Updated on 2025-01-09 GMT+08:00
INSERT
Function
This command inserts SELECT query results to a Delta table.
Syntax
Append mode:
INSERT INTO [database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`
select query;
Overwrite mode:
INSERT OVERWRITE [database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`
select query;
Parameter Description
Table 1 Parameter descriptions of INSERT INTO
Parameter
Description
database_name
Name of the database, consisting of letters, numbers, and underscores (_)
table_name
Name of the table in the database, consisting of letters, numbers, and underscores (_)
bucket_name
OBS bucket name
tbl_path
Storage location of the Delta table in the OBS bucket
select query
Query statement
Required Permissions
  • SQL permissions
Table 2 Permissions required for executing INSERT INTO
Permission Description
INSERT_INTO_TABLE permission on a table
  • Fine-grained permission: dli:table:insertIntoTable
  • Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Example
insert into delta_table0 values(1, 'a1', 20);
insert into delta_table0 select 1, 'a1', 20;
insert into test_delta_parts1 PARTITION(dt) select id,name,dt from test_delta1;
-- insert overwrite table
insert overwrite table delta_table0 select 1, 'a1', 20;
System Response
Displays whether the task is successfully executed in the execution history or job list.
