Updated on 2025-04-02 GMT+08:00
percentile_approx
This function is used to return the approximate percentile, which is applicable to a large amount of data. It sorts a specified column in ascending order, and then obtains the value closest to the pth percentile.
Syntax
percentile_approx (colname,DOUBLE p)
Parameters
Table 1 Parameters
Parameter
Mandatory
Type
Description
colname
Yes
STRING
Name of the column to be sorted
The elements in a column are of the DOUBLE type. If an element in a column is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation.
p
Yes
DOUBLE
The value can be a float, integer, or string.
The value ranges from 0 to 1. The value is a float.
Return Values
The return value is of the DOUBLE or ARRAY type.
  • If the column name does not exist, an error is reported.
  • If the value of p is NULL or outside the range of [0, 1], an error is reported.
Example Code
Assume that the elements in the int_test column are 1, 2, 3, and 4 and they are of the INT type.
The value 3 is returned.
select percentile_approx(int_test,0.7) FROM int_test;
select percentile_approx(int_test,0.75) FROM int_test;
The value 2 is returned.
select percentile_approx(int_test,0.5) FROM int_test;
The value [1,2,2,3,4] is returned.
select percentile_approx (int_test,ARRAY(0.1,0.3,0.5,0.6,0.9)) FROM int_test;
