Updated on 2025-04-02 GMT+08:00
lastday
This function is used to return the last day of the month a date belongs to. The hour, minute, and second part is 00:00:00.
Similar function: last_day. The last_day function is used to return the last day of the month a date belongs to. The return value is in the yyyy-mm-dd format.
Syntax
lastday(string date)
Parameters
Table 1 Parameter
Parameter
Mandatory
Type
Description
date
Yes
DATE
or
STRING
Date that needs to be processed
The following formats are supported:
  • yyyy-mm-dd
  • yyyy-mm-dd hh:mi:ss
  • yyyy-mm-dd hh:mi:ss.ff3
Return Values
The return value is of the STRING type, in the yyyy-mm-dd hh:mi:ss format.
  • If the value of date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
  • If the value of date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
  • If the value of date is NULL, NULL is returned.
Example Code
The value 2023-08-31 is returned.
 select lastday('2023-08-10');
The value 2023-08-31 00:00:00 is returned.
 select lastday ('2023-08-10 10:54:00');
The value NULL is returned.
 select lastday (null);
