Help Center/
Data Lake Insight/
Flink SQL Syntax Reference/
Flink Opensource SQL 1.10 Syntax Reference/
Data Manipulation Language (DML)/
Deduplication
Updated on 2025-07-04 GMT+08:00
Deduplication
Function
Deduplication removes rows that duplicate over a set of columns, keeping only the first one or the last one.
Syntax
SELECT [column_list] FROM ( SELECT [column_list], ROW_NUMBER() OVER ([PARTITION BY col1[, col2...]] ORDER BY time_attr [asc|desc]) AS rownum FROM table_name) WHERE rownum = 1
Description
- ROW_NUMBER(): Assigns a unique, sequential number to each row, starting with one.
- PARTITION BY col1[, col2...]: Specifies the partition columns, for example, the deduplicate key.
- ORDER BY time_attr [asc|desc]: Specifies the ordering column, which must be a time attribute. Currently Flink supports proctime only. Ascending (ASC) sorting keeps only the first row, while descending (DESC) sorting keeps only the last row.
- WHERE rownum = 1: The rownum = 1 is required for Flink to recognize this query is deduplication.
Precautions
None
Example
The following examples show how to remove duplicate rows on order_id. The proctime is an event time attribute.
SELECT order_id, user, product, number FROM ( SELECT *, ROW_NUMBER() OVER (PARTITION BY order_id ORDER BY proctime ASC) as row_num FROM Orders) WHERE row_num = 1;
Parent topic: Data Manipulation Language (DML)
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
