Creating a Signed URL (SDK for Python)
Function
This API creates a URL whose Query parameters are carried with authentication information by specifying the AK and SK, HTTP method, and request parameters. You can provide other users with this URL for temporary access. When generating a URL, you need to specify the validity period of the URL to restrict the access duration of visitors.
If you want to grant other users the permission to perform other operations on buckets or objects (for example, upload or download objects), generate a URL with the corresponding request (for example, to upload an object using the URL that generates the PUT request) and provide the URL for other users.
Restrictions
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- If a CORS or signature mismatch error occurs, refer to the following steps to troubleshoot the issue:
- If CORS is not configured, you need to configure CORS rules on OBS Console. For details, see Configuring CORS.
- If the signatures do not match, check whether signature parameters are correct. For details, see Authentication of Signature in a URL. For example, during an object upload, the backend uses Content-Type to calculate the signature and generate an authorized URL, but if Content-Type is not set or is set to an incorrect value when the frontend uses the authorized URL, a CORS error occurs. To avoid this issue, ensure that Content-Type fields at both the frontend and backend are kept consistent.
Method
ObsClient.createSignedUrl(method, bucketName, objectKey, specialParam, expires, headers, queryParams)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
method |
str |
Yes |
Explanation: HTTP methods Value range:
Default value: None |
bucketName |
str |
No |
Explanation: Bucket name Restrictions:
objectKey |
str |
No |
Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
specialParam |
str |
No |
Explanation: Special operator, which indicates the sub-resource to be operated Value range:
expires |
int |
No |
Explanation: Expiration time of the signed URL Value range:
Default value: 300 |
headers |
dict |
No |
Explanation: Headers in the request Default value: None |
queryParams |
dict |
No |
Explanation: Query parameters in the request Default value: None |
Responses
Parameter |
Type |
Description |
signedUrl |
str |
Explanation: Signed URL Default value: None |
actualSignedRequestHeaders |
dict |
Explanation: Actual headers in the request initiated by using the signed URL Default value: None |
Code Examples
This example creates temporary signed URLs.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 |
from obs import ObsClient import os import traceback import base64 # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: # Create a signed URL for creating a bucket. res1 = obsClient.createSignedUrl(method='PUT', bucketName='bucketname', expires=3600) print('signedUrl:', res1.signedUrl) print('actualSignedRequestHeaders:', res1.actualSignedRequestHeaders) # Create a signed URL for uploading an object. res2 = obsClient.createSignedUrl(method='PUT', bucketName='bucketname', objectKey='objectkey', expires=3600, headers={'Content-Type': 'text/plain'}) print('signedUrl:', res2.signedUrl) print('actualSignedRequestHeaders:', res2.actualSignedRequestHeaders) # Create a signed URL for setting an object ACL. res3 = obsClient.createSignedUrl(method='PUT', bucketName='bucketname', objectKey='objectkey', specialParam='acl', expires=3600, headers={'x-obs-acl': 'private'}) print('signedUrl:', res3.signedUrl) print('actualSignedRequestHeaders:', res3.actualSignedRequestHeaders) # Create a signed URL for downloading an object. res4 = obsClient.createSignedUrl(method='GET', bucketName='bucketname', objectKey='objectkey', expires=3600) print('signedUrl:', res4.signedUrl) print('actualSignedRequestHeaders:', res4.actualSignedRequestHeaders) # Create a signed URL for deleting an object. res5 = obsClient.createSignedUrl(method='DELETE', bucketName='bucketname', objectKey='objectkey', expires=3600) print('signedUrl:', res5.signedUrl) print('actualSignedRequestHeaders:', res5.actualSignedRequestHeaders) # Create a signed URL for deleting a bucket. res6 = obsClient.createSignedUrl(method='DELETE', bucketName='bucketname', expires=3600) print('signedUrl:', res6.signedUrl) print('actualSignedRequestHeaders:', res6.actualSignedRequestHeaders) # Create a signed URL for initiating a multipart task. res7 = obsClient.createSignedUrl(method='POST', bucketName='bucketname', objectKey='objectkey', specialParam='uploads', expires=3600) print('signedUrl:', res7.signedUrl) print('actualSignedRequestHeaders:', res7.actualSignedRequestHeaders) # Create a signed URL for uploading a part. res8 = obsClient.createSignedUrl(method='PUT', bucketName='bucketname', objectKey='objectkey', expires=3600, queryParams={'partNumber': '1', 'uploadId': '00000*****'}) print('signedUrl:', res8.signedUrl) print('actualSignedRequestHeaders:', res8.actualSignedRequestHeaders) # Create a signed URL for assembling parts. res9 = obsClient.createSignedUrl(method='POST', bucketName='bucketname', objectKey='objectkey', expires=3600, queryParams={'uploadId': '00000*****'}) print('signedUrl:', res9.signedUrl) print('actualSignedRequestHeaders:', res9.actualSignedRequestHeaders) # Create a signed URL for image persistency. # Name of the bucket that stores the source object bucketName = 'originBucketName'; # Source object name before the processing objectKey = 'test.png'; # Name of the object after processing targetObjectName ="save.png" # (Optional) Name of the bucket that stores the new object targetBucketName ="saveBucketName" queryParams={} queryParams["x-image-process"]="image/resize,w_100" queryParams["x-image-save-object"]=base64.b64encode(targetObjectName .encode("utf-8")).decode() # Optional parameter queryParams["x-image-save-bucket"]=base64.b64encode(targetBucketName .encode("utf-8")).decode() res10 = obsClient.createSignedUrl(method='GET', bucketName=bucketName, objectKey=objectKey, queryParams=queryParams, expires=3600) print('signedUrl:', res10.signedUrl) print('actualSignedRequestHeaders:', res10.actualSignedRequestHeaders) except: print(traceback.format_exc()) |
Feedback
Was this page helpful?
Chatbot
