Updated on 2025-07-04 GMT+08:00
Temporal Functions
Table 1 lists the time functions supported by Flink OpenSource SQL.
Description
Table 1 Temporal Functions
Function
Return Type
Description
DATE string
DATE
Parse the date string (yyyy-MM-dd) to a SQL date.
TIME string
TIME
Parse the time string (HH:mm:ss[.fff]) to a SQL time.
TIMESTAMP string
TIMESTAMP
Convert the time string into a timestamp. The time string format is yyyy-MM-dd HH:mm:ss[.fff].
INTERVAL string range
INTERVAL
interval indicates the interval. There are two forms:
  • yyyy-MM for SQL intervals of months. An interval range might be YEAR or YEAR TO MONTH for intervals of months.
  • dd hh:mm:ss.fff for SQL intervals of milliseconds. An interval range might be DAY, MINUTE, DAY TO HOUR, or DAY TO SECOND.
Example:
INTERVAL '10 00:00:00.004' DAY TO second indicates that the interval is 10 days and 4 milliseconds.
INTERVAL '10' DAY: indicates that the interval is 10 days.
INTERVAL '2-10' YEAR TO MONTH indicates that the interval is two years and ten months.
CURRENT_DATE
DATE
Return the SQL date of UTC time zone.
CURRENT_TIME
TIME
Return the SQL time of UTC time zone.
CURRENT_TIMESTAMP
TIMESTAMP
Return the SQL timestamp of UTC time zone.
LOCALTIME
TIME
Return the SQL time of the current time zone.
LOCALTIMESTAMP
TIMESTAMP
Return the SQL timestamp of the current time zone.
EXTRACT(timeintervalunit FROM temporal)
BigInt
Extract part of the time point or interval. Return the part in the int type.
For example, extract the date 2006-06-05 and return 5.
EXTRACT(DAY FROM DATE '2006-06-05') returns 5.
YEAR(date)
BigInt
Return the year from SQL date.
For example, YEAR(DATE'1994-09-27') returns 1994.
QUARTER(date)
BigInt
Return the quarter of a year (an integer between 1 and 4) from SQL date.
MONTH(date)
BigInt
Return the month of a year (an integer between 1 and 12) from SQL date.
For example, MONTH(DATE '1994-09-27') returns 9.
WEEK(date)
BigInt
Return the week of a year (an integer between 1 and 53) from SQL date.
For example, WEEK(DATE'1994-09-27') returns 39.
DAYOFYEAR(date)
BigInt
Returns the day of a year (an integer between 1 and 366) from SQL date.
For example, DAYOFYEAR(DATE '1994-09-27') is 270.
DAYOFMONTH(date)
BigInt
Return the day of a month (an integer between 1 and 31) from SQL date.
For example, DAYOFMONTH(DATE'1994-09-27') returns 27.
DAYOFWEEK(date)
BigInt
Return the day of a week (an integer between 1 and 7) from SQL date.
Sunday is set to 1.
For example, DAYOFWEEK(DATE'1994-09-27') returns 3.
HOUR(timestamp)
BigInt
Returns the hour of a day (an integer between 0 and 23) from SQL timestamp.
For example, HOUR(TIMESTAMP '1994-09-27 13:14:15') returns 13.
MINUTE(timestamp)
BigInt
Returns the minute of an hour (an integer between 0 and 59) from a SQL timestamp.
For example, MINUTE(TIMESTAMP '1994-09-27 13:14:15') returns 14.
SECOND(timestamp)
BigInt
Returns the second of a minute (an integer between 0 and 59) from a SQL timestamp.
For example, SECOND(TIMESTAMP '1994-09-27 13:14:15') returns 15.
FLOOR(timepoint TO timeintervalunit)
TIME
Round a time point down to the given unit.
For example, 12:44:00 is returned from FLOOR(TIME '12:44:31' TO MINUTE).
CEIL(timepoint TO timeintervalunit)
TIME
Round a time point up to the given unit.
For example, CEIL(TIME '12:44:31' TO MINUTE) returns 12:45:00.
(timepoint1, temporal1) OVERLAPS (timepoint2, temporal2)
BOOLEAN
Return TRUE if two time intervals defined by (timepoint1, temporal1) and (timepoint2, temporal2) overlap.
Example:
(TIME '2:55:00', INTERVAL '1' HOUR) OVERLAPS (TIME '3:30:00', INTERVAL '2' HOUR) returns TRUE.
(TIME '9:00:00', TIME '10:00:00') OVERLAPS (TIME '10:15:00', INTERVAL '3' HOUR) returns FALSE.
DATE_FORMAT(timestamp, string)
String
Convert a timestamp to a value of string in the format specified by the date format string.
TIMESTAMPADD(timeintervalunit, interval, timepoint)
TIMESTAMP/DATE/TIME
Return the date and time added to timepoint based on the result of interval and timeintervalunit.
For example, TIMESTAMPADD(WEEK, 1, DATE '2003-01-02') returns 2003-01-09.
TIMESTAMPDIFF(timepointunit, timepoint1, timepoint2)
INT
Return the (signed) number of timepointunit between timepoint1 and timepoint2.
The unit for the interval is given by the first argument, which should be one of the following values: SECOND, MINUTE, HOUR, DAY, MONTH, or YEAR.
For example, TIMESTAMPDIFF(DAY, TIMESTAMP '2003-01-02 10:00:00', TIMESTAMP '2003-01-03 10:00:00') returns 1.
CONVERT_TZ(string1, string2, string3)
TIMESTAMP
Convert a datetime string1 from time zone string2 to time zone string3.
For example, CONVERT_TZ('1970-01-01 00:00:00', 'UTC', 'Country A/City A') returns '1969-12-31 16:00:00'.
FROM_UNIXTIME(numeric[, string])
String
Return a string representation of the numeric argument (in seconds) in the current time zone.
The default string format is YYYY-MM-DD hh:mm:ss.
For example, FROM_UNIXTIME(44) returns 1970-01-01 09:00:44.
UNIX_TIMESTAMP()
BigInt
Get current Unix timestamp in seconds.
UNIX_TIMESTAMP(string1[, string2])
BigInt
Convert date time string string1 in format string2 to Unix timestamp (in seconds), using the specified timezone in table config.
The default format of string2 is yyyy-MM-dd HH:mm:ss.
TO_DATE(string1[, string2])
DATE
Convert a date string string1 with format string2 to a date.
The default format of string2 is yyyy-MM-dd.
TO_TIMESTAMP(string1[, string2])
TIMESTAMP
Converts date time string string1 with format string2 under the 'UTC+0' time zone to a timestamp.
DATE
  • Function
    Returns a SQL date parsed from string in form of yyyy-MM-dd.
  • Description
    DATE DATE string
  • Input parameters
    Parameter
    Data Type
    Description
    string
    String
    String in the SQL date format.
    Note that the string must be in the yyyy-MM-dd format. Otherwise, an error will be reported.
  • Example
    • Test statement
      SELECT
      	DATE "2021-08-19" AS `result`
      FROM
      	testtable;
    • Test result
      Result
      2021-08-19
TIME
  • Function
    Returns a SQL time parsed from string in form of HH:mm:ss[.fff].
  • Description
    TIME TIME string
  • Input parameters
    Parameter
    Data Type
    Description
    string
    String
    Time
    Note that the string must be in the format of HH:mm:ss[.fff]. Otherwise, an error will be reported.
  • Example
    • Test statement
      SELECT
      	TIME "10:11:12" AS `result`,
              TIME "10:11:12.032" AS `result2`
      FROM
      	testtable;
    • Test result
      Result
      Result 2
      10:11:12
      10:11:12.032
TIMESTAMP
  • Function
    Converts the time string into timestamp. The time string format is yyyy-MM-dd HH:mm:ss[.fff]. The return value is of the TIMESTAMP(3) type.
  • Description
    TIMESTAMP(3) TIMESTAMP string
  • Input parameters
    Parameter
    Data Type
    Description
    string
    String
    Time
    Note that the string must be in the format of yyyy-MM-dd HH:mm:ss[.fff]. Otherwise, an error will be reported.
  • Example
    • Test statement
      SELECT
      	TIMESTAMP "1997-04-25 13:14:15" AS `result`,
              TIMESTAMP "1997-04-25 13:14:15.032" AS `result2`
      FROM
      	testtable;
    • Test result
      Result
      Result 2
      1997-04-25 13:14:15
INTERVAL
  • Function
    Parses an interval string.
  • Description
    INTERVAL INTERVAL string range
  • Input parameters
    Parameter
    Data Type
    Description
    string
    String
    Timestamp string used together with the range parameter. The string is in either of the following two formats:
    range
    INTERVAL
    Interval range. This parameter is used together with the string parameter.
    Available values are as follows: YEAR, YEAR To Month, DAY, MINUTE, DAY TO HOUR and DAY TO SECOND.
  • Example
    Test statement
    -- indicates that the interval is 10 days and 4 milliseconds.
    -- The interval is 10 days.
    INTERVAL '10'
    -- The interval is 2 years and 10 months.
CURRENT_DATE
  • Function
    Returns the current SQL time (yyyy-MM-dd) in the local time zone. The return value is of the DATE type.
  • Description
    DATE CURRENT_DATE
  • Input parameters
    None
  • Example
    • Test statement
      SELECT
      	CURRENT_DATE AS `result`
      FROM
      	testtable;
    • Test result
      Result
      2021-10-28
CURRENT_TIME
  • Function
    Returns the current SQL time (HH:mm:sss.fff) in the local time zone. The return value is of the TIME type.
  • Description
    TIME CURRENT_TIME
  • Input parameters
    None
  • Example
    • Test statement
      SELECT
      	CURRENT_TIME AS `result`
      FROM
      	testtable;
    • Test result
      Result
      08:29:19.289
CURRENT_TIMESTAMP
  • Function
    Returns the current SQL timestamp in the local time zone. The return value is of the TIMESTAMP(3) type.
  • Description
    TIMESTAMP(3) CURRENT_TIMESTAMP
  • Input parameters
    None
  • Example
    • Test statement
      SELECT
      	CURRENT_TIMESTAMP AS `result`
      FROM
      	testtable;
    • Test result
      Result
      2021-10-28 08:33:51.606
LOCALTIME
  • Function
    Returns the current SQL time in the local time zone. The return value is of the TIME type.
  • Description
    TIME LOCALTIME
  • Input parameters
    None
  • Example
    • Test statement
      SELECT
      	LOCALTIME AS `result`
      FROM
      	testtable;
    • Test result
      Result
      16:39:37.706
LOCALTIMESTAMP
  • Function
  • Description
    TIMESTAMP(3) LOCALTIMESTAMP
  • Input parameters
    None
  • Example
    • Test statement
      SELECT
      	LOCALTIMESTAMP AS `result`
      FROM
      	testtable;
    • Test result
      Result
      2021-10-28 16:43:17.625
EXTRACT
  • Function
    Returns a value extracted from the timeintervalunit part of temporal. The return value is of the BIGINT type.
  • Description
    BIGINT EXTRACT(timeinteravlunit FROM temporal)
  • Input parameters
    Parameter
    Data Type
    Description
    timeinteravlunit
    TIMEUNIT
    Time unit to be extracted from a time point or interval. The value can be YEAR, QUARTER, MONTH, WEEK, DAY, DOY, HOUR, MINUTE, or SECOND.
    temporal
    DATE/TIME/TIMESTAMP/INTERVAL
    Time point or interval
    Do not specify a time unit that is not of any time points or intervals. Otherwise, the job fails to be submitted.
    For example, an error message is displayed when the following statement is executed because YEAR cannot be extracted from TIME.
    SELECT
    	EXTRACT(YEAR FROM TIME '12:44:31' ) AS `result`
    FROM
    	testtable;
  • Example
    • Test statement
      SELECT
      	EXTRACT(YEAR FROM DATE '1997-04-25' ) AS `result`,
              EXTRACT(MINUTE FROM TIME '12:44:31') AS `result2`,
              EXTRACT(SECOND FROM TIMESTAMP '1997-04-25 13:14:15') AS `result3`,
              EXTRACT(YEAR FROM INTERVAL '2-10' YEAR TO MONTH) AS `result4`,
      FROM
      	testtable;
    • Test result
      Result
      Result 2
      Result 3
      Result 4
      1997
      44
      15
      2
YEAR
  • Function
    Returns the year from a SQL date date. The return value is of the BIGINT type.
  • Description
    BIGINT YEAR(date)
  • Input parameters
    Parameter
    Data Type
    Description
    date
    DATE
    SQL date
  • Example
    • Test statement
      SELECT
      	YEAR(DATE '1997-04-25' ) AS `result`
      FROM
      	testtable;
    • Test result
      Result
      1997
QUARTER
  • Function
    Returns the quarter of a year (an integer between 1 and 4) from a SQL date date. The return value is of the BIGINT type.
  • Description
    BIGINT QUARTER(date)
  • Input parameters
    Parameter
    Data Type
    Description
    date
    DATE
    SQL date
  • Example
    • Test statement
      SELECT
      	QUARTER(DATE '1997-04-25' ) AS `result`
      FROM
      	testtable;
    • Test result
      Result
      2
MONTH
  • Function
    Returns the month of a year (an integer between 1 and 12) from a SQL date date. The return value is of the BIGINT type.
  • Description
    BIGINT MONTH(date)
  • Input parameters
    Parameter
    Data Type
    Description
    date
    DATE
    SQL date
  • Example
    • Test statement
      SELECT
      	MONTH(DATE '1997-04-25' ) AS `result`
      FROM
      	testtable;
    • Test result
      Result
      4
WEEK
  • Function
    Returns the week of a year from a SQL date date. The return value is of the BIGINT type.
  • Description
    BIGINT WEEK(date)
  • Input parameters
    Parameter
    Data Type
    Description
    date
    DATE
    SQL date
  • Example
    • Test statement
      SELECT
      	WEEK(DATE '1997-04-25' ) AS `result`
      FROM
      	testtable;
    • Test result
      Result
      17
DAYOFYEAR
  • Function
    Returns the day of a year (an integer between 1 and 366) from SQL date date. The return value is of the BIGINT type.
  • Description
    BIGINT DAYOFYEAR(date)
  • Input parameters
    Parameter
    Data Type
    Description
    date
    DATE
    SQL date
  • Example
    • Test statement
      SELECT
      	DAYOFYEAR(DATE '1997-04-25' ) AS `result`
      FROM
      	testtable;
    • Test result
      Result
      115
DAYOFMONTH
  • Function
    Returns the day of a month (an integer between 1 and 31) from a SQL date date. The return value is of the BIGINT type.
  • Description
    BIGINT DAYOFMONTH(date)
  • Input parameters
    Parameter
    Data Type
    Description
    date
    DATE
    SQL date
  • Example
    • Test statement
      SELECT
      	DAYOFMONTH(DATE '1997-04-25' ) AS `result`
      FROM
      	testtable;
    • Test result
      Result
      25
DAYOFWEEK
  • Function
    Returns the day of a week (an integer between 1 and 7) from a SQL date date. The return value is of the BIGINT type.
    Note that a calendar week starts on Sunday.
  • Description
    BIGINT DAYOFWEEK(date)
  • Input parameters
    Parameter
    Data Type
    Description
    date
    DATE
    SQL date
  • Example
    • Test statement
      SELECT
      	DAYOFWEEK(DATE '1997-04-25') AS `result`
      FROM
      	testtable;
    • Test result
      Result
      6
HOUR
  • Function
    Returns the hour of a day (an integer between 0 and 23) from SQL timestamp timestamp. The return value is of the BIGINT type.
  • Description
    BIGINT HOUR(timestamp)
  • Input parameters
    Parameter
    Data Type
    Description
    timestamp
    TIMESTAMP
    SQL timestamp
  • Example
    • Test statement
      SELECT
      	HOUR(TIMESTAMP '1997-04-25 10:11:12') AS `result`
      FROM
      	testtable;
    • Test result
      Result
      10
MINUTE
  • Function
    Returns the minute of an hour (an integer between 0 and 59) from a SQL timestamp. The return value is of the BIGINT type.
  • Description
    BIGINT MINUTE(timestamp)
  • Input parameters
    Parameter
    Data Type
    Description
    timestamp
    TIMESTAMP
    SQL timestamp
  • Example
    • Test statement
      SELECT
      	MINUTE(TIMESTAMP '1997-04-25 10:11:12') AS `result`
      FROM
      	testtable;
    • Test result
      Result
      11
SECOND
  • Function
    Returns the second of an hour (an integer between 0 and 59) from a SQL timestamp. The return value is of the BIGINT type.
  • Description
    BIGINT SECOND(timestamp)
  • Input parameters
    Parameter
    Data Type
    Description
    timestamp
    TIMESTAMP
    SQL timestamp
  • Example
    • Test statement
      SELECT
      	SECOND(TIMESTAMP '1997-04-25 10:11:12') AS `result`
      FROM
      	testtable;
    • Test result
      Result
      12
FLOOR
  • Function
    Returns a value that rounds timepoint down to the time unit timeintervalunit.
  • Description
    TIME/TIMESTAMP(3) FLOOR(timepoint TO timeintervalunit)
  • Input parameters
    Parameter
    Data Type
    Description
    timepoint
    TIMESTAMP/TIME
    SQL time or SQL timestamp
    timeintervalunit
    TIMEUNIT
    Time unit. The value can be YEAR, QUARTER, MONTH, WEEK, DAY, DOY, HOUR, MINUTE, or SECOND.
  • Example
    • Test statement
      SELECT
      	FLOOR(TIME '13:14:15' TO MINUTE) AS `result`
              FLOOR(TIMESTAMP '1997-04-25 13:14:15' TO MINUTE) AS `result2`,
              FLOOR(TIMESTAMP '1997-04-25 13:14:15' TO MINUTE) AS `result3`
      FROM	testtable;
    • Test result
      message
      message2
      message3
      13:14
      13:14
      1997-04-25T13:14
CEIL
  • Function
    Returns a value that rounds timepoint up to the time unit timeintervalunit.
  • Description
    TIME/TIMESTAMP(3) CEIL(timepoint TO timeintervalunit)
  • Input parameters
    Parameter
    Data Type
    Description
    timepoint
    TIMESTAMP/TIME
    timeintervalunit
    TIMEUNIT
  • Example
    • Test statement
      SELECT
      	CEIL(TIME '13:14:15' TO MINUTE) AS `result`
              CEIL(TIMESTAMP '1997-04-25 13:14:15' TO MINUTE) AS `result2`,
              CEIL(TIMESTAMP '1997-04-25 13:14:15' TO MINUTE) AS `result3`
      FROM	testtable;
    • Test result
      Result
      Result 2
      Result 3
      13:15
      13:15
      1997-04-25T13:15
OVERLAPS
  • Function
    Returns TRUE if two time intervals overlap; returns FALSE otherwise.
  • Description
    BOOLEAN (timepoint1, temporal1) OVERLAPS (timepoint2, temporal2)
  • Input parameters
    Parameter
    Data Type
    Description
    timepoint1/timepoint2
    DATE/TIME/TIMESTAMP
    Time point
    temporal1/temporal2
    • (timepoint, temporal) is a closed interval.
    • The temporal can be of the DATE, TIME, TIMESTAMP, or INTERVAL type.
      • When th temporal is DATE, TIME, or TIMESTAMP, (timepoint, temporal) indicates an interval between timepoint and temporal. The temporal can be earlier than the value of timepoint, for example, (DATE '1997-04-25', DATE '1997-04-23').
      • When the temporal is INTERVAL, (timepoint, temporal) indicates an interval between timepoint and timepoint + temporal.
    • Ensure that (timepoint1, temporal1) and (timepoint2, temporal2) are intervals of the same data type.
  • Example
    • Test statement
      SELECT
      	(TIME '2:55:00', INTERVAL '1' HOUR) OVERLAPS (TIME '3:30:00', INTERVAL '2' HOUR) AS `result`,
              (TIME '2:30:00', INTERVAL '1' HOUR) OVERLAPS (TIME '3:30:00', INTERVAL '2' HOUR) AS `result2`,
      	(TIME '2:30:00', INTERVAL '1' HOUR) OVERLAPS (TIME '3:31:00', INTERVAL '2' HOUR) AS `result3`,
      	(TIME '9:00:00', TIME '10:00:00') OVERLAPS (TIME '10:00:00', INTERVAL '3' HOUR) AS `result4`,
      	(TIMESTAMP '1997-04-25 12:00:00', TIMESTAMP '1997-04-25 12:20:00') OVERLAPS (TIMESTAMP '1997-04-25 13:00:00', INTERVAL '2' HOUR) AS `result5`,
      	(DATE '1997-04-23', INTERVAL '2' DAY) OVERLAPS (DATE '1997-04-25', INTERVAL '2' DAY) AS `result6`,
      	(DATE '1997-04-25', DATE '1997-04-23') OVERLAPS (DATE '1997-04-25', INTERVAL '2' DAY) AS `result7`
      FROM
      	testtable;
    • Test result
      Result
      Result 2
      Result 3
      Result 4
      Result 5
      Result 6
      Result 7
      true
      true
      false
      true
      false
      true
      true
DATE_FORMAT
  • Function
    Converts a timestamp to a value of string in the format specified by the date format string.
  • Description
    STRING DATE_FORMAT(timestamp, dateformat)
  • Input parameters
    Parameter
    Data Type
    Description
    timestamp
    Timestamp/String
    Time point
    dateformat
    String
    String in the date format
  • Example
    • Test statement
      SELECT
      	DATE_FORMAT(TIMESTAMP '1997-04-25 10:11:12', 'yyyy-MM-dd HH:mm:ss') AS `result`,
              DATE_FORMAT(TIMESTAMP '1997-04-25 10:11:12', 'yyyy-MM-dd') AS `result2`,
      	DATE_FORMAT(TIMESTAMP '1997-04-25 10:11:12', 'yy/MM/dd HH:mm') AS `result3`,
              DATE_FORMAT('1997-04-25 10:11:12', 'yyyy-MM-dd') AS `result4`
      FROM	testtable;
    • Test result
      Result
      Result 2
      Result 3
      Result 4
      1997-04-25 10:11:12
      1997-04-25
      97/04/25 10:11
      1997-04-25
TIMESTAMPADD
  • Function
    Returns the date and time by combining interval and timeintervalunit and adding the combination to timepoint.
    The return value of TIMESTAMPADD is the value of timepoint. An exception is that if the input timepoint is of the TIMESTAMP type, the return value can be inserted into a table field of the DATE type.
  • Description
    TIMESTAMP(3)/DATE/TIME TIMESTAMPADD(timeintervalunit, interval, timepoint)
  • Input parameters
    Parameter
    Data Type
    Description
    timeintervalunit
    TIMEUNIT
    Time unit.
    interval
    INT
    Interval
    timepoint
    TIMESTAMP/DATE/TIME
    Time point
  • Example
    • Test statement
      SELECT
      	TIMESTAMPADD(WEEK, 1, DATE '1997-04-25') AS `result`,
              TIMESTAMPADD(QUARTER, 1, TIMESTAMP '1997-04-25 10:11:12') AS `result2`,
      	TIMESTAMPADD(SECOND, 2, TIME '10:11:12') AS `result3`
      FROM	testtable;
    • Test result
      Result
      Result 2
      Result 3
      1997-05-02
      • If this field is inserted into a table field of the TIMESTAMP type, 1997-07-25T10:11:12 is returned.
      • If this field is inserted into a table field of the TIMESTAMP type, 1997-07-25 is returned.
      10:11:14
TIMESTAMPDIFF
  • Function
    Returns the (signed) number of timepointunit between timepoint1 and timepoint2. The unit for the interval is given by the first argument.
  • Description
    INT TIMESTAMPDIFF(timepointunit, timepoint1, timepoint2)
  • Input parameters
    Parameter
    Data Type
    Description
    timepointunit
    TIMEUNIT
    Time unit. The value can be SECOND, MINUTE, HOUR, DAY, MONTH or YEAR.
    TIMESTAMP/DATE
    Time point
  • Example
    • Test statement
      SELECT
      	TIMESTAMPDIFF(DAY, TIMESTAMP '1997-04-25 10:00:00', TIMESTAMP '1997-04-28 10:00:00') AS `result`,
              TIMESTAMPDIFF(DAY, DATE '1997-04-25', DATE '1997-04-28') AS `result2`,
      	TIMESTAMPDIFF(DAY, TIMESTAMP '1997-04-27 10:00:20', TIMESTAMP '1997-04-25 10:00:00') AS `result3`
      FROM	testtable;
    • Test result
      Result
      Result 2
      Result 3
      3
      3
      -2
CONVERT_TZ
  • Function
    Converts a datetime string1 (with default ISO timestamp format 'yyyy-MM-dd HH:mm:ss') from time zone string2 to time zone string3.
  • Description
    STRING CONVERT_TZ(string1, string2, string3)
  • Input parameters
    Parameter
    Data Type
    Description
    string1
    String
    SQL timestamp. If the value does not meet the format requirements, NULL is returned.
    string2
    String
    Time zone before conversion. The format of time zone should be either an abbreviation such as PST, a full name such as Country A/City A, or a custom ID such as GMT-08:00.
    string3
    String
    Time zone after conversion. The format of time zone should be either an abbreviation such as PST, a full name such as Country A/City A, or a custom ID such as GMT-08:00.
  • Example
    • Test statement
      SELECT
      	CONVERT_TZ(1970-01-01 00:00:00, UTC, Country A/City A) AS `result`,
              CONVERT_TZ(1997-04-25 10:00:00, UTC, GMT-08:00) AS `result2`
      FROM	testtable;
    • Test result
      Result
      Result 2
      1969-12-31 16:00:00
      1997-04-25 02:00:00
FROM_UNIXTIME
  • Function
    Returns a representation of the numeric argument as a value in string format.
  • Description
    STRING FROM_UNIXTIME(numeric[, string])
  • Input parameters
    Parameter
    Data Type
    Description
    numeric
    BigInt
    An internal timestamp representing the number of seconds since 1970-01-01 00:00:00 UTC. The value can be generated by the UNIX_TIMESTAMP() function.
    string
    String
    Time. If this parameter is not specified, the default time format is yyyy-MM-dd HH:mm:ss format.
  • Example
    • Test statement
      SELECT
      	FROM_UNIXTIME(44) AS `result`,
              FROM_UNIXTIME(44, 'yyyy:MM:dd') AS `result2`
      FROM	testtable;
    • Test result
      Result
      Result 2
      1970-01-01 08:00:44
      1970:01:01
UNIX_TIMESTAMP
  • Function
    Gets current Unix timestamp in seconds. The return value is of the BIGINT type.
  • Description
    BIGINT UNIX_TIMESTAMP()
  • Input parameters
    None
  • Example
    • Test statement
      SELECT
      	UNIX_TIMESTAMP() AS `result`
      FROM
      	table;
    • Test result
      Result
      1635401982
  • Function
    Converts date time string1 in format string2 to Unix timestamp (in seconds). The return value is of the BIGINT type.
  • Description
    BIGINT UNIX_TIMESTAMP(string1[, string2])
  • Input parameters
    Parameter
    Data Type
    Description
    string1
    String
    SQL timestamp string. An error is reported if the value does not comply with the string2 format.
    string2
    String
    Time. If this parameter is not specified, the default time format is yyyy-MM-dd HH:mm:ss.
  • Example
    • Test statement
      SELECT
      	UNIX_TIMESTAMP('1997-04-25', 'yyyy-MM-dd') AS `result`,
              UNIX_TIMESTAMP('1997-04-25 00:00:10', 'yyyy-MM-dd HH:mm:ss') AS `result2`,
              UNIX_TIMESTAMP('1997-04-25 00:00:00') AS `result3`
      FROM
      	testtable;
    • Test result
      Result
      Result 2
      Result 3
      861897600
      861897610
      861897600
TO_DATE
  • Function
    Converts a date string1 with format string2 to a date.
  • Description
    DATE TO_DATE(string1[, string2])
  • Input parameters
    Parameter
    Data Type
    Description
    string1
    String
    SQL timestamp string. If the value is not in the required format, an error is reported.
    string2
    String
    Format. If this parameter is not specified, the default time format is yyyy-MM-dd.
  • Example
    • Test statement
      SELECT
      	TO_DATE('1997-04-25') AS `result`,
              TO_DATE('1997:04:25', 'yyyy-MM-dd') AS `result2`,
              TO_DATE('1997-04-25 00:00:00', 'yyyy-MM-dd HH:mm:ss') AS `result3`
      FROM
      	testtable;
    • Test result
      Result
      Result 2
      Result 3
      1997-04-25
      1997-04-25
      1997-04-25
TO_TIMESTAMP
  • Function
    Converts date time string1 with format string2 to a timestamp.
  • Description
    TIMESTAMP TO_TIMESTAMP(string1[, string2])
  • Input parameters
    Parameter
    Data Type
    Description
    string1
    String
    SQL timestamp string. If the value is not in the required format, NULL is returned.
    string2
    String
    Date format. If this parameter is not specified, the default format is yyyy-MM-dd HH:mm:ss.
  • Example
    • Test statement
      SELECT
      	TO_TIMESTAMP('1997-04-25', 'yyyy-MM-dd') AS `result`,
              TO_TIMESTAMP('1997-04-25 00:00:00') AS `result2`,
              TO_TIMESTAMP('1997-04-25 00:00:00', 'yyyy-MM-dd HH:mm:ss') AS `result3`
      FROM
      	testtable;
    • Test result
      Result
      Result 2
      Result 3
      1997-04-25 00:00
      1997-04-25 00:00
      1997-04-25 00:00
