Help Center/ Data Lake Insight/ Delta SQL Syntax Reference/ Delta Time Travel/ Viewing History Operation Records of a Delta Table
Updated on 2025-01-09 GMT+08:00
Syntax
DESCRIBE HISTORY [database_name.]table_name|DELTA.`obs_path` [LIMIT n]
Example
DESCRIBE HISTORY delta_table0;
DESCRIBE HISTORY delta.`obs://tablePath` LIMIT 1;
System Response
Returns the table's historical operations, with the meaning of the result indicators shown in the following table.
Table 1 Result metrics
Metric
Description
version
Version number of the table operation
timestamp
Timestamp of the current version operation
userId
User ID of the current version operation
userName
Username of the current version operation
operation
Operation name (e.g., WRITE, CREATE TABLE, UPDATE, DELETE, MERGE, RESTORE)
operationParameters
Operation parameters
job
Detailed information about the job running the operation
notebook
Detailed information about the notebook running the operation
clusterId
Cluster ID
readVersion
Table version read for the write operation
isolationLevel
Isolation level
isBlindAppend
Whether data is appended
operationMetrics
Metrics of the operation (e.g., number of files modified, rows modified, bytes modified)
engineInfo
Information on Spark and Delta versions
