Uploading a Part (SDK for Python)
Function
After a multipart upload is initiated, this API uploads a part to a specified bucket. In the upload request, the multipart upload ID must be included. Except for the part lastly being uploaded whose size ranges from 0 to 5 GB, sizes of the other parts range from 100 KB to 5 GB. Part numbers can be any number from 1 to 10,000.
When uploading a part, you must specify its upload ID and part number. A part number uniquely identifies a part and its position in the object you are uploading. If you upload a new part with the same part number as that of a previous part, the previously uploaded part will be overwritten. Whenever you upload a part, OBS returns the ETag header in the response. For each part upload task, you must record the part number and ETag value. These values are required in subsequent requests for you to complete a multipart upload.
Restrictions
- To upload a part, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- After initiating a multipart upload and uploading one or more parts, you must assemble the parts or abort the multipart upload. Only after that can OBS stops billing you for storing the uploaded parts.
- partNumber in a multipart upload must be unique. When the same partNumber of the same object is concurrently uploaded, last write wins policy is applied. The time of last write is defined as the time when the part metadata is created. To ensure data accuracy, the client must be locked to ensure concurrent uploads of the same part of the same object. Concurrent uploads for different parts of the same object do not need to be locked.
Method
ObsClient.uploadPart(bucketName, objectKey, partNumber, uploadId, object, isFile, partSize, offset, sseHeader, isAttachMd5, md5, progressCallback, autoClose, extensionHeaders)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
bucketName |
str |
Yes |
Explanation: Bucket name Restrictions:
Default value: None |
objectKey |
str |
Yes |
Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None
NOTE:
The object URL is in the following format: https://Bucket name.Domain name/Folder directory level/Object name. If this object is stored in the root directory of the bucket, its URL does not contain the folder directory level. |
partNumber |
int |
Yes |
Explanation: Part number Value range: [1,10000] Default value: None |
uploadId |
str |
Yes |
Explanation: Multipart upload ID which can be returned by initiating a multipart upload, for example, 000001648453845DBB78F2340DD460D8 Restrictions: The value must contain 32 characters. Default value: None |
object |
str or readable object |
Yes |
Explanation: Part content to be uploaded Value range: A string or a readable object
NOTE:
If object is a readable object that contains the read attribute, data is read from the readable object. Otherwise, the object content is a string. Default value: None |
isFile |
bool |
No |
Explanation: Whether object indicates the file path. Value range: True: object indicates the file path. False: object does not indicate the file path. Default value: False |
offset |
int |
No |
Explanation: Start offset of a part in the source file Value range: A non-negative integer not exceeding the size of the object to be uploaded, in bytes Default value: 0 |
partSize |
int |
No |
Explanation: Part size Restrictions:
Value range: The value ranges from 100 KB to 5 GB, in bytes. Default value: 102400 |
sseHeader |
No |
Explanation: Server-side encryption header. For details, see Table 2. Default value: None |
isAttachMd5 |
bool |
No |
Explanation: Whether to automatically calculate the MD5 value of the data to be uploaded. Restrictions: If isAttachMd5 and md5 are used at the same time, isAttachMd5 is invalid. Value range: True: The MD5 value of the data to be uploaded is automatically calculated. False: The MD5 value of the data to be uploaded is not automatically calculated. Default value: False |
md5 |
str |
No |
Explanation: Base64-encoded MD5 value of the part to be uploaded, which uniquely identifies the content of the uploaded part and can be used to identify whether the object content is changed. Restrictions: If isAttachMd5 and md5 are used at the same time, isAttachMd5 is invalid. Value range: The value must contain 32 characters. Default value: None |
progressCallback |
callable |
No |
Explanation: Callback function for obtaining the upload progress Default value: None
NOTE:
This callback function contains the following parameters in sequence: number of uploaded bytes, total bytes, and used time (in seconds). |
autoClose |
bool |
No |
Explanation: Whether to automatically close data streams after the upload is complete Value range: True: The data stream is automatically closed. False: The data stream is not automatically closed. Default value: True |
extensionHeaders |
dict |
No |
Explanation: Extension headers. Value range: See User-defined Header (SDK for Python). Default value: None |
Parameter |
Type |
Description |
encryption |
str |
Yes |
Explanation: SSE-C used for encrypting objects Value range: AES256 Default value: None |
key |
str |
Yes |
Explanation: Key used in SSE-C encryption. It corresponds to the encryption method. For example, if encryption is set to AES256, the key is calculated using the AES-256 algorithm. Value range: The value must contain 32 characters. Default value: None |
Responses
Type |
Description |
Explanation: SDK common results |
Parameter |
Type |
Description |
status |
int |
Explanation: HTTP status code Value range: A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
reason |
str |
Explanation: Reason description. Default value: None |
errorCode |
str |
Explanation: Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
errorMessage |
str |
Explanation: Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
requestId |
str |
Explanation: Request ID returned by the OBS server Default value: None |
indicator |
str |
Explanation: Error indicator returned by the OBS server. Default value: None |
hostId |
str |
Explanation: Requested server ID. If the value of status is less than 300, this parameter is left blank. Default value: None |
resource |
str |
Explanation: Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank. Default value: None |
header |
list |
Explanation: Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header. Default value: None |
body |
object |
Explanation: Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python). Default value: None |
GetResult.body Type |
Description |
Explanation: Response to the request for uploading a part |
Parameter |
Type |
Description |
etag |
str |
Explanation: Base64-encoded 128-bit MD5 digest of a part. ETag is the unique identifier of the part content. It can be used to determine whether the part content is changed. Value range: The value must contain 32 characters. Default value: None |
sseKms |
str |
Explanation: SSE-KMS is used for encrypting objects on the server side. Value range: kms Default value: None |
sseKmsKey |
str |
Explanation: ID of the KMS master key when SSE-KMS is used Value range: Valid value formats are as follows:
In the preceding formats:
Default value:
sseC |
str |
Explanation: Algorithm used to encrypt and decrypt objects with SSE-C Value range: AES256 Default value: None |
sseCKeyMd5 |
str |
Explanation: MD5 value of the key for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key. Restrictions: The value is encrypted by MD5 and then encoded by Base64, for example, 4XvB3tbNTN+tIEVa0/fGaQ==. Default value: None |
Code Examples
This example uploads a part.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 |
from obs import ObsClient import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: bucketName = "examplebucket" # Specify the name of the object to be uploaded to the bucket. objectKey = "objectname" # Specify the part number, which ranges from 1 to 10,000 partNumber = "your partNumber" # Specify the ID of the multipart upload. uploadId = "your uploadid" # Specify the content of the part to be uploaded as a string or readable object. object = 'Hello OBS' # Specify whether object indicates the file path. The default value is False. isFile = False # Specify the start offset (in bytes) of a part in the source file. The default value is 0. offset = 0 # Specify the size (in bytes) of a part in the source file. The default value is the file size minus offset. partSize = 9 * 1024 * 1024 # Specify whether to automatically calculate the MD5 value of the data to be uploaded. The default value is False. isAttachMd5 = True # Upload the part to a specified bucket using the multipart upload ID. resp = obsClient.uploadPart(bucketName, objectKey, partNumber, uploadId, object, isFile, partSize, offset, isAttachMd5=isAttachMd5) # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails. if resp.status < 300: print('Upload Part Succeeded') print('requestId:', resp.requestId) print('etag:', resp.body.etag) else: print('Upload Part Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Upload Part Failed') print(traceback.format_exc()) |
Feedback
Was this page helpful?
Chatbot
