To copy an object, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- The object copy request carries the information about the source bucket and object to be copied in the header field. The message body cannot be carried.
- The target object size ranges from 0 to 5 GB. If the source object size exceeds 5 GB, you can only copy parts of the object by referring to APIs Related to Multipart Upload (SDK for Python).
Method
ObsClient.copyObject(sourceBucketName, sourceObjectKey, destBucketName, destObjectKey, metadata, headers, versionId, extensionHeaders)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
sourceBucketName |
str |
Yes |
Explanation: Name of the source bucket Restrictions:
Default value: None |
sourceObjectKey |
str |
Yes |
Explanation: Source object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
versionId |
str |
No |
Explanation: Version ID of the source object, for example, G001117FCE89978B0000401205D5DC9A Value range: The value must contain 32 characters. Default value: If this parameter is left blank, the latest version of the source object is copied. |
destBucketName |
str |
Yes |
Explanation: Target bucket name Restrictions:
destObjectKey |
str |
Yes |
Explanation: Target object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
metadata |
dict |
No |
Explanation: Custom metadata of the target object You can add a header starting with x-obs-meta- in the request to define metadata. The custom metadata will be returned in the response when you retrieve the object or query the object metadata. Restrictions:
headers |
No |
Explanation: Request headers for copying an object. For details, see Table 2. Default value: None |
extensionHeaders |
dict |
No |
Explanation: Extension headers. Value range: See User-defined Header (SDK for Python). Default value: None |
Parameter |
Type |
Description |
acl |
str |
No |
Explanation: ACL that can be pre-defined during object copying Default value: None |
directive |
str |
No |
Explanation: Whether to copy source object attributes to the target object Value range:
Default value: COPY |
if_match |
str |
No |
Explanation: Preset ETag. If the ETag of the object to be downloaded is the same as the preset ETag, the object is returned. Otherwise, an error is returned. Value range: The value must contain 32 characters. Default value: None |
if_none_match |
str |
No |
Explanation: Preset ETag. If the ETag of the object to be downloaded is different from the preset ETag, the object is returned. Otherwise, an error is returned. Value range: The value must contain 32 characters. Default value: None |
if_modified_since |
str or |
No |
Explanation: The source object is copied if it has been modified since the specified time; otherwise, an exception is thrown. Restrictions: The value must be in the GMT format. For example, Wed, 25 Mar 2020 02:39:52 GMT. You can refer to Table 5 to specify time. For example, DateTime(year=2023, month=9, day=12) Default value: None |
if_unmodified_since |
str or |
No |
Explanation: The source object is copied if it has not been modified since the specified time; otherwise, an exception is thrown. Restrictions: The value must be in the GMT format. For example, Wed, 25 Mar 2020 02:39:52 GMT. You can refer to Table 5 to specify time. For example, DateTime(year=2023, month=9, day=12) Default value: None |
location |
str |
No |
Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. The request is redirected to object anotherPage.html in the same bucket: location:/anotherPage.html The request is redirected to an external URL http://www.example.com/: location:http://www.example.com/ OBS obtains the specified value from the header and stores it in the object metadata location. Restrictions:
destSseHeader |
or |
No |
Explanation: Header for server-side encryption. It is used to encrypt the target object. Value range: Default value: None |
sourceSseHeader |
No |
Explanation: Header for server-side decryption. It is used to decrypt the source object. Value range: See Table 6. Default value: None |
cacheControl |
str |
No |
Explanation: Cache-Control is rewritten in the response. Default value: None |
contentDisposition |
str |
No |
Explanation: Content-Disposition is rewritten in the response. Default value: None |
contentEncoding |
str |
No |
Explanation: Content-Encoding is rewritten in the response. Default value: None |
contentLanguage |
str |
No |
Explanation: Content-Language is rewritten in the response. Default value: None |
contentType |
str |
No |
Explanation: MIME type of the file to be uploaded. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Value range: See What Is Content-Type (MIME)? (Python SDK) Default value: None |
expires |
str |
No |
Explanation: Expiration details. Example: "expiry-date=\"Mon, 11 Sep 2023 00:00:00 GMT\"" Default value: None |
storageClass |
str |
No |
Explanation: Object storage class. Value range:
successActionRedirect |
str |
No |
Explanation: Address (URL) to which a successfully answered request is redirected
extensionGrants |
list of ExtensionGrant |
No |
Explanation: List of the extended permissions for the object Value range: See Table 8. Default value: None |
Constant |
Default Value |
Description |
HeadPermission.PRIVATE |
private |
Private read/write A bucket or object can only be accessed by its owner. |
HeadPermission.PUBLIC_READ |
public-read |
Public read and private write If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket. If it is granted on an object, anyone can read the content and metadata of the object. |
HeadPermission.PUBLIC_READ_WRITE |
public-read-write |
Public read/write If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart upload tasks. If it is granted on an object, anyone can read the content and metadata of the object. |
HeadPermission.PUBLIC_READ_DELIVERED |
public-read-delivered |
Public read on a bucket as well as objects in the bucket If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions, and read the content and metadata of objects in the bucket.
NOTE:
PUBLIC_READ_DELIVERED cannot be applied to objects. |
HeadPermission.PUBLIC_READ_WRITE_DELIVERED |
public-read-write-delivered |
Public read/write on a bucket as well as objects in the bucket If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of objects in the bucket.
NOTE:
PUBLIC_READ_WRITE_DELIVERED cannot be applied to objects. |
HeadPermission.BUCKET_OWNER_FULL_CONTROL |
If this permission is granted on an object, only the bucket and object owners have the full control over the object. By default, if you upload an object to a bucket owned by another user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object. |
Parameter |
Type |
Description |
STANDARD |
Standard storage class |
Explanation: Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
WARM |
Infrequent Access storage class |
Explanation: Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed. |
COLD |
Archive storage class |
Explanation: Used for storing rarely accessed (once a year) data. |
Parameter |
Type |
Description |
year |
int |
Explanation: Year in UTC Default value: None |
month |
int |
Explanation: Month in UTC Default value: None |
day |
int |
Explanation: Day in UTC Default value: None |
hour |
int |
Explanation: Hour in UTC Restrictions: The value is in 24-hour format. Default value: 0 |
min |
int |
Explanation: Minute in UTC Default value: 0 |
sec |
int |
Explanation: Second in UTC Default value: 0 |
Parameter |
Type |
Description |
encryption |
str |
Yes |
Explanation: SSE-C used for encrypting objects Value range: AES256 Default value: None |
key |
str |
Yes |
Explanation: Key used in SSE-C encryption. It corresponds to the encryption method. For example, if encryption is set to AES256, the key is calculated using the AES-256 algorithm. Value range: The value must contain 32 characters. Default value: None |
Parameter |
Type |
Description |
encryption |
str |
Yes |
Explanation: SSE-KMS used for encrypting objects Value range: kms Default value: None |
key |
str |
No |
Explanation: Master key used in SSE-KMS Value range: The following two formats are supported:
In the preceding formats:
Default value:
Parameter |
Type |
Description |
granteeId |
str |
No |
Explanation: Account (domain) ID of the grantee Value range: To obtain the account ID, see How Do I Get My Account ID and IAM User ID? (SDK for Python) Default value: None |
permission |
str |
No |
Explanation: Granted permissions Default value: None |
Constant |
Description |
READ |
Read permission A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket. A grantee with this permission for an object can obtain the object content and metadata. |
WRITE |
Write permission A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket. Such permission for an object is not applicable. |
READ_ACP |
Permission to read ACL configurations A grantee with this permission can obtain the ACL of a bucket or object. A bucket or object owner has this permission for the bucket or object permanently. |
WRITE_ACP |
Permission to modify ACL configurations A grantee with this permission can update the ACL of a bucket or object. A bucket or object owner has this permission for the bucket or object permanently. A grantee with this permission can modify the ACL, thus obtaining full access permissions. |
FULL_CONTROL |
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL. A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket. A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object. |
Responses
Type |
Description |
Explanation: SDK common results |
Parameter |
Type |
Description |
status |
int |
Explanation: HTTP status code Value range: A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
reason |
str |
Explanation: Reason description. Default value: None |
errorCode |
str |
Explanation: Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
errorMessage |
str |
Explanation: Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
requestId |
str |
Explanation: Request ID returned by the OBS server Default value: None |
indicator |
str |
Explanation: Error indicator returned by the OBS server. Default value: None |
hostId |
str |
Explanation: Requested server ID. If the value of status is less than 300, this parameter is left blank. Default value: None |
resource |
str |
Explanation: Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank. Default value: None |
header |
list |
Explanation: Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header. Default value: None |
body |
object |
Explanation: Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python). Default value: None |
GetResult.body Type |
Description |
Explanation: Response to the request for copying an object |
Parameter |
Type |
Description |
lastModified |
str |
Explanation: Time when the last modification was made to the target object Value range: UTC time Default value: None |
etag |
str |
Explanation: Base64-encoded, 128-bit MD5 value of an object. ETag is the unique identifier of the object contents and is used to determine whether the contents of an object are changed. For example, if the ETag value is A when an object is uploaded and is B when the object is downloaded, this indicates the contents of the object are changed. The ETag reflects changes only to the contents of an object, not its metadata. Objects created by the upload and copy operations have unique ETags after being encrypted using MD5. Restrictions: If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object. Value range: The value must contain 32 characters. Default value: None |
copySourceVersionId |
str |
Explanation: Version ID of the source object. Value range: The value must contain 32 characters. Default value: None |
versionId |
str |
Explanation: Version ID of the target object Value range: The value must contain 32 characters. Default value: None |
sseKms |
str |
Explanation: SSE-KMS is used for encrypting objects on the server side. Value range: kms Default value: None |
sseKmsKey |
str |
Explanation: ID of the KMS master key when SSE-KMS is used Value range: Valid value formats are as follows:
Default value:
sseC |
str |
Explanation: Algorithm used to encrypt and decrypt objects with SSE-C Value range: AES256 Default value: None |
sseCKeyMd5 |
str |
Explanation: MD5 value of the key for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key. Restrictions: The value is encrypted by MD5 and then encoded by Base64, for example, 4XvB3tbNTN+tIEVa0/fGaQ==. Default value: None |
Code Examples
This example copies an object from one bucket to another.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 |
from obs import ObsClient from obs import CopyObjectHeader import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: # Specify additional headers of the request for copying an object. headers = CopyObjectHeader() # Set directive of headers to REPLACE when custom metadata is configured. headers.directive = 'REPLACE' # Specify the value of if_match. If the ETag of the source object is the same as the one specified by this parameter, the source object is copied. Otherwise, an error code is returned. headers.if_match = '8f4e******************ba8c' # Specify custom metadata of the target object. metadata = {'meta1': 'value1'} # Specify a source bucket. sourceBucketName = 'sourcebucket' # Specify a source object. sourceObjectKey = 'sourceobjectkey' # Specify a target bucket. destBucketName = 'destbucket' # Specify a target object name. destObjectKey = 'destobjectkey' # Copy the object. resp = obsClient.copyObject(sourceBucketName, sourceObjectKey, destBucketName, destObjectKey, metadata, headers) # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails. if resp.status < 300: print('Copy Object Succeeded') print('requestId:', resp.requestId) print('etag:', resp.body.etag) print('lastModified:', resp.body.lastModified) print('versionId:', resp.body.versionId) print('copySourceVersionId:', resp.body.copySourceVersionId) else: print('Copy Object Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Copy Object Failed') print(traceback.format_exc()) |
Feedback
Was this page helpful?
Chatbot
